Author Topic: CB750 77-78 K and F PD Carburettors  (Read 742 times)
Offline Vin750
« on: January 30, 2017, 05:04:52 AM »
Hi all, I am wondering here if there is any physical difference between the following carburettors:
K7 - PD41A
F2 - PD41B
F3 - PD42A
K8 - PD42B?
It looks to me the last three have the same body but the K7 one appears different. It had a different float height too.
Do they use the same gaskets?
Thanks in advance!
Re: CB750 77-78 K and F PD Carburettors
« Reply #1 on: January 30, 2017, 06:29:08 AM »
Same gaskets.
the 41's have adjustable needle clip positions.
The 42's have fixed needle clips.
Offline Vin750
« Reply #2 on: January 30, 2017, 06:44:31 AM »
Same gaskets.
But isn't the 41A smaller? Why does it have a different float height?
« Reply #3 on: January 30, 2017, 07:10:10 AM »
I cant say if they are smaller.  Never measured either of mine.  I have 41a's and 42b's.  Just interchanged a few parts when needed, and always clear tube checked/adjusted the floats.
Offline Vin750
« Reply #4 on: January 30, 2017, 07:13:43 AM »
If you ever have the opportunity to measure them, it would be much appreciated.
There has to be some difference, the float height would be 12.5mm otherwise.
