Author Topic: Hello from Southern California  (Read 12783 times)
Offline wolf550
« on: February 16, 2017, 02:56:25 PM »
Hello everyone. Decided to build my first motorcycle back in October 2016 and purchased a 1974 CB550 frame with title from Indiana to bring over here to sunny California.  with a limited budget (no budget at all) I started buying parts. Started with a Shell of Parts from a 1979 CB650. Once it was rolling, i purchased a 1978 CB550 engine and put it in there. Went to local hardware store and bought some wire to make a harness for everything I was going to need on the bike in order to register it. As of January 1st, my motorcycle is officially a California Bike.  But wait, there is more. My bike is by no means a completed motorcycle, but luckily with the cb550 forum I have been able to get the bike to where it is today and be able to putt the bike on down the road for trial and error problems that I have been working out searching this forum.
Current projects on the to do list:
upgrade/replace/fix the charging system components.
Re adjust clutch system after replacing all steel and cork rings (has a drag)
Finish My Fiberglass Seat (did not want to cut anything on the frame)
Top end oil leaks (Think this will end up in a disassembly of the engine to replace with a rebuild kit)
So post a hi and drop some knowledge my way as I will be on here as much as I can searching to get it up and running.
Thanks,
Anthony
I forgot to mention that I have no previous knowledge of motorcycles.
74' CB550 (Sold)
71' CB500/550 (Sold)
Re: Hello from Southern California
« Reply #1 on: February 17, 2017, 05:48:20 AM »
Welcome!
You can download shop manual from this site. it will help you with your project.
Offline Desert-SOHC
  • It's old
« Reply #2 on: February 17, 2017, 11:02:35 AM »
howdy
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: February 17, 2017, 03:42:30 PM »
Top end can be disassembled with engine still mounted on frame.
CB550 K0
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: February 17, 2017, 05:33:03 PM »
Welcome, seems as though you're doing well for no previous knowledge...Larry
Offline Gene
  • Chat enuf you too can be a
« Reply #5 on: February 17, 2017, 05:45:03 PM »
Welcome!  You're in the right place for sure. Where in Southern CA? I'm at the border of LA and Orange Counties.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #6 on: February 19, 2017, 06:41:54 PM »
Down near Trabuco Canyon Area.
Well, you have some nice riding around there - up in the hills (Cleveland National Forest).
*1973 CB750K3 (Bow)
« Reply #7 on: February 19, 2017, 06:43:06 PM »
Welcome to the forum wolf550
Offline Gene
« Reply #8 on: April 17, 2017, 05:58:10 PM »
Dude, move this to the projects section. You'll get way more response.
*1973 CB750K3 (Bow)
« Reply #9 on: April 17, 2017, 07:03:09 PM »
I do not know if it was rebuilt or just not ridden alot cause i did not see alot of build up or sludge etc.
Hey Anthony, the markings on the tops of the pistons mean they are 3mm over-size, so someone has installed a "big-bore" kit. ;D
Offline Gene
« Reply #10 on: April 20, 2017, 01:41:15 PM »
"Go-Fast" parts! That is exciting.
*1973 CB750K3 (Bow)
Offline Can550
« Reply #11 on: April 20, 2017, 02:55:55 PM »
I see that you blocked tach gear opening. Not running a tach ?
How did you close and seal it. I have broken mine and would like to close it until I got one to mount on. Thanks
Offline Can550
« Reply #12 on: April 21, 2017, 08:25:06 PM »
Thanks
Will try doing something similar. Have found a guy here who has more than one but is far. Will wait for him to ship. Meantime will close it. Cheers
Offline jnyrav
« Reply #13 on: April 24, 2017, 11:04:31 PM »
Hey wolf,
looks like you're a bit ahead of me on the 550 build!
We're both in the same area so maybe we'll touch base at some point..
good luck with your build,
john
Offline Scott S
« Reply #14 on: April 25, 2017, 03:20:45 AM »
 There are plugs available. This guy on DTT sells them: http://www.dotheton.com/forum/index.php?topic=22664.0
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #15 on: April 25, 2017, 03:21:19 AM »
 Agreed! Moving it now....and Welcome!
'71 CB500 K0
'81 Yamaha XS650
Offline BLAC
  • An espresso is a
« Reply #16 on: April 27, 2017, 02:09:27 PM »
Happy to see another '74 CB550 in SoCal!  Im up in Los Angeles and have a lot of stock parts off of my '74 project. Let me know what you need
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #17 on: May 02, 2017, 12:21:04 PM »
You can get the rotors re-surfaced and even thinned and drilled (for lightening).
« Reply #18 on: July 18, 2017, 06:18:53 PM »
What type of oil are you using (does it have mineral content)? What are the condition of your clutch springs and plates?
« Reply #19 on: July 19, 2017, 06:50:35 AM »
castrol 4t 10w40
Changed the clutch friction plates and steel plates along with the springs. All are EBC brand.
changed oil couple of times since test riding in past few months. it had black oil when I bought the bike.
first month only rode around neighborhood a few times before oil was dark. the second month changed/ rode around neighborhood a few times. drained and still has that gold brown look so far.
Did you replace the springs when you changed the plates?
« Reply #20 on: July 19, 2017, 11:12:53 AM »
Well, that eliminates 2 of the most common variables.
I assume you installed new OEM springs.  How many plates did you use in your stack?
« Reply #21 on: December 07, 2017, 05:26:25 PM »
How is that foot peg position?  It's pretty far back. What is your height?
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #22 on: December 23, 2017, 10:02:09 PM »
Cool little video bro. That thing is loud!
Where in socal are you? I'm in SD. We should get a bunch of socal guys together someday. Maybe a bikes and coffee..? We have a coffee shop called Cafe Moto here. Maybe a little meet could be setup this spring...
« Last Edit: December 24, 2017, 08:00:29 PM by JoeCooley »
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
« Reply #23 on: January 01, 2018, 08:28:03 PM »
Thnk yu sir!
Bikes and coffee sounds like an awesome idea for South CA!
Up in Trabuco Canyon Near the national forest.
Might need a little time while I figure out a new item on the to do list dealing with oil pressure light.
decided to start rebuilding other engine and almost ready to fire up!
we will see
You have some decent neighborhood roads for testing.
Offline jgger
« Reply #24 on: January 01, 2018, 10:46:33 PM »
How is that rear brake working out pushing on the arm instead pulling? Does it hop or change if you hit a bump? Are you not running a brake light either?
I'm not bagging on you, just never seen one set up like that.
