Author Topic: K8 Highway Racer - Finished  (Read 30151 times)
Offline JoeCooley
  • Long time lurker, but now I'm a
Re: CB750 K8 Highway Racer - Updates
« Reply #100 on: December 27, 2017, 09:11:30 PM »
Well my stickers came in from France. The shocks look much nicer now. Finally finished with that part of the build.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline JoeCooley
« Reply #101 on: December 30, 2017, 09:27:00 PM »
Tarozzi rear-sets DONE! The brake side was a pita! 😲
If this doesn't work out I'm just going to get a cable setup.
Next up: Clutch replacement and modification as per Mr. Hondaman.
Happy Year everyone!
-Joe
Online seanbarney41
« Reply #102 on: December 30, 2017, 10:26:16 PM »
you got that set up really weird...does it work good?  Here is mine, works good...
DSCN0944 by Sean Barney, on Flickr
« Last Edit: December 30, 2017, 10:30:41 PM by seanbarney41 »
Offline JoeCooley
« Reply #103 on: December 30, 2017, 10:43:58 PM »
Yes it works well. It took a lot of trial and error to make it all fit and work correctly. I have a K8 so the bolt on kits don't work. Also, I can't  go above like you did because the rod will hit the swing-arm nut. Luckily Cognito Moto sells brackets and other bits to make it happen. I may shorten the lever a bit to make packaging easier and clean it up a bit.
Offline JoeCooley
« Reply #104 on: December 31, 2017, 12:07:53 PM »
New clutch time! I've had these parts for like a year.... Finally get to it...
« Last Edit: December 31, 2017, 12:09:34 PM by JoeCooley »
Offline JoeCooley
« Reply #105 on: January 03, 2018, 08:01:02 PM »
Some new parts showed up...
Offline BPellerine
Re: K8 Highway Racer - Nobody cares? 🤔
« Reply #106 on: January 04, 2018, 10:10:16 AM »
some good parts,I have one of those cams,havent tried it yet,but it kissed the pistons in a stock engine,maybe contact cyclex about milling the pistons down?
1978 CB 750K ard and webers
another anfob
Offline JoeCooley
« Reply #107 on: January 04, 2018, 10:23:32 AM »
Do you know any of the specs for the cam? I can't find anything on Google.
The valve reliefs are huge on these pistons. I doubt I will have any contact.
Yes, I should contact them. Maybe they will know how much I should take off it I want to lower the scr.
Offline BPellerine
« Reply #108 on: January 04, 2018, 06:07:00 PM »
some guy on here contacted crane cams and got the specs for one of there other cams maybe they can supply you with info,I was not thinking you would have contact with those pistons,just knew it had a little too much lift for stock pistons,hope you can get the cr down.
another anfob
Offline JoeCooley
Re: K8 Highway Racer - Updates!
« Reply #109 on: January 12, 2018, 07:39:18 PM »
I contacted Crane's tech line. They said they will research it for me and email if they found anything... A week later and no word... So yeah.
On a positive note, I'm almost done with the rewire and new bar controls. I fired it up on starting fluid! So I know the coils are working and most of the bike is wired correctly. I went to a K1 harness and minimalist early style bar controls. Everything works except the signals. I think it's a simple fix but who knows. I have to probe the switch and check for power and see if it is even functioning. It's a cheap repop.
Also, some of new go fast parts showed up. So far I have the pistons, crane cam, CX Super rods, RC red retainers, and some stock rocker parts. Thinking about sending my gears off to be undercut.
Offline JoeCooley
« Reply #110 on: January 16, 2018, 01:06:59 PM »
Check if your harness has the signal power being supplied from the TURN SIGNAL RELAY. On many models (I don't know the K8 well) power comes to the LH pod on GREY.
I found the problem! It was just a missing spring on the little contact in the switch which I forgot to put in on reassembly. Stupid mistake that cost me an hour of diag to find. Oh well, it's good now. Haha
So Phase ll is nearing an end. The bike is looking much better now and everything seems to work electrically. I can't wait to ride this thing and see how she handles. 👍😎
« Last Edit: January 16, 2018, 04:38:42 PM by JoeCooley »
Offline SKTP
« Reply #111 on: January 16, 2018, 01:20:57 PM »
Looking good! What Wiseco pistons did you go with (assuming you have a 1978K head)? I am thinking of getting Wiseco 863cc pistons and and trying to figure out if the 78K uses the F style of the 69-76K style...I think F, but I need to do more research
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #112 on: January 16, 2018, 02:13:32 PM »
Looks fantastic!
