Author Topic: "The works"  (Read 1338 times)
Offline lash
"The works"
« on: February 17, 2017, 03:16:24 AM »
As usual you cant buy anything good that works in Canada and it seems that "the Works" is one of them. Anybody know what would be a good substitute?
Re: "The works"
« Reply #1 on: February 17, 2017, 05:02:03 AM »
 Yuk- must be some dirty looking toilets around there------------------- Don't they sell any other brands of toilet cleaner that may contain the same ingredients ?
Offline b52bombardier1
Re: "The works"
« Reply #2 on: February 17, 2017, 05:05:45 AM »
CLR bathroom cleanser used to be good stuff but they took out the phosphoric acid.  Now I buy straight phosphoric acid by the gallon called Prep and Etch. With a little heat, phosphoric acid easily removes rust but does not harm good metal.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: "The works"
« Reply #3 on: February 17, 2017, 08:58:54 AM »
I was going to suggest finding some on ebay....but then I looked.  People are trying to sell these $1.35 bottles of cleaner for $17.00 a bottle online 👿
Offline Desert-SOHC
  • It's old
Re: "The works"
« Reply #4 on: February 17, 2017, 11:20:24 AM »
Evapo-rust works well but takes awhile to eat the rust.  I used it on my Triple A's, everything looked like this...
I still need to soak them longer, but it worked pretty good.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Imago
  • 1978 CB750F
Re: "The works"
« Reply #5 on: February 18, 2017, 06:55:12 PM »
I did a tank this fall and used Apple Cider Vinegar. It's 5% acetic acid. I took off the gas cap, lock and petcock and taped the openings with really sticky duct tape. Inside was a gallon of the vinegar and a six foot length of light dog chain. I rotated the tank and shook it like mad every 6 hours for 3 days... voila! The tank looked like new inside. I immediately rinsed well with 1/2 a box of baking soda in a gallon of water, then rinsed with a garden hose for 10 minutes. I heard that it might flash rust so I sprayed the inside with some engine fogger I had in the garage.
It's now painted and on the bike with a new gas cap. I'm not sure if regular white vinegar is as effective, it's also 5% acetic acid, but I'm now a firm believer in Apple Cider Vinegar.
One tip... I learned to shake the tank directly up and down to get the chain and vinegar to the top of the interior of the tank. It's easy to shake it back and forth but inside the top part directly under the gas cap only gets wet and not struck by the chain to knock the rust loose, without this motion.
« Last Edit: February 18, 2017, 07:04:39 PM by Imago »
  • Holy Cow! I'm a
Re: "The works"
« Reply #6 on: February 18, 2017, 07:04:11 PM »
Word of warning; do not get any of "the works" on chrome.
I got a drop of the stuff on the 750's gas cap and it stained.  I hope it buffs out.
Imago, that sounds like a lotta work with the vinegar.  The works had the yammie's tank cleaned in about 6 hours flat.  I had a 8" length of old 530 chain in there as a scraper.  But didn't have to work nearly as hard as you did!
Metal Rescue seemed to work well on my chrome parts.  Same price as evapo rust.
Offline Imago
  • 1978 CB750F
Re: "The works"
« Reply #7 on: February 18, 2017, 07:07:03 PM »
No doubt, but I'm frugal, need the exercise and can't get the "Works" up here.
Offline toma
Re: "The works"
« Reply #8 on: February 18, 2017, 09:15:09 PM »
The Works jug says that it is hydrogen chloride in water. Which means that it is dilute hydrochloric acid or muriatic acid. If you buy the concentrated Muriatic be careful it is nasty stuff. It eats rust and aluminum and pot metal but really cleans brass carb parts well. Wear eye protection rubber gloves and don't breathe  the fumes.
  • Holy Cow! I'm a
Re: "The works"
« Reply #9 on: February 18, 2017, 10:25:27 PM »
Yay chemisty!  ;D
Offline lash
Re: "The works"
« Reply #10 on: February 19, 2017, 04:18:00 AM »
I use the Metal Restore on other stuff but it would be really expensive to do a tank. I am going to maybe do the vinegar thing or maybe the muriatic acid. Thinking about electrolysis also..
Offline lash
Re: "The works"
« Reply #11 on: February 19, 2017, 04:19:29 AM »
I dont know what the works has in it to compare anything else to.
Offline drumstyx
Re: "The works"
« Reply #12 on: February 19, 2017, 06:19:35 AM »
Prep and etch stuff here didn't have phosphoric acid...I forget what it was. Canada *sucks* for anything chemical. I paid 80 bucks for a gallon of methylene chloride just so I could make a brew similar to berryman chem dip.
If you find something let me know...I ended up using muriatic acid, but the surface rust comes back no matter how well you oil it after
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: "The works"
« Reply #13 on: February 19, 2017, 11:37:15 AM »
I have used molasses to derust a tank. Read about it on several other forums and tried it out. Mix with hot water one part molasses to five parts H2O.
Totally safe for paint and chrome, however, remove the petcock when you use it. let tank sit for 10 days. Works perfect and is cheap and easy to dispose of.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
