Author Topic: First post - Mounting cb750 stock wheel to cbr600rr forks and brakes  (Read 3062 times)
Offline nicklowe
Iv been lurking here for a while during my last couple builds and I'm currently on last few steps of my 74 cb750 cafe build.
I just wanted to share my successful attempt to using adapter plates to mount a spoked wheel to inverted forks rather than going the massively expensive cognito moto route. Instead of buying a $400 hub, spokes, possibly a new rim and going through the trouble of lacing and taking off and on the tire. I did almost the same thing as the "Olivia cb550" thread with plates to line up the cbr rotors but instead of milling down the axle to fit the stock cb bearings I removed them and used the same plates to hold the cbr 1" bearings. The plates mount through the 6 stock rotor holes. Me and my machinist photo graphed the process
Re: First post - Mounting cb750 stock wheel to cbr600rr forks and brakes
« Reply #1 on: January 06, 2017, 10:50:08 AM »
Nice....and welcome aboard...
« Last Edit: January 06, 2017, 10:54:11 AM by 754 »
Offline Ericcb750
« Reply #2 on: January 06, 2017, 12:22:11 PM »
Pretty Sweet, Looking forward to seeing this come together. I have a GSXR Conversion going on myself so I'm always curious to see how they turn out for other guys.... I've never done it myself and am super excited to feel how it rides and more importantly....how fast it stops...
Will keep an eye on your thread.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline nicklowe
« Reply #3 on: January 09, 2017, 01:32:04 PM »
The front end is on!
Offline nicklowe
« Reply #4 on: January 09, 2017, 01:37:32 PM »
First ride; The braking is massively improved (obviously) it stops on a dime and looks cool as hell. The downside is with the change in rake/trail the steering is so immediate, sharp and unpredictable that a steering damper is more than necessary.
I have also managed to add a stock but chopped fender from the stock cb wheel by way of the stabilizing arms.
« Reply #5 on: January 09, 2017, 01:47:25 PM »
Or a custom offset triple to restore the stock offset.
Offline DME
« Reply #6 on: January 09, 2017, 02:36:29 PM »
Looks like that front fender will hit the lower triple tree when hard on the brakes. Also a good chance/risk the front wheel will be stopped by the crushed fender or by hitting the downpipes.
The suspension must always be able to bottom out without anything else hitting first.
Be careful...
Offline slikwilli420
  • Master of Disaster
« Reply #7 on: January 09, 2017, 03:00:00 PM »
Custom offset triples will definitely correct the steering. Shoot me a PM if your interested and we can talk about some design options. I have a ton of designs to work with.
« Reply #8 on: January 10, 2017, 06:36:19 AM »
Very nice thinking outside the box.  Thank you for sharing your solution.
Definitely plan to change your front triples to correct the handling problem as others have advised, not doing so could be the recipe for a wreck.
David
« Reply #9 on: January 10, 2017, 08:48:46 AM »
slikwilli420 has a variety of triple tree designs and can make something custom for you.  I don't know what his prices are but you can PM him.
Cognitomoto also makes custom offset triples for $599 (https://cognitomoto.com/collections/fork-conversion-parts/products/cbr600rr-cbr1000rr-fixed-offset-triple-tree-conversion-30mm-45mm-50mm-55mm-60mm)
Offline nicklowe
« Reply #10 on: January 10, 2017, 04:15:55 PM »
Would it be possible to take the triple to my machinist have him press out the stem and drill the seat for the yolk on an angle and same for the top tree ?
« Reply #11 on: January 10, 2017, 04:30:41 PM »
No.  Manipulating the rake angle by drilling another hole in the bottom triple at an angle will change the rake of the bike.  The fork offset is the perpendicular distance from the steering axis (center of the steering head) to the center of the front wheel (the center of the fork tubes).
Offline bert96
  • past ride
« Reply #12 on: January 12, 2017, 02:02:54 AM »
Very nice,i don't want to hijack,but i did something like yours....
With the help of Frank.
Bert
« Last Edit: January 12, 2017, 02:06:04 AM by bert96 »
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
