Author Topic: Cb400f "goldie", Handbuilt show, Bikeexif, and dyno run.  (Read 79464 times)
Offline innovativems
    • Innovative MotoSports
Re: Cb400f build aka "goldy"
« Reply #275 on: March 02, 2017, 03:39:50 PM »
My last package from ttr400 showed up.  As always, outstanding work from Kevin!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #276 on: March 02, 2017, 05:29:55 PM »
What color will you be painting it? The tank,seat and sidecovers
« Last Edit: March 02, 2017, 10:00:25 PM by grcamna2 »
« Reply #277 on: March 02, 2017, 05:43:52 PM »
What color will you be painting it ?
Gonna polish all of it but will probably do the triples in satin black.  My shocks should be here in a couple days then I can determine that
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline redwillis1978
« Reply #278 on: March 02, 2017, 06:45:43 PM »
Looking good!!!
If you haven't torqued down your head yet (it doesn't look like it), you might want to consider pulling the cylinders back off and putting some heat shrink or painting over those A.P.E. studs, the ones that are exposed to the elements will rust and you will not be able to un-notice it.
I am jonesing for my CB400's........
I may cry if I have to put those cylinder back on.  Compressing the rings was not fun!
I wonder how they did it repeatedly in the factory?
Offline Kevin
« Reply #279 on: March 02, 2017, 07:08:17 PM »
[/quote]
[/quote]
Not the same material.
I've heard from others who have installed the A.P.E. hardened studs that they will rust if they get wet.
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
« Reply #280 on: March 02, 2017, 07:20:02 PM »
There are some plastic ring compressors used for small engine repair and two of these kits at about $9 each might be worth the investment to make things easier.  They are made of red plastic.
Some have used wide worm clamps but taking them apart to pull them out after fitting the pistons into the cylinders are fiddly.  The red plastic ones have a finger that projects out from the rings and you wrap a rubber band around that to hold the compression.  To remove you pull the rubber band clamping it together and then spread it enough to slip off and out of the way.
At factory, probably did it by hand and skills developed from years of doing it and doing it quickly.
A paint or powder coat would work best on the APE studs... A good high solids paint capable of high heat will provide good protection.
« Reply #281 on: March 02, 2017, 07:26:57 PM »
[/quote]
[/quote]
I'll Probably just spray them with alittle fogging oil to protect them
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #282 on: March 02, 2017, 09:27:46 PM »
Well couldn't help myself.  I polished the motor mounts and brake stay.  Also just set my tappet covers and points cover on.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #283 on: March 03, 2017, 06:29:13 AM »
Looking great. Get busy on that paint.   :)  Look into Evercoat Slick Sand.  It is a sprayable polyester you use on top of bodywork.  It will replace the multiple applications of primer and spotting in stuff.  Much more stable in the long run.
« Last Edit: March 03, 2017, 06:46:29 AM by palepainter »
Offline Camrector
« Reply #284 on: March 03, 2017, 09:39:02 AM »
Now that looks sexy!! Polish those lowers!!!!
« Reply #285 on: March 03, 2017, 02:11:03 PM »
Looks unbalanced now.
« Reply #286 on: March 03, 2017, 02:20:22 PM »
How so?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #287 on: March 03, 2017, 09:42:48 PM »
Got my starter and oil pump on tonight. Started on cutting the fat off the sprocket cover.  Also got round one on my seat pan done.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
« Reply #288 on: March 03, 2017, 10:27:21 PM »
 ;D ;D ;D
« Reply #289 on: March 04, 2017, 06:52:54 AM »
I'll have to give that a shot.  I use their fillers and love them.
Bodywork and paint is on deck once the seat pan is shipped out!  Getting there
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #290 on: March 04, 2017, 08:49:27 AM »
How so?
Polished swing arm, polished engine bits, and then gray fork lowers. Should be polished.
« Reply #291 on: March 04, 2017, 08:55:13 AM »
How so?
Correct I'm waitinf on my gold valves to rebuild the forks.  Once the shocks are on I'll decide if I'm polishing the fork lowers or going satin black.  Leaning towards polished lowers and black triples
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #292 on: March 04, 2017, 08:58:19 AM »
How does the trimmed sprocket/CS cover look ?
« Reply #293 on: March 04, 2017, 08:58:25 AM »
Two options. Both are very similar.
« Reply #294 on: March 04, 2017, 09:25:29 AM »
It's eh right now.  Opening it up little by little until I like the end result.  I'll reveal once it doesn't look like a 8 yr old hit with some air tools
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
« Reply #295 on: March 04, 2017, 12:50:30 PM »
Both great products to go over your bondo work.  Finish the bondo in 80g..then spray a few coats of this. block with 180...final prime. sand with 500gt and paint.  That stuff really takes away the back and forth process of prime...sand...fill...prime sand...repeat.
« Reply #296 on: March 04, 2017, 12:55:45 PM »
Alright got to where I'm happy with the sprocket cover.  It's going to get vapor blasted like the rest of the motor is.  The holes I spaced around the structural bracing on the backside.  I'm happy with how it turned out. Also did the last layers for the seat pan.  Going to trim it tomorrow and put some nut serts in it and off to Chicago to get some leather and alcantara
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #297 on: March 04, 2017, 12:57:28 PM »
There's nothing hidden under that cover anymore;I imagine it's a Lot lighter.
« Reply #298 on: March 04, 2017, 01:01:37 PM »
Agreed, good thing I hit the starter with the polisher quick!  That oil pump is so clean I could eat off it now.
It is noticeably lighter.  Not that it was that heavy to begin with.  Trying to get this baby as light as possible.  Been trash talking my buddy who just built a kz650.  That thing will be a lead brick compared to this.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #299 on: March 04, 2017, 01:21:37 PM »
Would be nice if you could maybe whittle it down to 275..  :o
