I just got a warning when I started this post that nothing new has been added in 90 days. Ugh.
Got the tank all sealed, used the Dragon Blood red Caswell. Coated the bottom of the tank (exterior) with rust converter and then primed it with 2 part epoxy primer. Did all the body work on the top as well (several small dings and depressions) and primed that. Left side where the emblem sat for some reason didn't come out as well as I thought, I could still see a slight depression in the badge area so I've been skim coating it and getting ready for another coat of primer.
Finally got a rear hoop; ordered the pre-formed one from Cognito. It was 1/4" too wide for my frame so I clamped it and welded it to the frame rails, then had to go to the back and cut out about 3/8" from the center and weld that to keep it from being too bulbous.
Started with the foam yesterday to form a rear section. Spent a lot of time on this - whenever I see a cafe that I don't like it almost always involves the proportions of the tail compared to the tank. Pretty happy with what I've ended up with and I just finished the second layer of fiberglass. Also realized that I should have brazed in a think piece of steel to cover the opening on the back of the tank before I epoxied it. I figured doing it now would be a bad idea so I'm adding a lip on the front of the seat that will be color matched to the tank; I don't really like the look of the seat itself being flared up to cover this opening.
Before anyone asks, that is in fact a piece of wood
. I was struggling with what to do for a seat pan when I came across this piece of scrap that might be the lightest piece of wood I've ever picked up. Figured why not, it was easy to sculpt the bottom to sit nice and low on the frame rails. My plan for a seat is to get a big piece of 3/8" thick hpde cutting board, heat it to bend the kick-up section and let my upholstery guy put foam on that and wrap the whole thing in leather and alcantara with a nice burgundy diamond stitch.
