Author Topic: Mable's Down (a rider again)  (Read 6901 times)
Offline Desert-SOHC
  • It's old
« on: November 23, 2016, 08:19:10 PM »
A little over 7,000 miles since being put back on the rode so far, and I'm on my way home from the shop yesterday and I start to notice a ticking coming from the lower left.  I narrow it down to the counter shaft area and pull over to see what I can see.  My chain has worn through the sprocket cover and the noise is the master link nicking the cover as it goes by.  What the heck!! I limp home at 40mph and parked her.  I will get her up and apart tomorrow morning and see what happened.... :-\
« Last Edit: December 03, 2016, 05:02:55 PM by Desert-SOHC »
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Re: Mable's Down
« Reply #1 on: November 23, 2016, 08:38:40 PM »
Sorry to hear!
Std chain?
Retainer for sprocket backed out?
Offline WhyNot2
  • I'm finally an
Re: Mable's Down
« Reply #2 on: November 24, 2016, 07:50:18 AM »
Sounds terrible.....any pics?
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #3 on: November 24, 2016, 09:59:46 AM »
I got a handle on it this morning, the chain is trashed along with the sprockets now.  The master link appears to have failed which caused the initial problem leading to the noise, damage, and would have been a failure.  I caught it before it threw the chain, but just barely.  I didnt replace the sprockets when I did the new chain and I knew it would wear the chain out early, so its on me   :P.  New chain and sprocket kit is ordered and she should be back up by next week.
11 Ranger S/C 2wd
Re: Mable's Down
« Reply #4 on: November 24, 2016, 01:16:35 PM »
Ouch!
glad you caught it before total catastophic failure.  At least it is fixable and you did not have a wreck/spill as a result.
David
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Mable's Down
« Reply #5 on: November 24, 2016, 02:14:42 PM »
Wow that thing really went to work on that cover!
Offline MoMo
  • Ride like you're invisible
Re: Mable's Down
« Reply #6 on: November 24, 2016, 03:08:15 PM »
pretty sure I have a spare cover if you need one.  As David(raf) said you could have had a terrible spill when the rear wheel locked up
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #7 on: November 24, 2016, 06:28:12 PM »
Yeah, it looked pretty sketchy this morning, but I think it would have just dropped the chain on the street rather than lock the rear wheel up.  I'm going with a 530 conversion this time with steel sprockets and am regearing it so that 5th is like an overdrive.  I do alot of highway and I want better than 36mpg.
11 Ranger S/C 2wd
Re: Mable's Down
« Reply #8 on: November 24, 2016, 06:35:25 PM »
If you are only getting 36mpg, you got something else other than sprockets wrong
Re: Mable's Down
« Reply #9 on: November 24, 2016, 07:02:38 PM »
First time I have seen that..
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #10 on: November 24, 2016, 09:19:56 PM »
She spends most of her life around 6K, and at that rpm thats all she gets.  I have gotten 48ish mpg, but to get that I have to stay around 4500rpm and that gets you run over around here.  The gearing change will get me in that rpm at the speeds I  have to travel.
11 Ranger S/C 2wd
Re: Mable's Down
« Reply #11 on: November 25, 2016, 03:41:46 AM »
you are going to lose a lot of acceleration making that sprocket change and will gain little if any mpg's as you will have to use more throttle.  You should get 42-45 mpg riding at 80mph/approx. 6000 rpm with  17/48 tooth combo or 18/48 and an 18" rear wheel.
Offline WhyNot2
  • I'm finally an
Re: Mable's Down
« Reply #12 on: November 25, 2016, 04:03:08 AM »
WOW....glad you caught that b4 anything worse happened.
I had one come off just on take off, so wasn't going to fast, and no damage.....fortunately.
Re: Mable's Down
« Reply #13 on: November 25, 2016, 11:04:11 AM »
It appears that the sideplate must have been partway off but still holding ?
One would think once clip was gone, it would come off easilly if it started hitting anything..
