The bike is damn near done, have a couple trivial little things to fab before it could be on the road. I need help tuning it though. I've never done anything with carbs and it is shows. I have the air screws at 3/4 turn out, more in or out only lowers the idle, so that seems like the right setting. I have the throttle stop set to generate an idle of 1500 rpm. This seems high, but if I lower it at all the bike just dies. It simply smells rich, although this could be how old things without FI and cats smell.
I can ride it down the road and it responds well to throttle, haven't had the throttle open more than about 1/8th of the way because the road I'm using is basically just a really long driveway. So basically at this point the other jets aren't really doing anything, but maybe they need to be changed?
As a review, this bike has CR26 carbs, an MRieck stage 2 port job on the head and 596 pistons in it. I have the following jets installed:
Pilot Jet 55
Air Jet 220
Starter jet 35
Main jet 95
Clip position 4 from the the bottom
All these settings were from others who had the same setup.
Any suggestions? It would be awesome if I could do something besides look at this thing after 4 years
If anyone is remotely close to Long Island, NY who can tune carbs I will put it on a trailer and come to you.
