Author Topic: Oh Baby, it's cold outside! Now it's hot! WTF?? NOW FREEZING - AGAIN!  (Read 46204 times)
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Oh Baby, it's cold outside! Now it's hot! WTF?? NOW FREEZING - AGAIN!
« Reply #450 on: January 17, 2024, 11:50:57 PM »
3 degrees here in south eastern Ohio
neighbors kid is staying with us bc their furnace went out.
bad time for that
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #451 on: January 18, 2024, 02:18:34 AM »
I do not see riding season even with my vivid fantasy!
Yesterday before I had to use my car.
We have extra warm days now -5*C to minus -10*C.
Soon back to -20*C  again ;)
My house heating system works fine. Garage the warmest room with +22-23*C.
Rest of the house 20-21*C daytime.
Night temperature 18.5-19.5*C.
I have programmed for best economy without making the house too cold.
« Last Edit: January 20, 2024, 01:31:08 AM by PeWe »
« Reply #452 on: January 18, 2024, 06:58:35 AM »
Hey Per...no room in the garage for your car?  I keep my truck outside but the wife likes her car in the garage!
We have "Rollor coaster" weather - today's high will be 72F but tomorrow night 22.
« Reply #453 on: January 18, 2024, 07:42:05 AM »
I don't like roller coaster type weather.
« Reply #454 on: January 18, 2024, 09:29:26 AM »
No, only 20 square meters.
I had the car there before I brought my K6 back from a friends barn August 2009.
Later on more bike stuff.
No room for anything else. Only possible to open car doors on driver side.
I need double more.
Garage here not US style, small narrow things for a medium size car maximum.
Now a work bench full of stuff, engine build in parts included + shelf systems for parts and stuff+ tools.
I have to clean out to get space to bolt stray parts together to use the space better.
That give me a 3:rd bike, CB750 K2 ;D
« Last Edit: January 18, 2024, 09:32:25 AM by PeWe »
« Reply #455 on: January 20, 2024, 12:09:47 AM »
PeWe, how do you heat your houses there? How much insulation is typical in walls, ceilings/attic, and floors? Are basements common or uncommon? Garages sound like 1970s typical size in US, over time the garages in America became much larger. There was a time 50s where our cars were not quite as huge, but some of the cars in 40s might have been narrower but they were longer. Our roadways became bigger to support tractor and trailer semis and large delivery trucks in many areas. Residential streets vary even today. My neighborhood with house built in 78 when I lived in Ohio was wide enough for 2 medium or large cars to be parked with one wheel on sloping curb on each side of street and room for large car to go between them. Backing out of your driveway if a single wide you had to cut left or right on the driveway sidewalk apron to back into the street without hitting a car if parked on a street across from the driveway. Space between houses was about 14 to 16 feet in side yards and front laws were about 40 feet to curb and my house has about 70-80 feet of depth behind the house with house being 45 feet in length and 30 feet depth roughly. The house was a 4 level split -level design with spit from side to side instead of front to back. 7? Or was it 8? steps between main entrance level to upper or lower level with basement t beneath main level and it was 4 steps down to lowest level. You had a stoop instead of a large porch and house's main level was 2-2.5 feet above graded level and 1 car garage under bedrooms on highest level and driveway sloped to drive into garage on left side of house from street view.
Your houses look much like some designs in America but built for colder climate of course. Columbia Ohio  being as bit south of England or along it's southern reaches I think. The difference in climate being largely that Englands weather like Sweden is dominated by the ocean that surrounds them with America the land mass being much greater the oceans influence is muted after several hundred miles inland, being about 2000-2400 miles across and Canada above US our weather is controlled by the jetstreams moisture and weather patterns with AZ being controlled by the southern flow diagonal out of Mexico and the Pacific sometimes because of the jet streams dip down through the western US being pushed east or drawn westward by high and low pressure front that move through.
So we get moisture up out of Mexico in Monsoon season and during the winter with cooler temps the moisture flows inwards from both directions. We historically get most of our rain in the winter in the desert SW of Southern Arizona... Monsoon rains usually start in July if we are going to have z good monsoon season they won't start before July. Then the monsoon season ends as late as October some years but usually in late September.
