Author Topic: This is my first CB750F  (Read 15994 times)
Re: This is my first CB750F
« Reply #25 on: December 05, 2017, 09:39:35 AM »
I thing that will work, but the placement of the seat mounts will force you to snake wiring, etc. underneath.  Obviously, make sure to not place connectors underneath the cross-member/mount so that you don't have any access issues for repair/maintenance.
Offline Johnny340
« Reply #26 on: December 05, 2017, 02:50:56 PM »
Good advice.  Thanks.  The Motogadget should fit perfectly and be accessible in that larger opening towards the rear of the E-box.
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Godffery
  • Godffery's Garage
« Reply #27 on: December 06, 2017, 12:03:33 AM »
 Personally, I'm not having a problem with the use of a round tube on the 750 swingarm. I think trying to use the larger box tubing from another 750 swingarm would have been "Way Over, Overkill".    ;)
 G~
Offline Johnny340
« Reply #28 on: December 06, 2017, 11:02:22 AM »
This is my last mockup before paint and powder coating.  Satin Black frame and something black and silver for the tank and cowl.  My question is, what about the rear brake stay arm?  Black may be too many black bars back there so I was thinking silver stay arm and all calipers??  Ideas?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Godffery
  • Godffery's Garage
« Reply #29 on: December 06, 2017, 02:48:47 PM »
 Your front end is silver so I would say Silver swingarm, Black brake brake stay & calipers.
Offline Johnny340
« Reply #30 on: December 06, 2017, 03:12:45 PM »
I hadn't considered that but it makes sense!  I usually see the swingarm the same colour as the frame..
The only other thing to consider could be an accent colour somewhere.  The 'Honda' tank badge is gold and so is the chain and fittings for the oil tank sight gauge (good suggestion Cafe Racer Fan) but all of that could be changed.  Would a slight accent on the calipers break up the black a bit?
You might want to think about installing a sight glass to be able to check the oil level without having to open the tank.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Godffery
  • Godffery's Garage
« Reply #31 on: December 06, 2017, 08:01:49 PM »
I could see the calipers gold.
You could also have the hardware plated gold zinc for a nice accent.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/Performance+motor+build/WH-118.JPG.html
Offline Johnny340
« Reply #32 on: December 06, 2017, 08:49:40 PM »
That gold zinc looks wicked! What engine is that?
Sent from my iPad using Tapatalk
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Godffery
  • Godffery's Garage
« Reply #33 on: December 07, 2017, 01:31:59 AM »
 That's a CB550 motor I built a few years ago.
Offline Johnny340
« Reply #34 on: January 07, 2018, 05:30:53 PM »
The foot pegs were going to be too low so I moved them up. The old top mount for the rear sets is now the bottom mount.
Finished the licence plate mount, regulator/rectifier mount studs on rear of battery box, and squared off the rear hoop for LED light bar.
Sent from my SM-G930W8 using Tapatalk
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline fireman1073
« Reply #35 on: January 09, 2018, 07:28:43 AM »
Johnny nice work, i have a 75 750f in that red as a future project
it currently has comstars and dual front caliper set from a 79f
right now i am doing a 75 750k
Steve
Offline Bankerdanny
  • Endeavor to persevere
« Reply #36 on: January 11, 2018, 02:39:09 PM »
The ABS should paint fine, but you need to use an adhesion promoter for plastic parts.
Offline Johnny340
« Reply #37 on: February 13, 2018, 09:28:07 AM »
ABS painted fine with adhesion promoter and flex agent.
Coming along..
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
« Reply #38 on: February 13, 2018, 09:44:25 AM »
Dude! That is bada$$!
Thanks Cal! It's starting to take shape.  Wiring soon..  :)
Hey that looks pretty good.  You might want to think about installing a sight glass to be able to check the oil level without having to open the tank.
Thanks for that suggestion!  See pic.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Godffery
  • Godffery's Garage
« Reply #39 on: February 13, 2018, 10:25:43 AM »
 Are you actually putting flaming sculls on this beautiful bike or are you just messing with us to see what the reaction would be?
Offline slikwilli420
  • Master of Disaster
« Reply #40 on: February 13, 2018, 10:28:29 AM »
Coming along..
Bad ass! Is that a wrap or hydro dip?
Offline Johnny340
« Reply #41 on: February 13, 2018, 10:31:45 AM »
Hydro Dip. It stretched a bit at the bottom but turned out pretty well for so many compound corners.  The adhesion promoter and flex agent were for the primer and clear coat on the ABS seat pan/cowl.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
« Reply #42 on: February 22, 2018, 03:43:14 PM »
More progress today.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
« Reply #43 on: February 22, 2018, 03:45:08 PM »
Temp sensor bracket and master cylinder bracket to be powder coated. Front and rear brakes bled, shifter and clutch hooked up today.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
« Reply #44 on: February 22, 2018, 03:46:22 PM »
Motogadget stuff is super high quality!
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #45 on: February 22, 2018, 04:24:35 PM »
Are those the hard or soft M-Grips?
Offline Johnny340
« Reply #46 on: February 22, 2018, 04:27:39 PM »
Soft
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Godffery
  • Godffery's Garage
« Reply #47 on: February 23, 2018, 06:45:20 PM »
Dig'n your solution for the Shifert / RearSet alignment!
« Reply #48 on: February 24, 2018, 12:24:32 AM »
Soft
Cool. Let us know how they work out.  They look grippy but I'm wondering if they offer enough "give" to dampen vibration and combat fatigue.
Offline Johnny340
« Reply #49 on: March 08, 2018, 08:33:28 PM »
Wiring done! It's like cheating using Motogadget.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
