Author Topic: solved my head seepage problem but  (Read 1044 times)
Offline use2b
« on: November 26, 2016, 11:34:00 AM »
solved my head seepage problem but hate to say how i did it.
my CB750K6 has had this seepage problem for some time and i got use to just wearing dark pants and wiping off the plastic side covers every 50-100 miles.  switched my oil to this last year and all seepage stopped with no clutch problems at all.
this is just a suggestion and it may not work for everyone but 5K and a year later by bike no longer seeps oil under the head
Re: solved my head seepage problem but
« Reply #1 on: November 26, 2016, 11:36:43 AM »
 Some people report more leakage with synthetic so consider yourself one of the lucky ones where it healed itself somehow..
Offline USMC5811
« Reply #2 on: November 26, 2016, 01:07:48 PM »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: November 26, 2016, 02:44:11 PM »
Zddp+ yo
Offline use2b
« Reply #4 on: November 27, 2016, 06:29:51 AM »
Had to google Zddp because i did not know what it was so thanks , and USMC " its a trap" LOL - SSgt 0311 here Vietnam Vet became a 6617 after i got back - Semper Fi
I was very reluctant to post these results and only then after a full year of use.  this may not work for everyone but not being a true mechanic i did not see what i had to loose because the seepage was so bad i was going to have to pull the head even though i suspected the seepage was only coming down around those rubber plugs [ sure they have a name ]
i believe this high millage oil has an additive that swelled or softened the original rubber plugs and now i have no leakage.
never the less this solved my problem and this is the only oil i will use in this bike.
I only use Castrol Actevo X-Tra 4T Synthetic Oil Blend 10W40 in my new CB1100A
Offline Lostboy Steve
« Reply #5 on: November 27, 2016, 09:00:07 AM »
Lol it sure is! Is that automobile oil? Jeezus.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #6 on: November 27, 2016, 09:01:28 AM »
I run zddp in everything that doesn't have a converter. I'm also all for unorthodox repair methods. Good to see it worked for you!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline USMC5811
« Reply #7 on: November 27, 2016, 10:48:24 AM »
If it works, it works
« Reply #8 on: November 27, 2016, 12:18:53 PM »
I considered doing that myself.
