Author Topic: 350f cam chain: what is it supposed to sound like?  (Read 3495 times)
Offline Dos
  • Owner of a cb350f
« on: November 10, 2016, 09:26:33 AM »
Hey all,
I have one of those finicky cam chain tensioners on my 350f.
I know how to tension and everything but I was wondering if this sounds right.
When I start the bike the chain slaps but after it warms up it goes away. This is okay right?
The other thing is when I am riding I hear like a slight grinding sound. I don't know how to describe it something like dragging cents across the floor.
I didn't know if this is normal I figure its my chain just sliding past the internal metal. The chain isn't making that slapping sound at high speeds but it's just a slight sound like described before like if you took your keys and just slide them across a metal surface.. Ill try and post a vid with good audio.
Re: 350f cam chain: what is it supposed to sound like?
« Reply #1 on: November 10, 2016, 10:20:17 AM »
It might be hard for us to differentiate between cam chain and valve train noise.
Help us out and take your video in a location where there is no white noise/breeze that can introduce other sounds.
10-15 seconds of (very still) idling sound at say 12'.  Again at 3'-4'.   Repeat the closer sound bite with a slow increase of rpm to 3000
Yes, there will be metal on metal sound.  Only a thin layer of oil separates these moving parts.
Offline Dos
  • Owner of a cb350f
« Reply #2 on: November 10, 2016, 10:26:03 AM »
Thank you I appreciate it. Just took it for alittle ride to warm up, video uploading now.
While doing a warm up I checked my oil on the side of the road and saw all this cream on the back end of the dip stick. When I looked in the engine there seemed to be a whitish coating as well .
Normal right? Video on its way
Offline Dos
  • Owner of a cb350f
« Reply #3 on: November 10, 2016, 10:27:12 AM »
Here's the vid. Took it before your instructions I'll film again back at the garage
« Reply #4 on: November 10, 2016, 10:38:22 AM »
The 'mayonnaise' on your dip stick is a sign of water in your oil.
Ride.  Complete oil/filter change with fresh oil.  NOW!
Cam chain noise might change after this is done.
Offline b52bombardier1
« Reply #5 on: November 10, 2016, 10:54:47 AM »
Ughhhh. He's right. You have water in your oil. That gray stuff is an emulsion mix of water and oil. And water is a HORRIBLE lubricant.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline Dos
  • Owner of a cb350f
« Reply #6 on: November 10, 2016, 10:56:19 AM »
Here is the new video
Hmm that's weird I wonder how water got in there.ive got a weepy head gasket that's a about it..Can I burn away the h20?
Sucks to have to buy all new oil and order a filter but I guess I'll do it..
« Last Edit: November 10, 2016, 11:01:58 AM by Dos »
Offline Dos
  • Owner of a cb350f
« Reply #7 on: November 10, 2016, 10:59:45 AM »
I've been riding for awhile with that so I hope that doesn't screw anything up .I'm using 20w50 valvoline conventional motorcycle oil so hopefully a new dose in this cold will do it well
« Reply #8 on: November 10, 2016, 11:08:58 AM »
I'm sure you haven't been washing your bike with the dipstick out  ;D That mayo can be from too many short rides/idle sessions.
The only way to keep it out is to ride long enough to burn it out.
Add some MMO or Marine stabil to your current oil.  Go for a 30 minute ride, then drain it all while its hot.
Top it off w new, and go from there.
Offline Dos
  • Owner of a cb350f
« Reply #9 on: November 10, 2016, 11:12:45 AM »
Could it be that yesterday I left the bike in the rain and this is condensation and such? And that this is temporary? I'll accept the facts but I'm just curious I store the bike in an open air garage so it just has a roof and wind can come in the front and sides. Will I always be at risk of getting water in there then? I ride the bike for about 15-20 minutes to the opposite end of town twice a day for work and they are considered short rides I guess
I'll deal with the oil water issue but how did the engine/cam sound
« Reply #10 on: November 10, 2016, 11:14:42 AM »
all that vapor out the vent is another indicator of water in your oil.  If you do an oil change, and the mayo comes back then it is a result of your storage area/short riding time.
sounds good at idle, but yeah...that noise really kicks in when you're on the throttle.
Still, i'd do an oil change asap, and go from there.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=caq3mekhj6r5nafj2jbavacsb7&/topic,60973.0.html
« Reply #11 on: November 10, 2016, 11:27:00 AM »
its the caburettors vho not are syncroed perfekt..it makes the firings of etch cylender not give  the same power autput..this make the engine hammer up and back as the pistone take/make speed thanges..as the firing hits the veaker cylenders...so it bangs and make the cam thain slack and teighten as the engine run..hammer the back slatch in the chain drive back and forth..real bad for the engine...its like a engine are not balanced..make vibrasions ..
i hate all this v-w.... vords
Offline markreimer
« Reply #12 on: November 10, 2016, 11:51:22 AM »
My 350f and 750 sound like a kitchen drawer being dumped on the ground. There is lots going in there, it will sound noisy! Even after a rebuild with new tensioners etc it's loud.
