If all your std rockers are not OK, check for used ones on eBay where you can find good ones for not much. As said earlier, aggressive cams will cause more wear. This is cams with high lift and relatively short duration where the lift accelerate very quick.
RC/DP315 cam is specified with a lot of lash, 0.012" which is 3 times more than other hot cams. Must have more space for oil to lubricate the rocker as Frank wrote. I ran DP315 with 0.04/0.05" as I used on other cams.
I read Franks ideas about better lubrication with more lash as RC specified. That cams overlap was rather much so it was easier to change to specified 0.012" lash with decreased overlap, duration and also lift. Longer cooling time for valve in the seats must be good too, especially for EX valves.
The forces on valve train including the rockers will be less too.
Engine has a different behaviour with DP315 (much smoother) compared with a 295 or my other cams as Action fours ss-1, CX-7, Megacycle 125-20 that all have a sudden power increase around 6000-7000 rpm. CX-7 and 125-20 suddenly wake up at around 7000 rpm.
I'll see later on dyno if I'll compare the cams. DP315 will go in next.
Dyno before was 80rwhp with SS-1, 83 with 125-20 that have a fun behaviour exceeding 10.000 rpm like tacho going crazy
Wecam 41, 41a are all mild cams in comparison. Some of the other hotter cams need more cc and cr to work as designed. High CR need a cam with more overlap, later closing of IN that reduce the pressure (dynamic compression ratio) and less risk for pinging.
Note! My engine is tuned with ported head, 34mm inlet, opened chambers, bored, 32mm carbs, lightened crank (APE), carillo rods.
Most cams need ported head and pistons with higher CR and deeper valve pockets. For more job the owner need deeper pockets!!
