Author Topic: 1963 Honda C200, Chinese Engine 90cc  (Read 7902 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: December 14, 2016, 05:04:46 PM »
Here is my latest project, I have a 63 Honda C200, I'm putting a Chinese in it.The brand name is Hauwei, never heard of it(got it a garage sale). It says 86ml on engine, I guess they don't like using "cc". I have two complete engines, minus one wire loom.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline tbpmusic
Re: 1963 Honda C200, Chinese Engine 90cc
« Reply #1 on: December 16, 2016, 09:40:44 AM »
Plug and play, dude !!
I have a C70 I'm thinking of trying to fit a Chineeze 125 or 150.
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline jgger
« Reply #2 on: December 16, 2016, 06:53:52 PM »
Wow! That was my first motorcycle........boy did I abuse that thing. I wish I still had it!
Offline rtbmrgl
« Reply #3 on: December 16, 2016, 08:41:40 PM »
If it was complete Id restore it, but a lot of stuff missing. Right now im just getting the engine in, new tires. Plan on riding it on daughters property, eventually will be grandsons first big bike. I have a line on a cheap PW50 for now.
thanks, Mark
Roseville, Ca
Got Points!
Offline faux fiddy
  • bike in a box
« Reply #4 on: December 18, 2016, 03:53:53 AM »
I recommend a yahoo group, Ill edit it in when I find it. I kind of got sick of all the updates after signing up, but that was the way to get info.
"Copy" it's not I understand, it looks like the oil port is different between the two of yours.
Mounting points can be different slightly or more and there are kits and tips if you find things don't just bolt up like you hoped.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline faux fiddy
  • bike in a box
« Reply #5 on: December 18, 2016, 04:45:08 AM »
Here's the Yahoo group. Yahoo generally sucks lately or what? I took ah hour to even log in.
https://groups.yahoo.com/neo/groups/honda_clone/info?prop=eupdate
Offline Lostboy Steve
« Reply #6 on: December 18, 2016, 04:48:40 AM »
I have a lifan 88cc 4speed semiauto that I got off of eBay on a 1968 z50 and it is pretty wicked. The original engine needed too many parts to justify a rebuild at the time. I have it on a shelf in the garage and maybe one day I'll put it back together.
Question, what the the big sprocket for?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline rtbmrgl
« Reply #7 on: December 18, 2016, 08:38:41 AM »
The big sprocket from what I understand was a Honda accessory that included the sprocket, adapter plate, chain link and bolts. You would remove the bolts on the big sprocket and slide the sprocket over and use the same bolts to attach the sprockets together. The CT90 had this similar setup but I believe this was an accessory. If Im wrong let me know, unlike in a Few Good Men, I can handle the truth. ;)
The engine fits after making a small notch. The foot peg bolts holes are offset so had to buy an adapter from DRATV.
http://dratv.com/bofoadplb.html
thanks, Mark
Roseville, Ca
Got Points!
« Reply #8 on: December 18, 2016, 06:40:59 PM »
That is an ungodly difference in sizes though, you going to be stunting with that thing? ;)
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline rtbmrgl
« Reply #9 on: December 18, 2016, 09:31:48 PM »
hahaha, it was on the bike and so ill leave it on there, kind of like it. My uncle put a huge sprocket like that on cousins step-through 50, it slowed us down. Top speed was about 25.
thanks, Mark
Roseville, Ca
Got Points!
Online RAFster122s
« Reply #10 on: December 18, 2016, 10:07:47 PM »
Having more hp without having more braking can spell trouble.  Ensure your brakes are working as well as possible to maximize their effectiveness.
Offline tbpmusic
« Reply #11 on: December 19, 2016, 07:39:34 AM »
The early ('66-'68) 4-speed CT90 models (K0) had a dual overlay rear sprocket setup.
The later models had a single sprocket but an 8-speed dual range transmission.
« Last Edit: December 19, 2016, 07:41:09 AM by tbpmusic »
Bill Lane
Offline rtbmrgl
« Reply #12 on: December 19, 2016, 08:33:47 AM »
Yep you right, I've never seen any big sprockets on any C200 photos.
As the store goes, Soichiro Honda in the late 50's and early 60's wondered why rural areas in the Mid-West were buying a lot of the C50 CUB's when they were basically designed for urban city commuting. They sent a team to investigate and found farmers were putting on knobby tires, racks etc and using they on the ranches. Thus was born the Trail 50 which and long with the Cub there biggest sellers.
thanks, Mark
Roseville, Ca
Got Points!
    • http://forums.sohc4.net/index.php?PHPSESSID=rn9v5pnh4prsg6g4bpag92bfj5&/topic,60973.0.html
« Reply #13 on: December 19, 2016, 08:49:23 AM »
you have to make a komplet new wiring..as the china is use cdi ignision and 12 volt battery..but its a easy thange..its basis the same as all china atv and cross modells use
i have just put a new china engine on the kids lifan dax..have some problems get the caburettor to Work perfekt..but the rest just Work fine...he is on the 2 oil thange run it more 1000 km
« Last Edit: December 19, 2016, 08:54:34 AM by strynboen »
Offline tbpmusic
« Reply #14 on: December 19, 2016, 12:31:21 PM »
Brakes are for girlie-men.
Real tiddler aficionados ride like this......
Bill Lane
Offline faux fiddy
  • bike in a box
« Reply #15 on: December 21, 2016, 02:56:28 AM »
Got enough ideas? Here's where you can spend hours looking at pit bike porn.  They have more big bike stuff because of some shows posted, but that's okay, too.
http://chalopy.blogspot.com/
Offline rtbmrgl
« Reply #16 on: December 22, 2016, 07:44:23 AM »
Thats some cool stuff
thanks, Mark
Roseville, Ca
Got Points!
« Reply #17 on: December 25, 2016, 05:41:09 AM »
My hardtail 50, as rough as it is, goes through everything that my wr goes through with that 88 4spd. It's a ton of fun in the woods but the hardtail does suck.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline rtbmrgl
« Reply #18 on: December 25, 2016, 11:28:43 AM »
Actually this engine is probably the same or less HP than the stock engine. Its 86cc, stock was 90cc.
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #19 on: December 25, 2016, 09:22:12 PM »
I used this Dura Fix to repair a broken aluminum handlebar bracket.
http://www.durafix.com/
thanks, Mark
Roseville, Ca
Got Points!
« Reply #20 on: December 26, 2016, 03:10:00 AM »
no good on struktuell stressed parts...the solder is far weaker then the cast aluminium..and the streangh/softnes dont match the orginal material...go for tig velding..
its fine for broken engine shields..to hold vater and dirt aut..and fill some holes..but not on brakes and stering parts..vho is importment for safty
« Reply #21 on: December 26, 2016, 07:03:55 AM »
I have wondered about this product in the past, it's not solder, but I can't tell you what exactly it is.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #22 on: December 27, 2016, 02:22:04 PM »
yes it are not direkt the same as solder..but either pure aluminium..it have a lover melding point then alu
..so have some p-b..and zink build inn..to make it melting farster..but that make it veaker and softer
tig weld is the only vay to make a strong burn total trough..and give a almost as good as new reparation..
Offline rtbmrgl
« Reply #23 on: February 03, 2017, 09:38:27 PM »
Im back at it, I had this on the back burner while restoring a Yamaha DT250.
« Last Edit: February 16, 2017, 04:58:49 PM by rtbmrgl »
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #24 on: February 10, 2017, 04:52:32 PM »
Almost ready to start
« Last Edit: February 11, 2017, 08:57:53 AM by rtbmrgl »
thanks, Mark
Roseville, Ca
Got Points!
