Author Topic: Palepainter's 750f project.. Al Fine'  (Read 63596 times)
Re: My first CB 750f project has started
« Reply #75 on: December 09, 2016, 09:48:13 AM »
Comstars are not a much used wheel , many other better looking alternatives out there.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #76 on: December 09, 2016, 01:33:41 PM »
I blocked down the polyester and threw a few coats of primer on fairing today.  Pretty happy with the results.
Offline Lostboy Steve
« Reply #77 on: December 09, 2016, 04:49:16 PM »
Dude, it looks amazing.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline palepainter
« Reply #78 on: December 10, 2016, 08:37:19 AM »
The final tear down is just about finished.
« Last Edit: December 10, 2016, 01:30:11 PM by palepainter »
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #79 on: December 10, 2016, 03:59:03 PM »
Fairing looks great.  What do you have in mind for the paint job?
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline palepainter
« Reply #80 on: December 10, 2016, 05:15:51 PM »
Thanks Budman.  I just started working on the mockup with the computer.  I will post a few ideas tomorrow eve.
Offline palepainter
« Reply #81 on: December 12, 2016, 08:03:16 AM »
The separation is final.  Tough job for one guy.  Kind of like a Rubik's cube.
« Reply #82 on: December 12, 2016, 02:16:06 PM »
You might want to take Hondaman's suggestion and grind down the inner lip of those lower engine mounts on the frame.  The motor often hangs up on those as you try to reinstall it into the frame.  If possible, get your motor finished first, lay it on its side and mount the empty frame around it and bolt in. Easiest method.
Offline palepainter
« Reply #83 on: December 12, 2016, 02:34:30 PM »
Thanks for the assistance.  That is how I took it off.  But you are right.  Those flanges hung me up a few times.  I will do that when de tabbing the frame.
Offline GritCity750
  • 5th time's a charm!
« Reply #84 on: December 12, 2016, 06:02:34 PM »
Oh man is this GOOD advice. I ground down the lip on the front right mount and it made all the difference in the world when reinstalling the engine.
Offline palepainter
« Reply #85 on: December 12, 2016, 09:11:27 PM »
I cut and ground tabs for a couple hours this eve.  Made some progress there.  I modified the inner splash guard to be able to work with tail section installed. Also mocked up some gussets. Here is a rough of a scheme I have been playing with on the computer
with. .
« Last Edit: December 12, 2016, 09:15:43 PM by palepainter »
Offline palepainter
« Reply #86 on: December 12, 2016, 09:12:30 PM »
Can anyone tell me what this tab is for? The one next to the horn?
« Last Edit: December 12, 2016, 09:14:33 PM by palepainter »
Offline palepainter
« Reply #87 on: December 12, 2016, 09:43:16 PM »
One more version.  This time I lowered the fairing down a bit and modified the stripe through tank and fairing.
« Last Edit: December 13, 2016, 06:17:41 AM by palepainter »
Offline budman
  • 1914X
« Reply #88 on: December 13, 2016, 07:03:59 AM »
That looks cool.
Bud
2021 Indian Scout
« Reply #89 on: December 13, 2016, 07:06:03 AM »
That tab is not stock...
« Reply #90 on: December 13, 2016, 08:31:01 AM »
Early F 75 and 76 had a wiring junction box there.. Member yeaho is looking to buy one of them..
Offline palepainter
« Reply #91 on: December 13, 2016, 08:59:16 AM »
Thanks!  Is it something I will need in order to connect the stock wiring harness or can it be stuffed into back of headlight?
« Reply #92 on: December 13, 2016, 10:13:39 AM »
I haven't tried it but doubt it can be done. The pigtail coming from the stock main harness that enters the junction box is too short to reach the headlight and the F bucket is a little shallower than the K bucket. I also haven't tried using a 77/78 F harness either! Those do not have the junction box. Perhaps. I'd love to see you find an easy solution as I'd like to add an oil cooler to one of my F's and that's where I'd place it.
Offline palepainter
« Reply #93 on: December 13, 2016, 10:21:37 AM »
Thanks Mutha.  That was my worry.  It is an ugly unit.  I just may have to make a new harness to clean it all up with out it.  But if a later model harness is available, that is probably a way to go for an electrically challenged guy like me.
Even if the lines are long enough, there probably isn't enough room to stuff it all in the F headlight.   >:(
« Last Edit: December 13, 2016, 10:47:12 AM by palepainter »
« Reply #94 on: December 13, 2016, 10:25:32 AM »
I ran a Bates type light with stock harness doubled over a lot of the wiring bunch, and taped it. Tucked it under the stock tank.. Would pop out or hang down. I am sure you could hide most under there, and make a few longer wires to get where you need to go.  Be much easier if you trim some of the unneeded off the harness .
 I usually run bare clutch lever, a 70-72 right hand switch/throttle housing . That gives me Off, Low High for lights , kill switch, and starter button... I used that for the horn.
 If its a 75 76 harness , you may not want to cut it , get another...earlier has less fuses ,no clutch interlock..etc
« Reply #95 on: December 13, 2016, 11:01:55 AM »
This one looks really cool.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline budman
  • 1914X
« Reply #96 on: December 13, 2016, 02:51:55 PM »
...for an electrically challenged guy like me.
Just jump into the deep end like me.  If you can wire a guitar you can wire an old motorcycle.  I ditched all the Honda stuff and started from scratch.  I'm working on the wiring right now and everything is going well.  I've just got the handlebar switches left to do.  Everything seems to be working fine so far.  I won't know if the electronic ignition works yet until I try to start it, but I'm pretty confident I got it right.
Bud
2021 Indian Scout
Offline palepainter
« Reply #97 on: December 13, 2016, 03:16:51 PM »
There is so much bull in this wiring harness.  Cornfusing.  Even with the diagram.   :)  I have wired choppers all my life, breeze.  10ft of wiring and the bike was done.  But this little import has me wondering where to start.  Originally, I was going to run kick only and no turn signals.  But know, my old ass is thinking....electric start is nice.  ;D
Offline budman
  • 1914X
« Reply #98 on: December 13, 2016, 04:06:14 PM »
Yeah, I looked at all that and said "no way".  I can send you my diagram if you want.  I need to make a couple of updates to it first.
Bud
2021 Indian Scout
Offline palepainter
« Reply #99 on: December 13, 2016, 04:16:57 PM »
[/quote]
[/quote]
That would be interesting to look at.  You can send to my email palepainter@gmail.com  Thank you Sir!
