SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
Project Shop
Topic:
Unlocking '74 CB750 gas tank
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Unlocking '74 CB750 gas tank (Read 8384 times)
77379
Full Member
on:
January 22, 2017, 10:26:08 AM »
The other day while I was looking for some parts I ran across and brought home a non running 1974 750. Of coarse the gas cap was locked and the P.O. didn't have the key. Do these locking gas caps have one standard key to unlock them or are they all keyed differently? Are the keys readily available for them or is a drill bit the best way to go? Gregg
Logged
Stev-o
Ain't no
Really Old Timer ...
Central Texas
Re: Unlocking '74 CB750 gas tank
Reply #1 on:
January 22, 2017, 01:00:49 PM »
That is not a stock Honda lock, either find a key or drill it.
Appears to be a hex, can you fit a small set of needlenose in there?
The Honda lock works with any key [or a screwdriver]
Logged
77379
Full Member
Reply #2 on:
January 22, 2017, 01:42:24 PM »
I couldn't fit any of the needle nose pliers I had in there. I'm going to round up some smaller ones and give that a try. If that doesn't work I'll go ahead and drill it out. I wasn't aware it wasn't a Honda lock.
Logged
b52bombardier1
Hot Shot
Reply #3 on:
January 22, 2017, 02:38:41 PM »
You could knock out the mounting posts instead of drilling out the key slot. Then you can reuse the cap assembly someday.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
Logged
1972 Candy Yellow CL100 K2
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
77379
Full Member
Reply #4 on:
January 22, 2017, 06:01:35 PM »
I tried to knock the pins out but the back one was pretty stubborn. It felt like if I hit them any harder something was going to bust off so I put the hammer down and hit them with wd40. After a day of soaking I'll go at them again lightly with the hammer tomorrow. Are those pins the posts that you are referring to?
Logged
b52bombardier1
Hot Shot
Reply #5 on:
January 22, 2017, 06:56:22 PM »
A small drill recently helped me weaken those pins for removal on a tank I'm working on. Replacement pin sets are available on Ebay and probably elsewhere and the replacements use small "C" clips rather than pins that are peened in place. Much easier for future removal.
Rick
Logged
77379
Full Member
Reply #6 on:
January 24, 2017, 02:38:50 PM »
Thanks for the advice. I cut the pins off with the dremmel. I'll be looking for some of those replacement pins on eBay. On an older model 750 I have they are just straight pins that can be punched about and reinstalled with the help of some wd40.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Project Shop
Topic:
