Author Topic: mitshuboshi clutch kit  (Read 1545 times)
Offline MessnerMoto
« on: February 08, 2017, 11:00:00 AM »
Did anybody use this clutch kit ?
http://www.ebay.de/itm/KUPPLUNG-SATZ-HONDA-VERSTARKT-CB750-K-71-78-CB750-F-Heavy-Dutch-Clutch-set-/231282733448?_trksid=p2141725.m3641.l6368
I have it in my possession but I don't know should I put CycleX plates or put this kit and change number of plates also ?
Re: mitshuboshi clutch kit
« Reply #1 on: February 08, 2017, 11:17:20 AM »
I have used something similar.  If all plates look the same,not for K6 and later.
All 8 plates of same model despite my K6-76 must have the outer disk with wider ears. I broke the outer disk twice (2 kits) until I understood that the clutch kit did not match my clutch. K6-76 and later have the outer disk with wider ears.
If not, the ears of the outer disk will have a huge play and it will crack the plate.
I have now std like clutch (cheap from cruzinimage) with Barnett springs
Offline MessnerMoto
« Reply #2 on: February 08, 2017, 03:18:35 PM »
Good point so I cant use this 8 plate kit...
Offline Old Scrambler
« Reply #3 on: February 08, 2017, 06:19:27 PM »
+1 with PeWe............I have a standard HONDA clutch system in my K4 salt-flats motor with Barnett springs. It works ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline MessnerMoto
« Reply #4 on: February 09, 2017, 03:01:37 AM »
Ok I can combine this 2 kits. I will take standard friction plates and longer springs from HD kit. Springs are 43mm... 3mm longer. A little bit thiner...
Also I was thinking is it possible to combine friction plates from this 2 kits. I can combine them to get stack of 8 friction plates and 7 steel ones with first one with bigger ears. And stack can be of same height like oem one. And use oem 40mm springs .. Probably not a good idea....
« Last Edit: February 09, 2017, 03:03:48 AM by MessnerMoto »