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #14 on: November 25, 2016, 01:17:58 PM »
I would suspect that the Master Link was installed incorrectly for it to have failed that quickly. Was it a riveted type or "open ended"? If open type, make sure the gap is oriented to the rear tire while the link is on the top of the sprocket. It also could have been an issue of too much slack in your chain allowing the chain to slap across the front sprocket. Make sure you check/adjust your new chain within the first few hundred miles of being newly installed.
Things to double-check...
Thanks Calj, it was a clip master link and was installed correctly.  I tend to think it was caused by a to loose chain myself, I've been meaning to get to adjusting it for awhile now and it just didnt get done.  I usually buy a riveted chain but was on a tight budget then and bought the cheapest chain I could find with the thought of changing it soon...that was a year and a half ago....lol.
11 Ranger S/C 2wd
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #15 on: November 25, 2016, 01:28:28 PM »
Being a 78 it has a 15/41 with a 630 chain and a 17" rear wheel and 6K on it is almost 90mph.  80-85 is the norm on the highway around here and I could probably get into that mpg if I babied her a little more during acceleration, but thats most likely not going to happen... ;D
11 Ranger S/C 2wd
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #16 on: November 25, 2016, 01:33:47 PM »
I think the "clip" broke or came off as I got to the shop or shortly after leaving to go home.  I do a dust wipe down at the shop every day and I would have noticed the damage to the cover then.  At that point I think the sideplate started to come off killing the cover and causing the noise.
Either way the parts are ordered and should be here by next Wednesday.  Till then I'm driving the Scout.
« Last Edit: November 25, 2016, 01:37:54 PM by Desert-SOHC »
11 Ranger S/C 2wd
Offline przjohn
Re: Mable's Down
« Reply #17 on: November 25, 2016, 02:07:33 PM »
I would recommend to anyone that is doing any chain or sprocket replacements to do everything at once. And, pry open the purse, let the Moths loose, buy a good chain tool kit, Motion Pro has one for a fair price. I have to laugh when I hear these guys asking for a "Chain Length" for their bike. WTF, If you don't have the basic knowledge, tools, or mechanical ability to properly measure, cut, and  install a chain and sprockets, GO TO A SHOP!!!!! You are riding Vintage Bikes for crying out loud. Go buy a Harley or a Beemer if you want Gravy. Get some basic tools, follow the prescribed guidelines in The Owner's Manual and you'll be fine. This isn't Rocket Science folks. You cut the chain, and then rivet it back together, or, install a Mater Link properly. If that is out of your realm of capabilities  than have a pro do it. Seriously, to quote the great Dirt Bike Magazine Editor Mr. Know It All, "You Should Have Known"
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #18 on: November 25, 2016, 10:50:44 PM »
Thanks mom.   ::)
11 Ranger S/C 2wd
Offline przjohn
Re: Mable's Down
« Reply #19 on: November 26, 2016, 01:45:55 PM »
  • Holy Cow! I'm a
Re: Mable's Down
« Reply #20 on: November 27, 2016, 12:03:21 PM »
Re: Mable's Down
« Reply #21 on: November 27, 2016, 01:00:47 PM »
 Some days I think people have trouble counting to 50 or 52...
Offline TomsK8resto
Re: Mable's Down
« Reply #22 on: November 27, 2016, 03:57:18 PM »
Chuck,
Sorry to hear about your chain woes.  The fairing is all packed up and I hope to get it shipped tomorrow.
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline Airborne 82nd
Re: Mable's Down
« Reply #23 on: November 27, 2016, 08:19:23 PM »
Glad you brought that up I like to get a good laugh. Now at  Desert-SOHC what sprockets size and chain length did you go with on the 530 conversion? I'm ready to get rid of my 630. I don't mind extra links on the chain better to long than to short :o Thanks in advance.
Offline Desert-SOHC
  • It's old
Re: Mable's Down
« Reply #24 on: November 27, 2016, 10:40:18 PM »
Chuck,
Tom
Parts should be here Tuesday.... ;D
11 Ranger S/C 2wd
