Author Topic: 550 Cam Chain Tensioner Installation  (Read 735 times)
Offline Clinto
« on: January 31, 2017, 11:05:03 AM »
I tried searching for this topic, but I remember the search function being a lot better in the past. Doesn't seem to work at all right now.
I need my memory refreshed -- If I want to swap out my cam chain tensioner with a new (to me) one, do I need to lift the cylinders up in order for it to properly slot in? Or can I install it  without lifting the cylinders? Keep in mind, I only want to replace the tensioner, not the guide. I'm trying to avoid having to disturb my cylinder base gasket.
Thanks
77 CB550F2
Offline flatlander
Re: 550 Cam Chain Tensioner Installation
« Reply #1 on: January 31, 2017, 12:10:26 PM »
you'd have to lift it up a little bit. best is also to remove the oil pan to make sure the tensioner is properly seated in its place at the bottom.
you can search in google: yoursearchterm site:http://forums.sohc4.net/
Offline DaveBarbier
« Reply #2 on: January 31, 2017, 07:36:43 PM »
Yeah, it has to be lifted up a bit unfortunately. You can look in with a flash light to see if it hits it's mark but opening the oil pan is a  better way I think.
Offline Clinto
« Reply #3 on: February 01, 2017, 06:14:12 AM »
Ok, that's what I was afraid of. Thanks for the info and thanks for the search tip
77 CB550F2
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: February 03, 2017, 08:09:06 AM »
If you lift it a little bit, chances are the gasket will tear and you will have to pull the jugs off anyway. Might as well plan for it.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
