Author Topic: 1978 750F The start of a big project.  (Read 16149 times)
Offline Jnel
« on: February 07, 2017, 12:34:49 PM »
I've been riding since I was 15 and I'm  62 now.  I've pulled a 750 engine a time or two. Done the timing chain thing.  Messed with the carbs. The normal stuff.
But I'm not going to lie here.  I think I went too far this time.  I've never owned a Cafe Racer and I've always loved the look.  The simple, open frame and the minimalistic approach to the design and function was what got me.
There is nothing simple about building this bike.  The research alone is a ton of work.  I think 3 dimensionally.  I see the finished project in my mind and i know what i want. But knowing what you want and knowing were to find it and bring it together... well that's another story.
Im the second owner of the bike.  The last time it ran was 2002.  Since then it got moverd around, treated terribly and I fully take the blame.  It had some issues back then, but mostly electrical glitches.  As long as you had spare fuses or aluminium foil in you cigarette pack... you were good.
So 14 years without running.  Not even turned over by hand.  But honestly... thats what got me.  I used my hand on the kick starter and it moved freely.  Wow.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline Jnel
Re: 1978 750F The start of a big project.
« Reply #1 on: February 07, 2017, 12:58:20 PM »
Offline Jnel
« Reply #2 on: February 07, 2017, 02:08:25 PM »
Well i did the only thing that I could think of... I took it completely apart.  This way Ill be sure to touch every part.  It's down to the frame now.
Offline Jnel
« Reply #3 on: February 07, 2017, 02:15:57 PM »
« Reply #4 on: February 07, 2017, 05:17:40 PM »
That might have been a little heavy handed.  It's easier to tell what an old bike needs by trying to getting it started and running before breaking it down, but so be it.  Bring on questions.
Offline Jnel
« Reply #5 on: February 08, 2017, 06:07:04 AM »
Take it off! Take it off! Take it off!
Oops, sorry was just trying to help jumpstart this project  :-[
Offline Jnel
« Reply #6 on: February 08, 2017, 06:08:06 AM »
Once I got started... look out.
Offline Jnel
« Reply #7 on: February 08, 2017, 06:09:24 AM »
Pretty rusty
Offline Jnel
« Reply #8 on: February 08, 2017, 06:11:13 AM »
Pretty rusty
Offline Jnel
« Reply #9 on: February 08, 2017, 06:16:17 AM »
I had only two issues on the tear-down.  The rear axle was very hard to remove and i snapped one bolt off on the points cover
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #10 on: February 08, 2017, 07:27:22 AM »
Yikes........
Offline hashvm
  • It's not a lesson without you making mistakes!
« Reply #11 on: February 08, 2017, 07:37:51 AM »
Looks like you got a plan .. good luck
Offline Jnel
« Reply #12 on: February 08, 2017, 08:13:07 AM »
I didn't turn them because I was thinking of getting new drilled disks.  But I hit them with a wire wheel.  They didn't come too bad.
Offline Jnel
« Reply #13 on: February 08, 2017, 08:16:06 AM »
Hashvm... I have no plan.  Nothing!  Only time and beer!  Totally winging it.
Offline Jnel
« Reply #14 on: February 08, 2017, 08:19:37 AM »
Cal.... lets see how this turns out.  Don't worry, I'm not going to bust out the electric drill and put some holes in that disk!    I appreciate your offer.
Offline palepainter
« Reply #15 on: February 08, 2017, 12:04:22 PM »
Beer does help!!
Offline Jnel
« Reply #16 on: February 09, 2017, 07:06:46 AM »
Spokes cleaned up ok.  Rims need some love.
Offline Jnel
« Reply #17 on: February 09, 2017, 08:43:01 AM »
My ears are open for comments on tires.  Please.
« Reply #18 on: February 09, 2017, 08:53:17 AM »
Bridgestone BT45 or Avon Roadriders -- both provide ample grip and durability.
Offline Jnel
« Reply #19 on: February 09, 2017, 09:51:09 AM »
I'm a fan of beefy looking tires. Not sure if im going to be able to get that with the rims that i have.
Offline slikwilli420
  • Master of Disaster
« Reply #20 on: February 09, 2017, 11:02:44 AM »
Matching tire size to rim width is going to be key to any sort of performance. If you want beefier tires, you need wider rims to accommodate that. Stock wheels of the era probably won't do it. Not sure what your budget is, but there are some amazing aftermarket options that really allow you to get what you are after.
« Reply #21 on: February 09, 2017, 02:12:16 PM »
Take a look at the tire manufacturer's web pages for the tires you want.  It will show the recommended rim width for the tires.
Offline Jnel
« Reply #22 on: February 09, 2017, 02:24:30 PM »
Yes.. I was just looking at Bridgestone.
Offline Jnel
« Reply #23 on: February 11, 2017, 12:22:02 PM »
Anyone got an idea on how I can remove a bolt from the points cover?  Of all the things I've removed, this was the only one that gave me a problem.
The top bolt is the problem and its now completely broken off.  Maybe eazy out?
Offline palepainter
« Reply #24 on: February 11, 2017, 02:29:44 PM »
Getting in there and boring it out for ez out is one way.  IF there is enough to weld on to the end of the broken bolt, that works too.  Plus the heat from welding has a tendency to work it loose a bit.  Either way.  Can always try welding first. Then ez out method.  From the looks of that bike, you will be dealing with this a lot.  I can suggest getting an impact driver with proper fitting Phillips to remove those.  The only way mine were coming out and it had zero rust.  Be sure to use anti cease compound on anything going back in.