The monsoon rains tend to be violent high wind events whereas the wn
Inter rains can last far longer. Our soil largely doesn't absorb the water as the calcium carbonate in the soil forms a concrete like impermeable layer 6 inches to 18 inches beneath the sil in much of the Tucson area, here in the valley beyond the Tucson Mountains the glacier that moved through thousands and thousands of years ago wore away the mountains grinding them into soil and sand without as much calcium carbonate here in my area...the soil percolates better but not great. Most of Tucson has caliche and it is allowing Davis Minathab to have the giat aircraft "boneyard" and reclamation storage of USAF and Navy and some US army aircraft in a high heat dry storage that is murder on electronics and plastics and composites with time as the sun and heat are brutal but the dry conditions slow airframes to survive without corrosion caused by moisture. So, ideal storage from that perspective.
The houses mostly do not have basements as jack hammers and boring bars avd sledgehammers have to be used to break through the caliche which varies from a few inches to 2 feet thick in places...
You build your house on top of caliche and it is like building atop concrete foundation, it can crack so you still have to build with idea of floating your building over a sandy soil full of rock and caliche. If builders run into a layer of caliche they typically aren't going to the expense and effort of trying to remove it, they adjust plans to accommodate it, if it means changing the design completely to different structure for homes they often do it. Depends on if the neighborhood is dealing with heavy excavation equipment or not whether they attempt to deal with cdliche . Many properties built go the opposite way abd grade and move soil in some complexes being developed when lots of houses are going in, to build up the area and grade it all fairly uniform to control flooding and water runoff and make the properties have more usable yards.others go with low impact and desert landscaping and desert like land surrounding the house
 The later tend to be those with individual builds.
Those just build up around the house to repel some water but can be at flood risk in some places with 100 year flood plains affevting those structures.
Sorry for segue, one thing leads to another and topic of house construction is way off topic except for insulation and construction differences and heating difference for our climates where we live withing the concept of it being cold...
David
« Reply #456 on: January 20, 2024, 01:04:57 AM »
My house built 1988, ready 1989, (I moved in 2004) is heated by hot water via pipes from a power plant producing electricity and hot water.  There is a huge network of pipes all over (under) the city undergound.
(They also produce remote cold, also via pipes, mostly to offices I guess. New since a few years back)
I have heat exchangers in my garage, for tap water and radiators below each window. Pump for radiators controlled by a programmable unit where I can decide day and night temperatures, times when switching on-off.
There is a sensor on the hause norhern side that measure outside temp so the system will compensate when it turns colder or warmer. There is a variable to set how fast it should react. This is different for each house depending on insulation and leaks.
3-glass windows. Rather well insulated house. I think the outer  walls are "building blocks", drywalls with foam inside. I think another layer of insulation, moisture barrier and brick walls up to 2.4m height.
The gabels have wooden plank from 2.4m up to full height, maybe 5-6m up.
Possible to add a 2nd floor. But that will need more heating. The empty space today is a good insulator. There is lots a fluffy stuff over the ceiling, min 0.5m.
This heating system the most effective here for best price.
House has 124m2 living space + 20m2 garage that is part of the house. Just walk thru the utility room.
Easy to get something done for 5 minutes or hours. Working from home  helped my rebuilds.
Since the incoming hot water enter the garage where the heat exchangers are located, garage is the warmest place, 23*C winter time.
The garage should be a double plus one extra much longer where an old long US car could be stored if I should have one ;)
Dec 26, much more snow today!
The narrow garage door in front of the car.
January 1 2024
The MESS, also called garage today. I need to remove stuff and make space for my CB750 no 3, in parts here and there. Not much missing, only some small things.
Heat wave today, now -12.6*C. Around -20*C yesterday.
But this is how I remember January and February since I was a kid.
Have memories from mid 60's and forward so I do not buy the silly talk about extreme weather.
In the 80's I usually said that we have to be prepared for constant -15*C to -20*C with some peaks below -25*C in January-February.
