Author Topic: Oh Baby, it's cold outside! Now it's hot! WTF?? NOW FREEZING - AGAIN!  (Read 51269 times)
Offline rb550four
Re: Oh Baby, it's cold outside! Now it's hot! WTF?? NOW FREEZING!!!
« Reply #200 on: February 23, 2021, 03:36:44 PM »
  I run 10 ply mastercraft truck tires all year long ,on the front and 4 on the rear end on all my trucks, they grip very well, been running them for years.  This truck is an 88 one ton  ,460 cu in, c6 auto 410 in the rear...not 4wd....never needed it ,I run about 9000lbs with tools on , and it seems to be enough weight to find the bottom of the snow for good traction and powerful enough to kick the rear around predictably by feathering or  back peddling the throttle.  The salt is a real killer  for sure , I replace panels and repaint every 3 years  or so, but once the frame rot starts , it's pretty much over.
   I have two 1990's in the wings for next year, I run the diesel in the summer because I don't like to plug them in ...and winters take their toll on starters at the end of the day at the winter jobsites. I wouldn't have another diesel since the fuel has been changed to make believe diesel....makes older engines run poorly,lack power, and is expensive now. When diesel was more like #2 fuel oil , I wouldn't run anything but a 7.3 idi diesel then ,a turbo was just something most other guys got off on and I never found it necessary until I got a newer diesel, they need a turbo on that crap fuel just to get out of their own way.
« Last Edit: February 24, 2021, 04:29:40 PM by rb550four »
« Reply #201 on: February 03, 2022, 07:38:43 AM »
It as friiggin freezing here in Cen Tex last night, 31 degrees.   I don't like it!
You?
Seems like our annual winter storm is upon us, temp is 28 degrees with freezing rain!
The City is pretty much shut down and they are urging everyone to just stay home...
« Reply #202 on: February 03, 2022, 08:32:50 AM »
I guess that is cold for Texas, not here at latitude 60* north ;D
28F,  -2.2C
Cold rain can cause heavy icing when freeze.
But usually more north when warm wet air from the Mexican gulf meet cold air from Canada as seen on TV, right?
Lets hope it will not go bad for you. Catastrophes often trig criminals to plunder others belongings.
I think "global warming" is an error while thinking or just a political thing, religion.
It can be something like "Maunder Minimum" 1640 to 1715.
https://link.springer.com/article/10.1007%2Fs00382-006-0188-7
I doubt people caused that.
Good to be prepared and be able to handle the situation while discussions goes wild and hot. Science vs religion.
Knowledge about the past can help to handle the future.
Offline CycleRanger
  • No comment about being an
« Reply #203 on: February 03, 2022, 09:16:25 AM »
Two hours ago it was 30 degrees. Now it's 24.
« Reply #204 on: February 03, 2022, 09:23:56 AM »
28F,  -2.2C
Hey Per!   Yes, that is cold for Central Texas!  [Latitude 30° N].
We get the strong cold fronts from Canada, but typically only lasts for a couple days, will be back to 50F this weekend.
Global warming?  The "Ice Age" was 18,000 years ago, it has warmed up ever since!!
Online Don R
« Reply #205 on: February 03, 2022, 09:42:07 AM »
 My Dad remembered a winter that was extra cold, they had to tunnel through the snow to move and feed the farm animals. The summer stayed cool also, the crops sucked. I think it was in the 1920's or 30's. He may have been in Pennsylvania at that time. They moved back and forth.
« Reply #206 on: February 03, 2022, 10:39:18 AM »
It can be a colder period as had happened before. Maybe not the real iceage with km thick layer of ice covering the nothern half ;D
The colder period brings more heavy storms too.
If that is what happen now, more can come.
Early 40's during WW2  had extra cold winters around here.
The sea outside Denmark froze 1658 so Swedish soldiers could attack walking on ice ;D
Lets see if we will get s longer cooler period.
They talked about a coming near future small iceage when I went in school for decades ago.
« Last Edit: February 03, 2022, 10:46:55 AM by PeWe »
« Reply #207 on: February 04, 2022, 06:23:21 AM »
6 degrees after I rolled out of bed this morning here in SW Michigan. See our big snowstorm we had recently is slowly heading east, enjoy you guys.
« Reply #208 on: February 04, 2022, 07:15:47 AM »
Hey Eric...heard from a buddy last night, he lives near Ann Arbor, said they got about 12" of snow up there. Guessing you got about the same?
The storm here wasnt as bad as the weather forecasters predicted, only about 1/3" of ice.
« Reply #209 on: February 04, 2022, 07:30:30 AM »
Steve-o, your houses are not that insulated as we have in the north, right?
3 glazed windows is standard here since decades ago. Thick roof with fluffy glass wool or similar, not only in the walls.
