Author Topic: Need advice: Bike dies shortly after forced bog down. no crank no start.  (Read 2318 times)
Offline _millmo
  • Design Life
    • Portfolio site:
Hi guys,
I'll make this quick.
78 CB550 running a ballistic 8 cell battery, will die one block after letting out the clutch to bog down the bike at a light.  Then, there is a no crank no start.  but...the bike will start immediately after touching the battery with a jumpers from a charged battery.  It's like the starter relay or something) is magically being "reset" and the bike will start immediately via kick (takes more charging to start with the button.
Is that a bad starter relay?  has anyone ever experienced anything like this? Strange problem...
Offline innovativems
    • Innovative MotoSports
Re: Need advice: Bike dies shortly after forced bog down. no crank no start.
« Reply #1 on: February 02, 2017, 07:22:29 AM »
Hi guys,
I think I understand the jest of what you are saying happened.  Does it fire when kicking it?  Does it just click when you hit the starter?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #2 on: February 02, 2017, 07:39:09 AM »
Measure battery voltage at the terminals with the bike off.
Offline _millmo
  • Design Life
    • Portfolio site:
Re: Need advice: Bike dies shortly after forced bog down. Crank/no start.
« Reply #3 on: February 02, 2017, 02:02:31 PM »
It will crank but not start.  And I can kick but no start.
But, if I touch the terminals with jumper cables from another battery I can kick start it (if its warm) and use the button if it has charged sufficiently.
« Last Edit: February 02, 2017, 02:07:57 PM by _millmo »
Offline _millmo
  • Design Life
    • Portfolio site:
« Reply #4 on: February 02, 2017, 02:11:10 PM »
So, the key switch is new, not sure how old the right side controls are (bad button?), and the battery terminals are tight and clean.
« Reply #5 on: February 02, 2017, 02:14:50 PM »
Tell us what your voltage at the battery terminals is
Offline Old Scrambler
« Reply #6 on: February 02, 2017, 03:12:36 PM »
Listen to Flybox..................your charging system (voltage regulator?) is not keeping your battery at full charge. The coils need a certain amount of voltage to fire the points & plugs. With a jump and partial charge, the bike will run but only for a short time and then bog ;) Also, check your plugs, they may be fouled.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline _millmo
  • Design Life
    • Portfolio site:
« Reply #7 on: February 03, 2017, 08:47:53 AM »
From what I remember, the terminals read 10 volts (sorry i thought i wrote that in the first post)
...  Just enough to crank it over once before it dies completely.  With the headlight pulled out it runs fine. Put it in and it drains.  Im on my second reg/rec.  You think the stator needs to be rewound?  Or a new field coil?
Offline _millmo
  • Design Life
    • Portfolio site:
« Reply #8 on: February 04, 2017, 01:07:55 PM »
Awesome flow chart.  Thanks!
Is it possible, that since there are no blinkers or gauges that the blinker wire connectors from the harness could be touching something and drawing from the battery?  I'm not seeing any frayed wires except for some unconnected wires in the HL bucket.
« Reply #9 on: February 04, 2017, 03:15:14 PM »
 Check to see if the coils stay hot when the key is off.
