Author Topic: Are these still good?  (Read 3179 times)
Offline txterror
« on: November 21, 2016, 07:25:20 PM »
Hi guys it's been a loooonnnngggg time since I've posted. But need y'alls opinion on these brake pads. Are these still good? Need a new tube, so figured while the tire is off, might as well check the brakes. Appreciate yalls time/experience.
Bike has been lonely in the garage way too long, reason why I haven't posted in so long. Buddy got a fancy Harley, and wants to ride. Motivated me to get her out in the sun.
1975 cb400f
Re: Are these still good?
« Reply #1 on: November 21, 2016, 08:10:14 PM »
 they just look dirty, if there's any white corrosion between the backing and the friction material toss them. I've seen the friction  lining come off.
Offline txterror
« Reply #2 on: November 21, 2016, 10:17:42 PM »
If replacing, should I just get genuine Honda or are there better options worth paying for?
1975 cb400f
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: November 22, 2016, 04:44:40 AM »
The linings look okay, but as Don mentioned, with age they can separate from the shoe. Pads are cheap insurance if you do not know the age of the linings then might be best to replace. Even aftermarket brakes would perform better than linings that separate from their shoe.  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: November 22, 2016, 07:09:05 AM »
Buy new........
« Reply #5 on: November 22, 2016, 07:10:58 AM »
Your brakes. Your life.
I'd replace.
    • http://forums.sohc4.net/index.php?PHPSESSID=vm7i7fgpq1tqscj6d200q64vi0&/topic,60973.0.html
« Reply #6 on: November 22, 2016, 07:40:39 AM »
they are fine. just vash and re use
.but your floor is crached serios
you have this indikations for Wear..on the brake lever..just thek them..think there is used the half of the material..so 40 years left to use..before hit the limit
thek for korosion../ for loosen brake material
hov is the hub looking..mine had korosion ,,vho cracked the hub..so the cast iron surface vas badly cracked
« Last Edit: November 22, 2016, 07:47:41 AM by strynboen »
Offline Bodi
« Reply #7 on: November 22, 2016, 08:17:03 AM »
Barely broken in. Good to go. Just clean - look for any grease contamination and clean with acetone if you see any dark spots. Wash the linings with acetone as well. A scrape with medium wet/dry paper won't hurt the linings either.
If this is a high-mileage bike, the rider knew how to brake properly. I've seen rear linings worn to the backing because the front brake is too "scary" to EVER use.
Offline txterror
« Reply #8 on: November 22, 2016, 09:27:30 AM »
Thanks guys. Still a little confused though, some say replace while others say still good. They seem to still have quite a bit of meat left.
1975 cb400f
Offline 540nova
« Reply #9 on: November 22, 2016, 09:33:24 AM »
The issue isn't usable brake material, but that some have been known to come unbound from the shoe. Pretty unlikely, but your call.
« Reply #10 on: November 22, 2016, 09:50:21 AM »
Do you know how old they are? If they are original pads (over 40 years old) and if the lining separates from the shoe under high speed braking and locks up the rear wheel and you go down on asphalt, you just have to ask yourself...
how much meat will be left on your bones when you stop sliding?
Original Honda shoes are less than $40: http://www.hondapartsnation.com/oemparts/p/honda/06430-393-405/shoe-kit-brake
Aftermarket shoes (Vintage CB750 Part #: 29-3121) can be had for less than $25 (scroll down): http://www.vintagecb750.com/products/2/chassis-brakes/39/brakes-brake-hose
The age of the shoes would be my only concern. If the previous owner replaced them within the last 10 years or so (provided the bike was not stored outside, exposed to the elements) then you would probably be fine.
Otherwise, new shoes are cheap insurance. I've got enough to worry about as far as "cagers" trying to run me over without flinging myself down on the asphalt as a result of a failed brake shoe locking up the rear wheel. Sure, you could use them, there is indeed plenty of pad left on the shoe, and they might work well until they are worn to their service limit without any issues, and you could replace them then. I've used old shoes without issue (back when I was younger... and invincible), but I've also had old shoes sitting on the shelf that had the linings fall off. Ultimately it's your hide and your decision to make.  :-\
« Last Edit: November 22, 2016, 09:52:06 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #11 on: November 22, 2016, 10:10:08 AM »
^yes.
