Hi Guys,
I know there's plenty of threads regarding this, but to put it simply I must be stupid because I still dont have a damn clue how to adjust my clutch correctly.
Story so far...
The bike has been rebuilt.
Its nearly all back together apart from installing my new clutch cable and adjusting accordingly.
Current Situation...
The new cable has not been installed onto the bike as of yet, from what I've read up on, I need to adjust the nut/screw on the clutch housing to line up the clutch arm dots???
Pics below to show where I am.
My questions...
1. Should the dots line up without the cable on?
2. when I loosen the lock nut and turn the screw what happens? or what should happen?
3. What are the steps to install and adjust the clutch correctly?
With the cable off I loosened the lock nut and slightly turned the screw to see if it moved the arm at all...nothing happened? is that correct?
Any help would be much appreciated, Im at the finishing line and this is the last main task.
Many Thanks, Fraser
