Author Topic: K3 Project has now started.  (Read 35185 times)
Re: K3 Project has now started.
« Reply #75 on: July 03, 2017, 09:44:30 PM »
More photos
« Reply #76 on: July 03, 2017, 09:46:28 PM »
The small buffer
« Reply #77 on: July 03, 2017, 09:48:16 PM »
The electrolysis tank for removing rust.
« Reply #78 on: July 03, 2017, 09:50:40 PM »
I will need to repair the steering stops
« Reply #79 on: July 04, 2017, 04:12:19 PM »
Cleaned up the engine some
« Reply #80 on: July 04, 2017, 08:14:52 PM »
Head and cylinders off, no drama. A bit dirty with some blow by
« Reply #81 on: July 04, 2017, 08:15:53 PM »
Before and after in ultrasonic
« Reply #82 on: July 04, 2017, 08:17:02 PM »
Head a bit dirty
« Reply #83 on: July 04, 2017, 08:19:00 PM »
Also getting going on some of the bright work, still have a long way to go.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #84 on: July 05, 2017, 06:04:17 AM »
Looking good.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
« Reply #85 on: July 08, 2017, 09:36:23 PM »
No turning back now. So far internals look fine. I'll be checking clearances, installing new cam chain/tensioner, maybe a primary chain.
« Reply #86 on: July 08, 2017, 09:37:31 PM »
Had to take a break today to cut down a banana tree that was ready.
« Reply #87 on: July 08, 2017, 09:38:34 PM »
Valves and seats need work.
« Reply #88 on: July 08, 2017, 09:44:16 PM »
Cam tension rollers have some nicks, new stuff is on order, that was the main mission for going in, as well as valves, bores and leaks.
« Reply #89 on: July 09, 2017, 09:07:12 AM »
It's mango season, too, right?
« Reply #90 on: July 09, 2017, 09:18:53 AM »
Yes, some of the early ones are ready. My favorite is the Hayden variety which is coming in now. I will give my neighbor some bananas, he has Haydens. I also have papaya in the back yard, which is producing very reliably.
 There are some advantages to living in paradise.
« Reply #91 on: July 09, 2017, 09:20:58 AM »
I don't think this engine was ever opened since the factory built it but the sealant I found is dark brown, much like Permatex. It looks precision applied so I assume it's from the factory.
Offline budman
  • 1914X
« Reply #92 on: July 09, 2017, 10:26:31 AM »
Go OEM on the cam chain tensioner parts.  There have been some problems reported about some of the aftermarket stuff.  Hondman started a thread about it and was doing some experimenting.  Don't know what the results were.
Bud
2021 Indian Scout
Offline budman
  • 1914X
« Reply #93 on: July 09, 2017, 10:30:19 AM »
We knew somebody who had an avocado tree on Maui.  We were frequently gifted with  big bags of avocados.  I remember finding some guavas on the way to Hana once.  They were my favorite, but hard to find.
Bud
2021 Indian Scout
« Reply #94 on: July 09, 2017, 11:12:42 AM »
Do you have a link (just curious).  Was this more focused on manual tensioners like the APE one, or on heavy duty delrin parts like the Cycle Exchange parts?
Offline budman
  • 1914X
« Reply #95 on: July 09, 2017, 11:56:54 AM »
http://forums.sohc4.net/index.php/topic,156601.0.html
Bud
2021 Indian Scout
« Reply #96 on: July 09, 2017, 03:12:39 PM »
Since I'm building a mostly stock K3 I am trying to stick with OEM as much as possible especially engine internals. My 2 over pistons will be the "all Japanese" set from  Yamiya.
Carb kits likewise.
Have to change the Simple Green in the ultrasonic before I go on, I made it pretty dark. It sure saves a lot of time. I put anything in there that will fit.  For even larger parts I have a 5 gallon bucket of it for overnight soaking, which also really helps. SG in that too.
Oh, and about the guavas on the road to Hana. Most are a variety called strawberry guava, now considered invasive (they are). They have imported a bug to help control them.
« Reply #97 on: July 09, 2017, 03:50:04 PM »
I purchased one of the Cycle Exchange racing cam chain tensioners, but never got to building my next 750 motor.  In theory the material (being more durable and heat resistant) should be an improvement over stock.
http://www.cyclexchange.net/camshaftpage.htm
« Reply #98 on: July 09, 2017, 07:41:28 PM »
Looks pretty good. My K3 will likely rarely see the redline. Back in the K0 day I got a thrill out of goading Sportster guys into drag races, they always lost and couldn't figure it out. Not so much any more. I just like the sound of those no number 4 into 4's running up and down, music to my ears. Throw in a little valve clatter  for good measure..now that's a party!
I'm starting my crank and Rod bearing plastigage event next. I hope it goes well, the bearings look almost new.
Also working on the plan to paint the engine. From the looks of it, Honda painted this engine before it was assembled. I may do the same.
« Reply #99 on: July 09, 2017, 07:47:14 PM »
I've been thinking about the first startup. Everyone worries about the time it takes to get the oil up into everything. Of course assembly lube helps but there is always that worry about how long it will take.
What about a power prime through the gallery where we all mount the gauge on the right side? Make a temporary fitting, set up a small pump of some sort with a gauge to monitor and pump the system up until you see oil in the top end. Overkill or crazy?