We put a lot of faith in old shiit here.
New pads/brake lines are no-brainers.  I liken it to original tires with good tread (but cracked and hard as a rock).
Small change in the grand scheme of things.
Offline txterror
« Reply #12 on: November 22, 2016, 11:01:14 AM »
alrighty, looks like ill be ordering new shoes. Do you guys recommend genuine honda shoes or should i look at some after market shoes (any recommendations)? I appreciate yalls time/opinions. Also looks like ill be ordering a new tire as well. Took wheel to tire shop to replace tube an guy said i need a new tire. Any recommendations on tires as well?
1975 cb400f
« Reply #13 on: November 22, 2016, 11:14:37 AM »
Wise move. How old are your tires? The date code is easy to read once you've read them a few times:
http://www.tirebuyer.com/education/how-to-determine-the-age-of-your-tires
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
As for tires, you will get many opinions. In my opinion, the cheapest new tire will outperform any 40 year-old tire, and in many cases will perform better than the old tire, even when that old tire was new. I will save a little on tires but I do try to splurge a little on a better quality tube (i.e. not the cheapest tube I can find).
TAMTF...
Wilbur
Projects:
Offline nicks2319
  • Youngstown, OH
« Reply #14 on: November 22, 2016, 11:18:04 AM »
If you have to ask with those rear shoes, replace them. I thought mine looked fine too until they broke apart and locked my rear wheel going about 40. Went sideways and somehow didn't go down. Scared the hell out of me.
« Last Edit: December 13, 2016, 05:15:08 PM by nicks2319 »
Offline txterror
« Reply #15 on: November 22, 2016, 11:21:05 AM »
dang nick! glad to hear you were able to keep it up right.
and Madmtn, not sure how old the tires are. bought the bike in 2012 and still has the same tires, they are not originals. Also not sure how old the pads are.
1975 cb400f
Offline txterror
« Reply #16 on: November 22, 2016, 11:33:42 AM »
tire say 5010
1975 cb400f
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #17 on: November 22, 2016, 11:49:48 AM »
Like Stryn said let the wear indicator on the brake arm be the judge but if you think they are original I say replace.
« Reply #18 on: November 22, 2016, 11:53:47 AM »
tire say 5010
That would be the "50"th week of 2010, so they were manufactured in November of 2010. Six years old, which is a reasonable age to consider retiring them. I've run older tires, but I was younger and invincible then too!
TAMTF...
Wilbur
Projects:
« Reply #19 on: November 22, 2016, 11:58:25 AM »
Holy cow Nick! Is the lining missing from the other shoe? Is that what caused the lock up?
As for Honda shoes or aftermarket shoes, I've used both with success. Nick's shoes pictured above appear to be genuine Honda, but likely very old.
TAMTF...
Wilbur
Projects:
Offline txterror
« Reply #20 on: November 22, 2016, 11:59:22 AM »
Any recommendations for shoes and tires guys?
1975 cb400f
Offline nicks2319
  • Youngstown, OH
« Reply #21 on: November 22, 2016, 12:04:44 PM »
Yeah, I think so. Lining is missing and somehow it caused the big crack. Wheel was totally locked up.
« Last Edit: December 13, 2016, 05:15:31 PM by nicks2319 »
Offline txterror
« Reply #22 on: November 22, 2016, 12:08:06 PM »
what lining are you guys talking about?
1975 cb400f
« Reply #23 on: November 22, 2016, 12:10:47 PM »
The outer friction lining that is bonded to the metal shoe. The friction surface (lining) separated from one of Nick's brake shoes and got wedged between the other shoe and the drum causing the lock up he described. I knew it was possible, I've just never experienced first hand thank goodness!
It looks like pieces of the friction "lining" still laying inside the hub in Nick's picture.
TAMTF...
Wilbur
Projects:
Offline greenjeans
  • 1972 CB750K2
« Reply #24 on: November 22, 2016, 12:30:33 PM »
I've had 2 sets of 40 year old shoes separate on me over the years.   Those are now on my "replace immediately" check list.