I remember one winter when I bicycled to my job. It felt like my cheaks hade cracked so I checked with my hand for blood.
I thought it was around -20C, did not ckeck temp before.
My colleagues mentioned -27*C that explained the feeling after only 10 minutes ride of total 15 minutes. ;D
Think that was end of 1990's.
« Last Edit: January 20, 2024, 02:44:05 AM by PeWe »
« Reply #457 on: January 20, 2024, 03:45:43 AM »
PeWe:   Quite few setups like that in Czech Republic.  Usually utlizing power plants but some facilities were built as central heating solution.
Funny story:
My college in Prague was next to a huge hotel.  The heating was shared with the hotel and other buildings.  When I was defending my thesis in August, the college building was heated to 30+ degrees Celsius, because the heating company had to burn leftover coal for the year before the winter.
Miracles of socialism.  If they had coal left for the heating season, the next year supply would be limited by that quantity.
« Reply #458 on: January 20, 2024, 04:09:59 AM »
Funny story:
That reminds me of Ukraine in winter, around new year 97-98.
An appartment in Odessa where the radiators were really hot, windows slightly open to compensate. ;D
Similar in Transnistria where  a power plant for electricity heats up water for the city and more. Natural gas from Russia.
Same as here when hot water initially was left overs of electricity production. Later more focus on producing hot water
Open windows when I pay for heat,  no thanks!
Ventilation system need to be adjusted for fresh air and correct flow in all rooms. No condense on windows inside is the thing.
« Reply #459 on: January 20, 2024, 11:40:02 AM »
A friend had an apartment in Ukraine and was living there and she was home for some medical stuff and visiting family and friends sbd has a delay on her return, then the invasion & war started. The place she worked was taken over by the Russians when they occupied the city and Russians were using the campus and buildings as barracks and other headquarters...and it was destroyed in the end.  Her cat she hasn't seen for over 18 months now and a friend was caring for it but he couldn't take the pets with him when he had to flee to safety. The city was ravaged as it was where early fighting took place as the Russians pushed in from Cromea and from the East. They had centralized hearing and Chicago city apartments and NYC apartment buildings use these systems today... Hot water was used in part of the old AT,&T Western Electric manufacturing plant I worked it, it was AT&T Network Systems when I worked there with AT&T Bell Laboratories doing hardware and software product design and development in their areas. I worked with them and then for them for the 17.4 years I was employed by them and their tri-vesture breakup company...
It was an interesting career with them...learned a lot of things in that career...
Extreme heat and extreme cold both need excellent insulation.
« Reply #460 on: January 21, 2025, 08:01:34 AM »
Woke up with this weird white stuff all over the ground and Baby, it's cold outside!  Currently 29F but looking forward to the weekend when it will be in the mid-fifties.
« Reply #461 on: January 21, 2025, 08:42:25 AM »
I saw on the news this morning that Houston had a record amount of snow! The mornings here have been really cold, with single digit temps on 8 days out of the last 10. Three weeks ago, the high temps were running 15-18 degrees above normal for this time of year, and there hasn't been any measurable rain for months, much less snow.
Offline WhyNot2
  • I'm finally an
« Reply #462 on: January 21, 2025, 08:51:15 AM »
We have snow heading this way today, temp. it the 30s.
Next week temps will be in the low 60s,
Gonna put the tank back on the 750, and see what she'll do out on the road.
Finished with the CB550 front forks and rear swingarm swap.
I'm around the Augusta area of Georgia.
I'm also in need of a SL350 seat or seat pan.
« Reply #463 on: January 21, 2025, 08:52:59 AM »
We hit -20C last night and our dog that usually spend the whole day outside is doing 5 minutes stints today…….
Offline Mark1976
« Reply #464 on: January 21, 2025, 08:55:02 AM »
This is at my brother's home in Houston.
Start with the end in mind...
« Reply #465 on: January 21, 2025, 10:24:38 AM »
I just shoveled out the Explorer.
Yesterday I shoveled out the Escape.
Tomorrow it might be the JEEP.
I put a heater next to the 750 last night, it's coming up from 0 degrees inside the garage this AM. I don't know how far below zero it went last night.
