I'll take a look when I get home in a few hours. I don't have the original muffler brackets though. Is it stamped anywhere on else? I'll see if I can find anything that helps to identify.
My front end is close to stock - I replaced the original springs with some Progressive springs about 4-5 years ago. Other than that, everything is stock. I weight 150lbs. I don't think I've had the issue while riding alone, but anytime I have a passenger or camping stuff on the back, watch out...
The interference is on the inside of 2/3. The fender literally goes right in between the two middle headers if you're riding in a straight line, preventing the bars from turning until the suspension pushes the wheel back out. If you are already in a turn, the fender just bashes into the header, hence my fender dents
