Author Topic: CB750 people - Does your bike leak?  (Read 7244 times)
Offline SKTP
« on: November 18, 2016, 10:18:19 AM »
Does you bike leak? If so, how much and from where?
Mine currently leaks from the head-gasket and I think from one of the oil line connectors.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: CB750 people - Does your bike leak?
« Reply #1 on: November 18, 2016, 10:21:54 AM »
Does the pope #$%* in the woods? Does a bear wear a funny hat? It pretty much leaks from most of the possible places where I did not change the oil seals on.
« Reply #2 on: November 18, 2016, 10:32:46 AM »
Does you bike leak?
No.  Not after my rebuild.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=bohf4cuch7p0t1g7b61fo9nue4&/topic,60973.0.html
« Reply #3 on: November 18, 2016, 10:38:59 AM »
i dont have a 750...so no...my 750 dont leak....but my 550 does..and the 400 and the cbx..and my mz..all my 40 years old bikes leak a bit
i hate all this v-w.... vords
Offline lrutt
« Reply #4 on: November 18, 2016, 10:43:33 AM »
Just a tad at the head gasket, but then they are all original and never been apart.
Offline pjlogue
« Reply #5 on: November 18, 2016, 10:46:35 AM »
After rebuild I had the oil line leaking and the oil pan drain plug leak.  Put new crush washer on oil drain plug and replaced the oil lines.  I figured the oil lines must have cracked when I stripped down the bike for a full reconditioning.  Old lines were very stiff.  Now, not a drop on floor anywhere!  :)
The hallmarks of the Japanese bikes of the 70's was they didn't leak like the AMF Harleys or the Triumphs.  The running joke in the 70's was the Harleys and Triumphs carried their "oil pans" and placed them underneath when they parked it.
-P.
« Reply #6 on: November 18, 2016, 10:53:32 AM »
CB750 and leak from head gasket area is standard and have always been. Oil from one place will spread all over the head and more when driving, the wind and heat will make the oil to float, impregnate everything.
Thanks to this forum and all combined knowledge from all members and bike experts that worked with the bikes from the very beginning we know what to do and not. The CB750 can be bone dry.
-Oil leak under rubber coins under the cam holders. Make sure that the rubber coins are fresh and seal them with non hardening sealer.
- cam studs: They must not be removed or coming loose. If they have, new thread inserts like time-sert that are glued with loctite 272, stud sealed with teflon high temp thread sealer.
- Gasket under valve cover OK, no oil leak thru bolts keeping the cover.. EDIT: forgot the breather cover on valve cover. All 3 bolts need to be tightened and good o-ring. oil will leak from here otherwise. I had one leak when driving , front bolt not tightened at all
- Tacho connection to valve cover, typical place from where oil is weeping. Remove cover and replace the oil seal, do not press it in too hard. Do not use a screwdriver from outside when removing the old one. The cover can crack and alu parts falling in beside cam and rocker arms between 3-4. (How do I know????)
Head gasket: MLS, Multi layer steel (mounted dry) does not require another tightening after 500km. The rivets must be hammered flat to not interfere with the mating surfaces. I drilled small dents on my head and cyl block where rivets are located with 8-10mm drill. That gasket need only 2 o-rings for oil feed around the inner 2 studs on inlet side.
MLS need a good surface. I made my blick and head good on the kitchen table. First grit 240 paper, later 400 when all scratches were gone.
I'll fine tune my head again to remove some small scratches happened the last 2 seasons head liftings. Case surface to cyl block too.
Photos when I fixed head and block 2012 when repairing/restoring the engine. later the entire bike..project never stops... :D
« Last Edit: November 18, 2016, 11:00:18 AM by PeWe »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #7 on: November 18, 2016, 11:03:20 AM »
 8)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #8 on: November 18, 2016, 11:16:16 AM »
Not since my top end rebuild following: http://forums.sohc4.net/index.php?topic=107040.0
Lately though, yes it is leaking around the oil pressure switch. Need to snug it up I guess.
--Evan
1975 CB750K "Rhonda"
« Reply #9 on: November 18, 2016, 11:35:01 AM »
 Sometimes the oil from a leak will still show up after the leak is fixed. My last one was where the wires leave the dyno cover. It was self inflicted. My brothers bike leaks down from the oil tank and runs out on the sidestand. I suspect the countershaft seal and of course the oil pump seal.
