Thanks all. Have performed most of the 3000, including gutting and cleaning carbs with wires, clearners and air. Disassembled and replaced rings, gasket and filter on petcock, cleaned points and reset timing, though I think that is still off a little. Have played with air fuel mix screw but don't feel like I quite have that right yet. Know the valve tappets should be done first, so had to order bent tip feeler gauge and then will restart entire sequence again. Only about 3k miles on oil and still clear so good for now. Adjusted cam chain. New plugs and snipped end of plug wires and rescrewed the caps. Air box disassembled, cleaned, new filter and gasket so check. New airbox to carb rubbers and wintergreened carb to engine rubbers. All new fuel lines from tank and at carbs. Fuel tank some small rust inside way down in sides so OK for now. Throttle cable slick and spring responsive--good snap back.
Steering head bearings and fork seals are beyond my skills and tools, I'm afraid and certainly do not trust a shop with any work on this bike. Can drop pan and clean under there, and could also drain front fork oil, as well as check out master cylinder. Good tip on tires--will check for date.
Thanks all. Will update in future in "what I did to my bike today."
Safe trails.
