Author Topic: a thinner,lighter repro front brake rotor work on a CB350/400F front wheel ?  (Read 9851 times)
Online grcamna2
I have a CB400F front wheel w/ stock 4 bolt mount front rotor and wondered if anyone makes a repro that mounts with the same dimensions/size,etc. but is thinner/lighter ? The stock disc is heavy stainless and i think an improvement(lightened cast iron?) would help.
« Last Edit: October 27, 2016, 07:07:36 AM by grcamna2 »
Online grcamna2
Offline Godffery
  • Godffery's Garage
Cast iron and stainless pretty close to same weight.. I think I would run a much thinner Stainless , than a really  thin cast iron..
Offline Bodi
Why does Honda specify minimum thickness 6mm - if this is a stock disk thinned to 4mm, what makes it immune to that specification?
Online grcamna2
I wouldn't even mind if it was just drilled w/o being thinned,I guess it would still be lighter.
« Last Edit: October 27, 2016, 03:01:13 PM by grcamna2 »
Offline robvangulik
  • Honda Fourever
Just drilling  made 1 disc 750 grams lighter, so both discs together made a difference of 1,5 kilogram.
Offline slikwilli420
  • Master of Disaster
Using two of them.
Offline MoMo
  • Ride like you're invisible
Bill, I have a pattern to drill a 400f rotor.  I've done a couple, doesn't take all that long and eats up one cobalt bit.   If you like I'd drill yours gratis...Larry
Honda over engineers everything, partly due to liability.
Pretty sure they like the piston to not go out further than need be...
Honda does not recommend it, but as with most racing stuff , there is always some sacrifice...so probably shorter component life. Hi performance modded stuff should be inspected more frequently than stock.
Note how thin most rotor are now, and many are floaters to avoid warping..? Stock Honda discs from the seventies are Stone Age...
Online grcamna2
The stock are heavy but they sure have lot's of extra life built into them  8)
Offline Godffery
  • Godffery's Garage
Brake Rotors were relatively new technology in the 1970's so they erred on the side of caution, by the late 70's early 80's they already started getting thinner and drilled.  I have done allot of these and found that 4.3mm is the "Sweet spot" and now I do all my drilled & thinned rotors to that thickness. Also; the number, size & location of holes is critical as well.
Online grcamna2
Thanks Jeff,PM sent.
Offline Godffery
  • Godffery's Garage
If you sent a PM to me, I don't think I got it...?  If you'd like, you can contact me directly at jstephens7@wi.rr.com
« Last Edit: October 29, 2016, 03:47:39 PM by Godffery »
Online grcamna2
I'm still waiting for a reply to my last email Jeff,thanks.
Offline Godffery
  • Godffery's Garage
Oh, ok. Got that and just replied.
Online grcamna2
thanks
Slotted will help with water evacuation for wet braking improvement while brake performance can be improved with proper application of holes for gas and material evacuation.
Offline sixthwisconsin
I have Jeffs rotors on both my 550 & 750f.
Highly recommended.
« Last Edit: November 04, 2016, 08:48:46 AM by sixthwisconsin »
Online grcamna2
Those look good sixthW  8) I'm purchasing from Godfferry also.
These oem machined rotors are looking like a much better choice than some chinese repro.
« Last Edit: November 03, 2016, 08:41:46 PM by grcamna2 »
Offline Godffery
  • Godffery's Garage
 Thanks for posting Pix, I always love to see these on the bikes!
I hope to be starting an album of Customer builds on my web site soon, I trust you won't mind me using these Photos...?
Let me get you a couple of beauty shots of the whole bikes complete. If the OP doesn't mind, I'll just post them here for you to grab.
Online grcamna2
Sure,love to see them myself.
