Author Topic: First build new to working on bikes in general. Open to tips, criticism, comment  (Read 5794 times)
Offline calj737
  • I refuse...
Not likely going to make a difference at all. The alternator is what produces the juice, and thats bone stock. You could probably go higher, but that's not really needed. The stock sealed beam is pretty crappy compared to modern lights. If you want a vast improvement, you'd need to also change the reflector and then you could really get after some new, better light. But the H4 is very straightforward swap and noticeable improvement.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
I run an H4 on my 750 as well and it does just fine. I've been interested in the LED lights for a while, like the trucklite, but I just haven't pulled the trigger.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
