Author Topic: Anyone run TRW forged 750 pistons?or Hi compression 750 on the street?  (Read 1859 times)
Found a set of TRWbStandard 10.5-1. Pistons for a 750.
Just wondering if anyone had run these before ?
Or ran high compression 750 size on the street, with big cam 315 and maybe a bit of porting and Webers ?
Re: Anyone run TRW forged 750 pistons?or Hi compression 750 on the street?
« Reply #1 on: November 06, 2016, 08:27:40 PM »
My 836 pistons are TRW, but I think are higher compression than 10.5? I've got pics of both somewhere.. You MUST check for adequate valve clearance on the exhaust side.
« Reply #2 on: November 06, 2016, 08:48:28 PM »
The pic of the new 3mm over piston is courtesy of Jaguar, and is 10.25:1 or 10.5:1. My 4mm over pistons appear to have much higher crowns. Note the "eyebrows" where the exhaust valves were hitting the pistons.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: November 07, 2016, 04:07:37 AM »
OUCH!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
