Hi all ..
It's winter time and I was working on one of the projects in the garage
I need to install a reg/rec unit on a 550 ..
I salvaged some of the original harness to use since I'm doing a rewiring but I'm a little confused
here's the part I'm taking about specifically
first question: should the orange thick wires be connected (go from one plug to the other)? or where should it connect to?
here's the breakdown of the plugs and tell me if I'm right or not ..
1-Furthest left in the upper picture
This should connect to the reg/rec unit but the orange shielded wire should connect to
2- the middle plug in the first picture
this should connect to the plug coming out of the engine right?
3- the last plug
Should I just eliminate this or where does it connect?
If I understand the wiring diagram right, I should just run the shielded wire straight from the battery's +, and use 3 wires from the third plug: natural, oil light, and the white should connect to the loose white on the reg/rec unit, and then I can jut eliminate the rest.. right?
I guess I have to say that I'm using an M-unit so the solenoid would be powered through there instead of using the wires in the 3rd plug.
Thanks again
Hashem
