Author Topic: K&N air filter  (Read 847 times)
Offline emlupi
K&N air filter
« on: January 21, 2017, 02:59:17 pm »
I have a 1972 CB 750K with all stock jetting and air box. Is the K&N air filter a direct replacement for the OEM or will it require rejetting? Am I better served with an OEM replacement? Don't want to mess around too much with carbs.
Offline Bodi
Re: K&N air filter
« Reply #1 on: January 21, 2017, 05:28:49 pm »
An aftermarket filter in the stock airbox rarely upsets the tuning much. Be careful with the oiling of a K&N filter though: over saturating the filter media will restrict airflow considerably, basically it acts like the choke is on. Just a pint tint is good. The oil will wick into white areas after application... you don't have to soak the whole surface.
Offline emlupi
Re: K&N air filter
« Reply #2 on: January 21, 2017, 06:39:14 pm »
I wasn't aware that the air filter needed to be oiled. Please explain further.
Offline Killer Canary
  • Typical Bran Muffin
Re: K&N air filter
« Reply #3 on: January 21, 2017, 06:39:42 pm »
As Bodi said.
You'll also enjoy never having to buy another air cleaner. 8)
Kawi GPz900, H1
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: K&N air filter
« Reply #4 on: January 21, 2017, 07:16:30 pm »
K&N's are great!
With the stock airbox you might be fine.  Just do plug chops to be sure it doesn't lean out too much.
Re: K&N air filter
« Reply #5 on: January 21, 2017, 07:22:31 pm »
K&N filters usually come pre-oiled, ready to go, right out of the box.
Re: K&N air filter
« Reply #6 on: January 21, 2017, 07:45:47 pm »
 You only oil them after a good cleaning. I have a couple (cb and a gl) but not enough riding time with one to decide anything.
Offline emlupi
Re: K&N air filter
« Reply #7 on: January 21, 2017, 09:07:54 pm »
OK, that makes more sense. Thanks for the input.
Re: K&N air filter
« Reply #8 on: January 22, 2017, 04:43:26 am »
 I have a couple in bikes with stock air box and never had the need to re-jet. If you want to start a hot debate ask which filters better stock or K&N. Things could get 'oily' if you know what I mean  ;)
   On my 1200 Bandit the carbs from the factory or tuned so close to lean that a K&N is not recommended and will probably make it run worse on stock settings. Went with OEM style on that one.
« Last Edit: January 22, 2017, 10:22:01 am by ekpent »
Offline Bodi
Re: K&N air filter
« Reply #9 on: January 22, 2017, 08:20:27 am »
They used to be sold dry (white element) but folks were a bit dumb and neglected to buy and apply the red filter oil. Now most come pre-oiled - and of course ppl are still a bit dumb and neglect to clean and re-oil as needed.
There is a K&N filter cleaning and re-oiling kit available for around $15.00:
... but I'm cheap so I wash the pods in solvent until they are close to white then with water and laundry detergent to get the solvent out then hold each on a wet/dry vacuum until dry, maybe once a year (sucking the solvent out leads to unpleasant vacuum explosions). A squeeze bottle of K&N oil lasts about forever for pods... not so long on a large car filter.
« Last Edit: January 22, 2017, 08:23:30 am by Bodi »
Offline emlupi
Re: K&N air filter
« Reply #10 on: January 22, 2017, 10:15:20 am »
Thanks for the information.