Again.
« Reply #466 on: January 21, 2025, 10:45:40 AM »
Yes, our daughter moved to Hou last year, she sent a video of her and the dogs out in it. They prolly got about 4".
Check out this video, this was Central Texas 4 years ago near my home when we had two major snowstorms in a week, the guys were snowboarding on the streets!!!
https://www.youtube.com/shorts/2XMAGIilpJ0
Global Warming??!!
« Reply #467 on: January 21, 2025, 10:50:09 AM »
What area does he live?   Our daughter is in The Heights.
Offline Mark1976
« Reply #468 on: January 21, 2025, 04:01:29 PM »
   The Heights is a nice area, our current neighbors moved from the Heights area about 3 yrs ago, nice people. My brother lives just a bit south of the heights, Shearn st. He splits his time between Houston in the winter and an island community off the coast of Portland Maine in the summer. I lived in Galveston for a number of yrs during the 80's, it never snowed but it sure would get icey in January.
« Reply #469 on: January 21, 2025, 07:36:58 PM »
Global Warming??!!
Actually, it's more like climate change, driven by global warming. ;)
https://en.wikipedia.org/wiki/Climate_change
Just food for thought: one gallon of gasoline contains about 5.5 pounds of carbon. When burned fully, it combines with oxygen to produce 20 pounds of CO2. In 2023, the US consumed an average of 376 million gallons per day, producing 3.7 million tons of CO2, per day. This is just from burning gasoline, and doesn't include natural gas or coal. Basically, any carbon based fuel when burned produces CO2.
« Last Edit: January 21, 2025, 07:52:57 PM by scottly »
Offline denward17
« Reply #470 on: January 21, 2025, 08:04:13 PM »
Cold in NC the last few days, down in the teens tonight with a little snow coming up the coast.
« Reply #471 on: January 21, 2025, 08:16:53 PM »
There are interesting tv programs where historians and scientists have found repeating climate changes during thousands of years and more. El Niño, not a new phenomenon.
Viasat History and even Netflix have shown very interesting new program series the last 2-3 years.
The Akkadians in the Middle east had a severe dry period of 200-300 years around 2300 BC. No one could live there, all had to leave. Again 1200BC....it still happen while people has made that to a political leverage.
When the Angkor area in Cambodia had a monster monsoon with heavy floods in the 1400's,  Europe had a mini ice age. Etc etc.
People can handle that better today when food can be delivered from functional parts of the world to not functional.
Edit: 2300BC (not 23000)
« Last Edit: January 21, 2025, 08:41:42 PM by PeWe »
« Reply #472 on: January 21, 2025, 08:38:04 PM »
Per, there are very good programs on american PBS regarding the environment and history.
https://www.pbs.org/video/carbon-car-tailpipe-solid-chunks/
« Reply #473 on: January 22, 2025, 04:09:19 AM »
-7*f night before. 7*f above tonight…
Exactly on the historical perspective….just a nanosecond of actual documentation to determine the butterfly’s actual effect on millennia of millenniums. (See chaos theory)
Some experts claim the recent California fires have already spewed more co, co2, etc, and particulates into the atmosphere that all the catalytic converters and dpf filters will ever convert or trap…Mt.. St. Helen was a good example too.. Man’s arrogances are always amazing..
Brings to mind a saying Carl Seagan may have said,   “if it can be destroyed by the truth, it deserves to be destroyed by the truth”..   sometimes defined as it’s hard to go against the establishments’ accepted, political, and published views, until the truth (more accurate knowledge and understanding ) becomes so apparent that the new truths (beliefs) are so undeniable and obvious they destroy the older truths (beliefs).. it is usually constantly reoccurring over and over as we become more educated and intelligent. But the same arrogances and resistances will be met to prevent change. As well as the same reservations to buck the beliefs of the accepted establishments’s views. Even though all the professionals in the respective fields already knows and have proven those earlier beliefs to be false but remain silent for fear of the political retribution directed at them for doing so..
« Reply #474 on: January 22, 2025, 06:46:35 AM »
-7F here this am too. COLD.