« Reply #10 on: November 18, 2016, 11:36:09 AM »
I forgot thr cam chain tensioner housing. Bad gasket and maybe bad threads on any of the 3 bolts will cause a leak.
If engine is taken apart, case opened and wrong sealer used will leak a little. I had bad experience with Hylomar blue. Hermetite Golden was really good, Hondabond almost like that one. Most of the other covers do not need additional sealer. This (Hondabond) will make PITA when removing the cover, replacing the gasket.
Oil seal not correctly mounted on crank on igniotion side... here a little bit sealer, avoid oil hole.
oil seal for kickstarter shaft and gear shifter must be OK. Bike fallen and genefrator cover scratch can get a hole and leak. JB weld can fix that.
« Last Edit: November 19, 2016, 12:24:53 PM by PeWe »
« Reply #11 on: November 18, 2016, 06:07:06 PM »
350 cubic inch small block chevy v8 at 5000 rpm?...about 40-60psi of oil pressure  736cc sohc honda at 5000 rpm?...at least 70psi of oil pressure
Yeah, you might get some leaks.
« Reply #12 on: November 18, 2016, 08:05:05 PM »
....not a drop
Offline markreimer
« Reply #13 on: November 18, 2016, 09:42:57 PM »
Nope. Did a bad valve cover gasket installation once and it leaked right away, cleaned it up and new gasket and it was gone.
Offline CB_Jeff
« Reply #14 on: November 19, 2016, 03:54:11 AM »
My F3 leaks at the head as some of the pucks have failed.  More of a weep actually.  Not quite bad enough to pull the engine immediately, but I will need to do it one of these days.  The unfortunate part is the engine is otherwise tight and runs strong, so the engine needs to come out for $20 worth or of pucks.
Offline Bailgang
  • Scott
  • Indiana
« Reply #15 on: November 19, 2016, 05:03:25 AM »
When rebuilding my F2 I used an aftermarket gasket set and seals however I pitched the o-rings that came with the gasket set and used viton o-rings wherever I could instead and it still leaked at the head but that turned out to be the cheap pucks. I replaced those pucks with genuine honda pucks and top end of engine has been leak free for about 3 years now however it STILL has a pesky oil leak around the oil pan.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline CycleRanger
  • No comment about being an
« Reply #16 on: November 19, 2016, 05:37:39 AM »
Yep, I have the same leaky puck issue with my K5. It started slow but steadily got worse until now I need to take action.
Offline turkey4me
  • The closer you are the less you can see!
« Reply #17 on: November 19, 2016, 06:25:36 AM »
8 years ago when I got bitten by the sohc bug, my 750 leaked voltage, fork oil, engine oil, compression, and fuel from the fiberglass tank.  Thanks to all your help, now it only leaks fuel when I leave the petcock open.
« Reply #18 on: November 19, 2016, 12:44:14 PM »
Maybe missing alu washers in the oil hose connections?
I hade one leak when I did not tighten the upper oil connection to tank properly. I used used a waterpump plier that squeezed the nut tight and not tighten completely, washers did not seal. Used a spanner, 27mm and tighten correctly. No more leaks. Oil hose was of SS braided type so it needed high pressure cleaning from oil in it.
Another time was leak from Clutch cover, gasket was not properly aligned so one dowel pin jammed with gasket and not possible to tighten bolts, cover not completely tightened and squeezing the gasket. Oil flowed rarher good.
Dripping oil under engine can be the drive chain lubrication. Tighten the bolt/nut insode the front sprocket completely or repace it with a bolt with o-ring.
« Last Edit: November 19, 2016, 01:28:09 PM by PeWe »
« Reply #19 on: November 19, 2016, 02:27:29 PM »
Pewe..kudos on showing the hand sand glass plate method so well..
I am a fan of taking off minimal amounts.
Usually though, if space permits, i use a figure eight motion.
Hard part is finding big sandpaper...or making smaller sheets work without tearing.
Offline greenjeans
  • 1972 CB750K2
« Reply #20 on: November 22, 2016, 05:44:55 AM »
Mine are dry as a bone.   Recently started using the CycleX MLS gaskets.  Big fan.
Offline 72 yellow
« Reply #21 on: November 22, 2016, 03:09:59 PM »
A little weeping around the head gasket, but the engine has never been apart.  Anything else I blame on the BSA parked next to it.   ;D