I also ALWAYS have that white stuff on my dipstick in cold weather after short rides. Condensation builds up over night and that's why you see the mayonnaise. If you ride long enough it's all burned off pretty quickly. But shorter rides where the oil isn't at full operating temp for a descent amount of time will not get rid of it. I get this the day after an oil change even. It's not water leaking into the oil system.
Offline Dos
  • Owner of a cb350f
« Reply #13 on: November 10, 2016, 12:54:29 PM »
Yeah I take it on short rides and today was the first time doing a long ride.
I will take it that this is temporary and ride it for 30mins  and burn it out.
This is the first time I've seen this so if it doesn't go away then I'll change oil and such.
I couldn't understand too much about the carbs being synced but I feel my carbs do need some syncing and I've done it before but I guess inhavent gotten it right. The bike does vibrate more. Should I just leave everything be and adjust the cam tensioner?
Offline pjlogue
« Reply #14 on: November 10, 2016, 12:59:06 PM »
 Part is from the breather and most is probably from combustion.  Water vapor is a byproduct of combustion.  If your rings are worn/not seated you will get a lot of blow by and it will make the oil-water froth worse.
-P.
Offline markreimer
« Reply #15 on: November 10, 2016, 03:35:55 PM »
-P.
Interesting, didn't know that. I had very worn cylinders and recently bored to 2nd over with new rings. I still get the white junk but only on short rides. My commute is only 5km so it's nowhere close to operating temp, and it's dipping below freezing overnight. I find a layer of ice on my seat in the morning hah! I try not to ride such short jaunts too often
A good hour long highway ride will burn all that moisture off.
Offline Dos
  • Owner of a cb350f
« Reply #16 on: November 10, 2016, 06:05:58 PM »
Thanks for the help everyone!
sort of went off topic haha but I greatly appreciate!
In regards to the cam chain it is definitely grinding so I am going to do a proper carb sync and then see what happens
Offline Dos
  • Owner of a cb350f
« Reply #17 on: November 13, 2016, 02:09:23 PM »
Update: went around the block a couple of times and no more mayonnaise. However got white smoke coming out of breather.
« Reply #18 on: November 13, 2016, 02:52:07 PM »
Around the block a few times isnt hot enough.  How about 30+ miles....
Offline Dos
  • Owner of a cb350f
« Reply #19 on: November 13, 2016, 04:51:41 PM »
I also synced the carbs with no fan ;D
Offline Dos
  • Owner of a cb350f
« Reply #20 on: November 17, 2016, 10:26:48 AM »
Hey fly box,
in regards to the cam chain grinding, it is still there even after a carb sync.
I loosened the cam chain adjuster and it seems that the grinding goes away at high speeds but that classic cam chain slapping is there at low speed and idle.
Don't know what to do with this one.
When I push down on the tensioner the slapping goes away but I hear that grinding come along.
« Reply #21 on: November 17, 2016, 10:34:25 AM »
I would deduce that the tensioner is near its wear limits.
IIWM, id say fukc it....get the A/F mixture through the throttle range as good as you can, and ride it.
Wait till the rains/cold come and do a tear down to replace the tensioner unit, do a mild hone/re-ring and top-end refresh.
Be ready for next riding season.
Offline strynboen
« Reply #22 on: November 17, 2016, 10:46:58 AM »
on mine 400 four..i cant get the music aut..have made a direkt adjuster to press direkt at the horseshue..but still have some scrambel ..so think i need new thains..both the cam and the main thain...to the clutch shaft.
..think to take the engine aut and turn it up Down..and go inn from bottom..hope to safe the new head gasket...i mounted this summer
Offline camshaft1991
« Reply #23 on: November 17, 2016, 10:51:30 AM »
Hey,  have you adjusted or fiddled with your valve clearance? If so check them again for clearance and see if the the tappet nuts are loose. If you take one of those eight caps off the cylinder head cover, you would see a nut. If you didn't adjust your valve gap,  disregard what I have to say. l one time adjusted my valves and I  didn't tighten one all the way after adjusting for gap and it came loose when I was riding. It sounded worse than yours in that second video.  I had to replace one of my rockers and my camshaft. Again,  I'm not saying you have the same problem. There are tons of other things that could be related to your idle issues
« Reply #24 on: November 17, 2016, 10:59:50 AM »
If you do find a loose tappet screw check to see if the bottom of the valve tappet cover is chipped or hit.
