Author Topic: Another name for circlip  (Read 2687 times)
Offline eigenvector
« on: January 23, 2017, 04:14:22 PM »
I'm trying to get a replacement for a circlip I had to remove when working on the alternator shaft on a bike.
Trouble is, looking for them ain't easy.
circlip - the kind without holes in them.  And not the kind you use for piston wrist pins.  Flat circlip.
I'm getting all sorts of hits for snap rings, snap ring pliers, but nothing on circlips.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Another name for circlip
« Reply #1 on: January 23, 2017, 04:29:28 PM »
E-clip?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: January 23, 2017, 04:31:48 PM »
"Jesus Christ Clips"
As in "Jesus Christ where did that clip go flying off to?"  :o
Often heard immediately after freeing said clip from its confines of the assembled position.  ;)
E-clip was going to be my next guess...  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
scrapvalue
« Reply #3 on: January 23, 2017, 04:37:30 PM »
Mr. Clip?
Offline eigenvector
« Reply #4 on: January 23, 2017, 04:50:25 PM »
Jeeze guys!  No wonder I can't find them - no one knows what to call them.
Circlip
https://www.carid.com/images/wp/genuine/w01331742537oes.jpg
If it was an e-clip I could find them all day long.
Seems like the only circlips I can locate are for piston wrists - round profile, wrong type.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #5 on: January 23, 2017, 04:54:57 PM »
Do you check the fiche for the part number?
« Reply #6 on: January 23, 2017, 04:58:18 PM »
C-clip?
« Reply #7 on: January 23, 2017, 05:10:31 PM »
Snap clip?
« Reply #8 on: January 23, 2017, 05:11:12 PM »
I wish I could remember but Fastenal has an array of them
« Reply #9 on: January 23, 2017, 05:12:51 PM »
TAMTF...
Wilbur
Projects:
« Reply #10 on: January 23, 2017, 05:17:23 PM »
"Constant section/snap ring"
Offline eigenvector
« Reply #11 on: January 23, 2017, 05:33:05 PM »
hey there we go!
Just what I was looking for.
Constant Section snap ring.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #12 on: January 23, 2017, 05:36:44 PM »
They are typically used to withstand higher thrust loads. I am used to seeing them in transmissions.
TAMTF...
Wilbur
Projects:
Offline eigenvector
« Reply #13 on: January 23, 2017, 05:51:14 PM »
The Honda OEM clip is junk, which is why I didn't just get it from Honda.  It most definitely has to take a thrust load - 6 heavy Belleville washers cushioning the drive gear for the starter and crankshaft chain.  Overdesigned in my opinion - but it works.
Nighthawk is still getting my goat.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #14 on: January 23, 2017, 05:54:47 PM »
I think I have a tool for installing/removing that style of snap ring? I was told it was a snap ring tool, but never found it's proper use; it didn't work well with either e-clips or the snap rings with the holes on the ends.
Offline eigenvector
« Reply #15 on: January 23, 2017, 07:28:54 PM »
I'll tell you this - the proper tool ain't a screwdriver.  Tried that - have 2 stab wounds in my hand to prove it.
It's a circlip tool, but the ends are weird - ends of the snap ring fit into grooves on the tips of the snap ring tool.  Lets the tool grip the snap ring without it slipping out under tension.  I've never actually seen one - that's just my recollection.
Rob
1977 CB550K
1983 VF750S Sabre
Offline eigenvector
« Reply #16 on: January 23, 2017, 07:32:08 PM »
Just found the other name for them - Retaining ring
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #17 on: January 24, 2017, 05:09:25 AM »
Thank you, I was trying to remember where did I see them before.
Offline DaveBarbier
« Reply #18 on: January 24, 2017, 05:21:02 AM »
Mr. Clip?
I like this one the best, haha.
Monsieur Clíp, right this way!
Edit: Or maybe the clip was knighted... Sir Clip.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #19 on: January 24, 2017, 05:38:22 AM »
There are a couple of them in the CB750 tranny.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline DaveBarbier
« Reply #20 on: January 24, 2017, 05:44:44 AM »
The 650 and I think 550 have them in the starter clutch assembly. I used snap ring pliers and it was a pain.
« Reply #21 on: January 24, 2017, 06:20:48 AM »
Yup, replaced them all when I was troubleshooting Red's shifting problems.
Offline ofreen
« Reply #22 on: January 25, 2017, 07:17:23 PM »
People call these transmission pliers.  They are designed for the snap rings described in this thread.  I bought it when I rebuilt my first transmission over 30 years ago, a three speed in a Mustang.  This one is made by Proto and I think Snap-On has a similar one.  Note when the handles are squeezed the jaws stay parallel and the jaws have divots in them to hold the snap ring ends.  It works great.  A lot of front axles on 4X4's use those rings and this reaches right into the hub and makes removal and replacement a cinch.
« Last Edit: January 25, 2017, 07:18:57 PM by ofreen »
Greg
'75 CB750F
« Reply #23 on: January 26, 2017, 03:19:47 AM »
That reminds me the np435 i had to rebuild to replace the failed T5 in my jeep, it had these circlips too.
I ended up grinding cheap HF pliers to assist me in removal of those circlips.
