Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Three different bolts and nut that don't seem Honda. They are all also 11mm head.
Well yeah, the bolts heads are 7/16. The other nuts were various types (nylon locking, non-locking, flanged nuts, etc...). All of these fasteners were removed with an 11mm socket. But yes sir, you're correct.
I might just scrap this head.
This engine will be exactly that. K8 - cases, crank, rods, transK2 - cylinders, cam, cam towers, camy followers, chrome coversF1 - 392 headI will make it all work...
Quote from: JoeCooley on January 20, 2017, 05:57:24 amThis engine will be exactly that. K8 - cases, crank, rods, transK2 - cylinders, cam, cam towers, camy followers, chrome coversF1 - 392 headI will make it all work...No adjustments required for that recipe, everything should fit together without drama. The bike I'm racing now had some similar issues as yours, in that there were a number of bolts missing and some were broken.Runs good now though!
Such a better ride than that Enfield.
