Author Topic: Palepainter's 750f project.. Al Fine'  (Read 62361 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: My first CB 750f project has started
« Reply #100 on: December 13, 2016, 04:06:14 PM »
...for an electrically challenged guy like me.
Just jump into the deep end like me.  If you can wire a guitar you can wire an old motorcycle.  I ditched all the Honda stuff and started from scratch.  I'm working on the wiring right now and everything is going well.  I've just got the handlebar switches left to do.  Everything seems to be working fine so far.  I won't know if the electronic ignition works yet until I try to start it, but I'm pretty confident I got it right.
There is so much bull in this wiring harness.  Cornfusing.  Even with the diagram.   :)  I have wired choppers all my life, breeze.  10ft of wiring and the bike was done.  But this little import has me wondering where to start.  Originally, I was going to run kick only and no turn signals.  But know, my old ass is thinking....electric start is nice.  ;D
Yeah, I looked at all that and said "no way".  I can send you my diagram if you want.  I need to make a couple of updates to it first.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #101 on: December 13, 2016, 04:16:57 PM »
[/quote]
[/quote]
That would be interesting to look at.  You can send to my email palepainter@gmail.com  Thank you Sir!
Offline budman
  • 1914X
« Reply #102 on: December 14, 2016, 10:12:55 AM »
Diagram sent.
Bud
2021 Indian Scout
Offline palepainter
« Reply #103 on: December 14, 2016, 10:42:52 AM »
Diagram sent.
Got it Bud.  Thanks a ton.  I going to give it a good look over this weekend.
Mike
Offline palepainter
« Reply #104 on: December 16, 2016, 05:07:43 PM »
Well, the welder went down again.  So in order to keep moving, the sand blasting has commenced.  There is a bunch of it.   I managed to get the rear caliper torn down.  Will need new seals and one piston.
« Last Edit: December 16, 2016, 05:50:27 PM by palepainter »
Offline palepainter
« Reply #105 on: December 16, 2016, 05:27:17 PM »
Rear caliper torn down and am cleaning up the castings.  Call me OCD.
« Reply #106 on: December 16, 2016, 05:39:10 PM »
Well, the welder went down again.  So I order to keep moving, the sand blasting has commenced.  There is a bunch of it.   I managed to get the rear caliper torn down.  Will need new seals and one piston.
SiriusConInc.com has a kit with both pistons and seals at a reasonable price
Offline palepainter
« Reply #107 on: December 16, 2016, 08:50:06 PM »
use this:
Thanks Calj, I seen that on chop cult.  I looks like a good place to start.
Offline palepainter
« Reply #108 on: December 17, 2016, 07:35:01 AM »
Thanks for that link Jerry!!!
Offline palepainter
« Reply #109 on: December 17, 2016, 03:14:05 PM »
The only way I have ever finished projects was to keep at it amidst stumbling blocks.  So since the welder is down, I went ahead with painting blasted parts.  Etch prime, base and clear.
Offline calj737
  • I refuse...
« Reply #110 on: December 18, 2016, 02:40:06 AM »
A gentle reminder; if you use the stock controls and handlebars, the metal needs clean metal-to-metal contact even at the top clamp bridge in order to maintain a good ground. So cleaning the underside of the idiot cluster and top clamp where the bars pass thru is recommended. It also insures a proper fit without too much coating build up.  :)
« Reply #111 on: December 18, 2016, 10:22:37 AM »
 Hope you got  soft jaws on order...
Offline palepainter
« Reply #112 on: December 18, 2016, 02:47:22 PM »
Today I met up with a local CB collector/builder.  Purchased a few items from him including neck bearing kit, oil pressure gauge, and updated fuse block.  This guy has it all, tons of stuff.  Man.....  I am sure he will be taking my money.  I found a set of wheels from 77 SS for my bike.  After pricing a bunch of different options for making the spoked wheels look decent, I pulled the trigger on these mag wheels.  I will be able to take them down and powercoat or paint them.  I will put the money saved somewhere more important.  I really like the look of the wheels on this bike.
Offline palepainter
« Reply #113 on: December 18, 2016, 02:50:46 PM »
Has anyone used this oil temp/ dipstick on their bike Supersport.  I was wondering if it fit under stock side cover?
Thanks.
« Reply #114 on: December 18, 2016, 04:25:31 PM »
Hold onto that rear SS hub.  Many people with spoked drum rears wanting to upgrade to a disc, and they can easily relace a wheel.
Offline budman
  • 1914X
« Reply #115 on: December 21, 2016, 09:47:28 AM »
What are the ping pong balls for?
Bud
2021 Indian Scout
Offline palepainter
« Reply #116 on: December 21, 2016, 10:30:10 AM »
Bud, they are to put into intake boots when I soda blast the motor.
Offline budman
  • 1914X
« Reply #117 on: December 21, 2016, 11:52:49 AM »
Clever.
Bud
2021 Indian Scout
Offline palepainter
« Reply #118 on: December 21, 2016, 12:30:16 PM »
Ping pong balls at work.
« Last Edit: December 21, 2016, 12:41:32 PM by palepainter »
Offline palepainter
« Reply #119 on: December 23, 2016, 10:26:03 AM »
I cut and drilled the gussets today.  The welder is back.  Taking some time between Christmas and New Years to finalize frame and get to blaster.
Offline palepainter
« Reply #120 on: December 23, 2016, 04:21:14 PM »
Can anyone confirm the year of this front caliper sitting in the beer tray?  75K?   The one that came with bike is shot.  I fired up my PM caliper to push out pistons.  Worked pretty slick.
« Last Edit: December 23, 2016, 04:43:53 PM by palepainter »
« Reply #121 on: December 23, 2016, 05:53:54 PM »
 Caliper is 73-76 if it came on that bracket..
 Your gussets look like they may be quite thick... If they are more than 1/16 ” thick, they are just extra weight...plus there is a tendency for vibrations to concentrate near the bracket if you use overly thick material.      Plus its harder to bell the holes..
Offline palepainter
« Reply #122 on: December 23, 2016, 07:06:23 PM »
Yup.  Those came on that bracket.   Thanks, now I know what rebuild kit to get.   .110 is the plate thickness.
Offline Godffery
  • Godffery's Garage
« Reply #123 on: December 24, 2016, 11:46:42 AM »
 Looking pretty interesting Man,
I could help with those Brake components if you'd like:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/
Offline palepainter
« Reply #124 on: December 24, 2016, 04:29:09 PM »
Thank you for the link.  I will keep your services in mind.   This afternoon  I made the spacer between the tank and tail section.  .080 aluminum with flanged holes.  My wife calls it the nut cooler panel.
« Last Edit: December 24, 2016, 05:10:08 PM by palepainter »
