Author Topic: Timing chain question  (Read 1699 times)
Offline dcooksey001
« on: November 19, 2016, 05:03:43 AM »
Long story short; need to install a new timing chain.  Ordered the chain and a master link,  but the master link posts(for lack of a better word)  are a bit smaller than the chains posts(the shafts that go across connecting the sides of the chain)  k&l says this is the right master link but I'm wondering if this will become a problem?  Should I just crack the case and do complete rebuild?
Sent from my SM-S902L using Tapatalk
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=frannajb7iska3l2288tv22h30&/topic,60973.0.html
Re: Timing chain question
« Reply #1 on: November 19, 2016, 08:58:43 AM »
the chaim is a heavy duty thain vith bigger side valls..and the link are a standart round egdet..it vill look smaller.
..often the heavy thains are endless..so theu dont offer a lose link to that type..but i think the normal link vill Work..but better to find one vho fits perfekt..you dont vant to build a veak link inn..then tha ekstra sekurity from the ekstra strong thain, are lost
is it a 750 ???...
i hate all this v-w.... vords
Offline dcooksey001
« Reply #2 on: November 19, 2016, 09:28:34 AM »
I ended up using the new chain from k&l there is a slight difference in the shanks that make the replacement chain a bit bigger so that the master link wouldn't work on the old chain.  Now to fish it through and time it lol.  Wish me luck kind of stabbing in the dark on this one (first bike build)
Offline dcooksey001
« Reply #3 on: November 19, 2016, 09:29:02 AM »
BTW it's a 500
Offline strynboen
« Reply #4 on: November 19, 2016, 09:48:35 AM »
then i have some bonus info for you..alvays thek the tensioner bars for vear..spicily the adjustabel one...and be shure it fits in the groove in the bottom..its easy to do vrong..best is to take the oil sump off..and klean it at the same time..and thek the tensioner bar have fitted korrekt in the small groove..it can be seen klerly dovn up..
« Last Edit: November 19, 2016, 09:52:07 AM by strynboen »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: November 19, 2016, 10:41:21 AM »
So you were wanting to use the new master link on the old, existing chain? Sounds like an apples to oranges comparison to me. Use the new master link to temporarily connect the old chain to the new chain and rotate the new chain into place.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dcooksey001
« Reply #6 on: November 19, 2016, 10:44:16 AM »
I was going to do it that way but the master link wouldn't fit into the old chain lol.  And on the further down side my 7yo wanted to help and just pulled the old chain completely out
« Reply #7 on: November 19, 2016, 12:13:46 PM »
Tie new chain and old chain together with steel wire?
 Something that hold them together when rotating and replace the old chain with new. I have never done that but it must be possible.
Offline dcooksey001
« Reply #8 on: November 19, 2016, 12:15:11 PM »
Yeah my bud is coming over to help me brainstorm lol
Offline strynboen
« Reply #9 on: November 20, 2016, 03:04:36 AM »
open to the oil sump..then you can get the thain araund the crankshaft...and get it up to the head..use some steel vire or copper vire to pull it.like sveden says.but it need some help to get araund in the bottom
