Author Topic: Jardine 4 into 2 exhaust  (Read 5443 times)
Offline markreimer
Re: Jardine 4 into 2 exhaust
« Reply #25 on: November 04, 2016, 11:56:22 AM »
I'll take a look when I get home in a few hours. I don't have the original muffler brackets though. Is it stamped anywhere on else? I'll see if I can find anything that helps to identify.
My front end is close to stock - I replaced the original springs with some Progressive springs about 4-5 years ago. Other than that, everything is stock. I weight 150lbs. I don't think I've had the issue while riding alone, but anytime I have a passenger or camping stuff on the back, watch out...
The interference is on the inside of 2/3. The fender literally goes right in between the two middle headers if you're riding in a straight line, preventing the bars from turning until the suspension pushes the wheel back out. If you are already in a turn, the fender just bashes into the header, hence my fender dents  :(
« Reply #26 on: November 04, 2016, 12:07:09 PM »
Hey mark, yours dont look like 'em.
A noticeable stamp "JARDINE" on the rear peg mount tab and trumpeted end.
« Last Edit: November 04, 2016, 12:10:43 PM by flybox1 »
Offline Darren Jakal
« Reply #27 on: November 04, 2016, 12:18:37 PM »
Hey thanks to all concerned, I'm actually quite touched by it.
Anyway, here is a pick of the outside pipe with the collar on.
The inside pipes ride pretty tight but maybe the bend is up high and sharp and in the right place for problems.
As Flybox says there are some differences between mine and yours and by my eye it does look like your pipes stick out a bit more.
I will for certain be aware of this when I get the bike together. I hope these work because they do look great.
cheers, Darren
« Reply #28 on: November 04, 2016, 02:04:13 PM »
Here is a picture of the rear bracket with the stamp 2047 R. Looks different from the other brackets I have seen.
Picture 2 is looking into the exhaust end.
There is no brand name that I can find.
I would love to know what these are as they are cool and the cost me $200 pesos.
cheers, dj
Offline markreimer
« Reply #29 on: November 05, 2016, 01:43:46 PM »
Well I tried to find a manufacturer stamp on my system and I couldn't see anything, so seems like we have different ones. Just check for clearance and if it's good, the get out and ride!
« Reply #30 on: November 05, 2016, 01:53:12 PM »
Hey thanks Mark,
I'll make sure to check these out for interference when I get it together.
Something to think about with any header I guess.
cheers, dj
Offline work9to5
« Reply #31 on: November 05, 2016, 02:13:31 PM »
Hey Mark, I run what I think is the exact pipes you have in one of my bikes. I don't have any issues with fork clearence (I'm running a gsxr front tho). One issue I should note was with the kickstand. It rubs/bangs on one of the pipes a bit. It's possible that I tucked them in too tight and could've moved them a cm right to avoid this on the install. But it's something to be wary of when you install them. I had mine on a jack not the stand when installing. I really like them tho, bike is pretty quiet and not "buzzy" like my others