Offline JoeCooley
« Reply #113 on: January 16, 2018, 04:48:53 PM »
Thank you. My current build is a bit of a mutt. CruzinImage flat top 65mm pistons, 72k cylinders, 72k cam, 75 F1 Head, Kimble white springs. I had 3 angle valve job done and springs & seals replaced.
The 78k Head is supposed to be similar to the F1 head. The F2 got the change in combustion chambers. I have my old 78K head laying around and it looks pretty much like the F1.
Looks fantastic!
Thank you Stev-o! It means a lot coming from you. Your bikes are all very nice. This bike isn't perfect in any way. It does however remind me of a track worn 70s racer with modern updates... That's kinda the look I'm going for....
Cheers Guys!
« Reply #114 on: January 16, 2018, 08:04:20 PM »
Looks good, Joe.  Ride it like you stole it!
Offline JoeCooley
« Reply #115 on: January 16, 2018, 09:22:32 PM »
Thanks Don! Oh, I plan to ride $hit out it!!!
Seat pan is started. Just taped it up with packing tape and masking tape. I might lay the first layer of glass tonight. Kinda tired tho and I have to be up at 0500...
« Last Edit: January 16, 2018, 09:29:10 PM by JoeCooley »
Offline JoeCooley
« Reply #116 on: January 20, 2018, 10:39:56 PM »
I spent today laying fiberglass. I have 5 layers of woven fiberglass. I will pop the mold tomorrow and clean it up. It should be good and strong.
Offline JoeCooley
« Reply #117 on: January 31, 2018, 10:18:04 PM »
Ok so the seat pan is done. I finished trimming it and dropped it off at an upholstery shop today. It's going to cost a little more than I expected but the shop is highly recommended and produces quality work. I'm excited to see how it turns out. I've never had a real seat on this bike and this is also the last piece of the puzzle for Phase II of this bike.
Offline JoeCooley
« Reply #118 on: January 31, 2018, 11:12:30 PM »
I also picked up some cool finned covers off my friend Ted (Ricky_racer). He has tons of really cool parts (unobtainium) for these bikes that are for sale. Shoot him a pm or email with your needs.
So yeah, on with the pics... haha
« Reply #119 on: February 01, 2018, 08:57:15 AM »
Ted has a treasure trove of goodies.  A regular Bill Benton of Southern California.
Offline JoeCooley
« Reply #120 on: February 10, 2018, 04:26:56 PM »
For sure and he's a great guy!
Update: The seat is back from Mark Luhr. http://www.customupholstery.net/
He did an amazing job and is a real craftsman. Not cheap but very nice quality and worked with me the entire time to ensure that I would be happy with the finished product.
A couple pics attached. It's almost time for glamor shots. I have to ride it and find a good background.
« Last Edit: February 10, 2018, 04:43:01 PM by JoeCooley »
Offline JoeCooley
« Reply #121 on: February 10, 2018, 07:08:20 PM »
Some Moose Racing plugs and a Pingel Power-Flo petcock. Anybody ever use these plugs? They came from Cognito Moto.
Offline JoeCooley
« Reply #122 on: February 10, 2018, 11:53:37 PM »
Here's a couple glamor shots from the garage.
« Last Edit: February 10, 2018, 11:55:33 PM by JoeCooley »
Offline JoeCooley
« Reply #123 on: February 11, 2018, 12:03:59 AM »
So the first test ride went sorta well. The new rear shocks ride much better than the #$%*ty emgos it had. She ran like a scalded dog!
That is until an intermittent ignition problem reared its ugly head again. I think either the dyna s has taken a #$%* or my coils are on their way out. Seems to run great until it gets warm and then it starts missing real bad. Sometimes it'll pick right up and start hauling ass again, othertimes not so much.
Anyone have some coils laying around so I can test my theory?
« Reply #124 on: February 11, 2018, 10:46:32 AM »
The seat looks great.
Make sure to check your wiring to the coils and move the wires as you test to make sure there are no internal breaks in the wires.
