Author Topic: 1978 750F The start of a big project.  (Read 18454 times)
Re: 1978 750F The start of a big project.
« Reply #100 on: August 24, 2017, 08:49:20 AM »
What thickness steel did you use to cover the hole and mount the bung?
« Reply #101 on: August 24, 2017, 10:04:44 AM »
To weld up the pinholes, use Silicon Bronze wire. It welds at a lower temp (brazing) and works great for tank work and body work.
Cal,
When my SS tank had pinholes, my metal fab guy welded patches (because there were so many pinholes concentrated in areas of the tank.  How does Brazing work.  Is using the wires a higher temperature version of soldering to fill the holes?
Offline Jnel
« Reply #102 on: August 24, 2017, 10:33:22 AM »
I used the same thickness as the tank. .040.  I gas welded it, thinking the same size metal would be better for heating and less distortion. Even tho, the tank metal was effected more then i care to admit.  The old Japanese was doing some tricks and it was a difficult job.  Hense... no photos.  No proud of the job.  But it passed the leak test.
Sent from my SAMSUNG-SM-G935A using Tapatalk
« Reply #103 on: August 24, 2017, 12:35:35 PM »
No leaks, looks straight primed, functional.  What's not to like? Apparently, nothing a grinder and some filler couldn't sort out.
Offline Jnel
« Reply #104 on: August 24, 2017, 01:19:00 PM »
Exactly what t thought.
