Author Topic: CR 750 reinforced cam cover  (Read 13082 times)
Offline ratrap
Re: CR 750 reinforced cam cover
« Reply #50 on: November 23, 2016, 02:53:42 AM »
Looking at the pics I assume the added bolts bear down on the flat areas of the cam towers?
« Reply #51 on: November 23, 2016, 06:04:03 AM »
Possible with a rivet thread insert? No weld....
Example movie
If the hole is too wide, use a bigger rivet insert and in that use an M6 Time-sert.....
Maybe use of a shaped washer to control the angle of the rivet thread insert when the cover is curved.... + sealer..
« Reply #52 on: November 23, 2016, 01:42:50 PM »
Example movie
I think thats what Cyclex use, I've read of a couple of them failing...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #53 on: November 23, 2016, 01:56:18 PM »
Nope. From the pictures on their site, the insert they use has external threads and the hole in the valve cover would be tapped for the insert to be threaded in from what I can see. Can't speak one way or another as to reliability. Based on the CycleX approach, you could drill and tap the center of a short bolt (M10?) that could then be threaded into tapped holes in the valve cover.
Voila'  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dragracer
  • CB750F Dragbike
« Reply #54 on: November 23, 2016, 02:18:58 PM »
At what point do we really need to use this method to hold the rockers in place?? I guess I'm living on borrowed time after 18 years, but even with the RC327 cam, and using the advertised seat pressure for the KPMI springs, I have yet to lift a cam holder. I'll count my blessings for the many years of great service from the stock set up. I've had countless passes at WOT down the dragstrip without issue.  Keep the homebrew options coming guys, I may need to consider this over the winter time as added insurance.
« Reply #55 on: November 23, 2016, 03:32:44 PM »
For me it's more "old school cool" than anything. I have not seen any proven advantage, more of just a "warm fuzzy". This is one of the few mods where I might consider the form over function, i.e. I believe it looks cooler than it actually performs, but cool enough to implement!   ;) 8)
TAMTF...
Wilbur
Projects:
« Reply #56 on: November 23, 2016, 04:15:53 PM »
This... ;D  And I have a head full of helicoils, a bit of insurance... {cool insurance}  8)
Offline bear
  • Leeton in Australia
« Reply #57 on: November 23, 2016, 04:18:33 PM »
Not required in any way shape or form these days Frank.
 Buy a good "Helicoil" kit, a much better insurance policy in my opinion.  ;)
Brian
Offline bear
« Reply #58 on: November 23, 2016, 04:19:41 PM »
Beat me to it it Mick. ;)
« Last Edit: November 23, 2016, 04:22:05 PM by bear »
« Reply #59 on: November 23, 2016, 05:03:52 PM »
Brian
....and in mine too.    It's worked for years.
« Reply #60 on: November 23, 2016, 05:11:40 PM »
If you're just after the look, then J-B weld some threaded bungs onto the cover. Guaranteed not to leak! 8) ;D ;D
« Reply #61 on: November 23, 2016, 05:43:30 PM »
No way, if I'm going to do it then I'm going all in!  8)
TAMTF...
Wilbur
Projects:
« Reply #62 on: November 23, 2016, 05:49:28 PM »
If you want to do it right, welding is the proper method, IMHO. ;)
« Reply #63 on: November 24, 2016, 09:50:31 PM »
CycleX version has thread inserts in the thin cover, fastened with red loctite. No chance it will keep together. I have one in my garage as an example. One insert popped direct at assembly when the hole in cover had no threads. Maybe the tool spun to fast and worked as a drill. Insert just glued with loctite.
If a rivet thread insert can be used and aligned correctly it must work much better....
Offline ratrap
« Reply #64 on: November 25, 2016, 02:03:59 AM »
I drilled my camcover yesterday.
Took 30 minutes.
Busy turning up 13mm inserts threaded for 6mm bolts.
Welding will commence later.
To minimize any potential warping I will bolt the camcover down onto a spare cylinder head while welding.
If my welding looks OK I will post a pic   ;)
« Last Edit: November 25, 2016, 02:06:09 AM by ratrap »
« Reply #65 on: November 25, 2016, 12:34:05 PM »
Brian
Time sert work fine too. They have survived several assemblies and disassemblies better then the helicoil in threads that are frequenly used.
I'm told that the kibblewhite 5mm valve kit has springs with less pressure than std race springs. Also good for the threads.
Cams with relatively short duration and high lift will cause more stress, right? Or is it anything in real life?
DP315 has not that high lift and has a little bit longer duration. 0.3mm (0.12") in valve lash must be healthy too. (I set my other cams to 0.1mm In/ 0.15mm Ex
A valve cover with 8 bolts will sooner or later find its home on top of my engine :) I have an old dark grey with welded bolt holes from a K0 in need of TLC. It has JB weld around the welds that need to be removed. Grind and eventually seal if needed, but in alu look.
Offline Big Jay
    • CBRzone
« Reply #66 on: November 25, 2016, 02:26:52 PM »
Back in the day when we first started modding these motors, thewre were no valve springs. RC and othere were using S&W springs from, I believe,  a 2.3 liter Pinto engine. Way too much pressure and lifted the cam towers up.  That is when the bolts in the valve cover thing started.
Later on, we had springs specifically designed for the sohc 750 and with the correct pressure.  That was the end of needing that mod.
« Reply #67 on: November 25, 2016, 03:21:38 PM »
That's pretty much my understanding.  8)
Keep us straight Jay!  :D
TAMTF...
Wilbur
Projects:
« Reply #68 on: November 25, 2016, 04:15:21 PM »
My Yoshimura 812 and Daytona cam kit came with S & W springs.
Offline dragracer
  • CB750F Dragbike
« Reply #69 on: November 25, 2016, 08:59:36 PM »
And that was the reason I never bothered to mod my cover. I was concerned I was missing something here. I've been using APE springs since 1998 with no issues of pulling rocker studs/screws out in my 1030cc motor with RC327 cam. Goodness knows I have enough stuff to worry about instead of old school aesthetics. Still happy to see you guys thinking of new methods of doing the same trick-evolution at  its best.
Offline ratrap
« Reply #70 on: November 27, 2016, 11:01:31 PM »
All done. Camcover now off for beadblasting.
« Reply #71 on: November 27, 2016, 11:04:34 PM »
Ah a smoothed one..looks good..
Offline Jim F
  • go baby go
« Reply #72 on: November 29, 2016, 05:00:41 PM »
Well most of all, it just looks cool guys.
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #73 on: November 29, 2016, 08:13:46 PM »
I run a smooth one too
« Reply #74 on: November 29, 2016, 10:13:42 PM »
You can always tease someone you beat that extra weight helps you turn in more consistent lights...
Have them head scratch on that for a while.