A well insulated house keep the hot sunny weather outside  and keep the electrically created coolness inside too ;D
« Reply #210 on: February 04, 2022, 07:38:35 AM »
My house is almost 20 yrs old and insulated fairly well, the windows are double paned. The attic has at least 8" of "blown in" insulation, wish it was foam as I feel that is superior.
It is two story so I have 2 HVAC systems, electric power, and my electric bill runs $200 - $300 per month all year 'round.
It is highest July - Sept when daily temps rise to 95-100F every day.  Pretty reasonable, I think.  The house is all electric, fairly common for this area, so I dont have a gas bill [the two hot water heaters are elec too]
« Reply #211 on: February 04, 2022, 08:25:24 AM »
Around that. Got to break out the snow blower for a 'ride' and did both neighbors also. Had been a pretty easy winter around here but finally getting a little late winter spanking.
   Saw the big traffic jam down in Texas where some people had been sitting for over 10 hours on a highway on a hill. Ice is bad wherever it is but salt trucks help.
« Reply #212 on: February 04, 2022, 08:37:18 AM »
My house has no issues with -25C or colder. It will cost more though. ;(
We get very hot water from a power plant in my city that heat up most of the town via hot water pipes in the ground.
Heat exchangers in each connected building with measuring device that sends the heat consumption to the power company wireless, like a phone as most alarms do.
Tap water is cold when arriving, heated up by this. Radiators are waterfilled and has its own circuit to a heat exchanger.
I have got more thoughts about this when we like to purchase an apartment or house in Spain or Canarian Islands to the retirement. The latter less need of heating or cooling.
The increased costs of the electricity due to climate discussions make this to an important detail.
Be more independent.
Sunny countries when cold: Solar heated water circulate into a huge insulated tank of water where heat exchangers are connected to floor heating
and tap water that is used all year around.
House with roof terrace where the solar panel can be placed.
The tank on ground floor that can handle the weight.
Cheap version of aircon when needed ;D
There are lots of informarion about the Bangladesh version air cooling device when compressed by its own flow.
Solar powered fans might help.
Make a better build in the air vent with metal net keeping the bugs out.
http://www.inspiraction.news/en/2017/09/11/plastic-bottles-as-air-conditioner-in-bangladesh/
« Last Edit: February 04, 2022, 08:51:09 AM by PeWe »
« Reply #213 on: February 04, 2022, 08:51:10 AM »
No salt trucks around here and glad there are not!  Some of the major highways in Austin were pre-treated with a "brine" solution [salt water?] but then it rained so not sure if that helped melt ice?
« Reply #214 on: February 04, 2022, 09:22:56 AM »
Around here at one time they were making some type of a brine out of sugar beets or material left over from the sugar process. Up around Saginaw and through that area some people call them "Sugar Beeters" as that is a major crop.
« Reply #215 on: February 04, 2022, 07:13:55 PM »
It's been 9*F here the last two mornings....
« Reply #216 on: February 05, 2022, 07:59:35 PM »
7.6F this morning with a high of 55.8 this afternoon!??
« Reply #217 on: February 07, 2022, 07:12:25 AM »
34F this morning here, looking forward to sunny and 61F this afternoon.
The freezing temps are gone for now.
« Reply #218 on: February 07, 2022, 07:26:26 AM »
Very short winter for you Stev-o! 8)
The spring rides will feel extra good after 5 months of waiting as here! ;D ;D
This forum makes the winter to a bike season anyway.  ;)
« Reply #219 on: February 13, 2022, 03:13:21 PM »
I give up!
« Reply #220 on: February 13, 2022, 06:54:02 PM »
15.5 F in the AM today, with a high of 69.8 in the afternoon, with clear blue skies. There's only been a couple of dustings of snow this winter, but the winters of 2019 and 2020 had record amounts of snow here, while last summer had record rain-fall, and the summer before had records for heat. Climate change is real..
« Reply #221 on: February 14, 2022, 06:46:43 AM »
It would be better with max 3 months off when it's too hot for leathers and full protection.
Too much of this. 5 months of waste Nov-March. Fixing bike need less garage time.
More than 1 bike or always a bike up for a ride. Bike harem! ;D
(This morning)
« Last Edit: February 14, 2022, 06:51:39 AM by PeWe »
« Reply #222 on: February 14, 2022, 07:24:36 AM »
Beautiful day today, going up to 72 degrees F.  It was one year ago that we had the "once in a lifetime" [I hope!]  snow/ice storm in Texas...
« Reply #223 on: February 14, 2022, 08:16:57 AM »
Saturday it was 16C and I rode 117 miles while Sunday was 0C, snow and wind.
« Reply #224 on: February 14, 2022, 08:48:17 AM »
1 degree when I left a Superbowl get-together last night in SW Mi. Driving there around 5:00pm hit a major white-out on the highway. Those are always fun !
