Author Topic: Under the seat electric box  (Read 1992 times)
Offline jcop550
« on: February 22, 2017, 02:25:53 PM »
Hey guys i need some help. I put an electronic tray under my seat and i was wondering what you did with your electricals to make it all fit. I bought a cognito moto deep electrical tray. I was hoping to keep my stock fuse box etc.
Offline calj737
  • I refuse...
Re: Under the seat electric box
« Reply #1 on: February 22, 2017, 02:28:00 PM »
Usually swapping to a solid state Reg/Rec helps. If you want to keep "all" the stock electricals, it will be snug under there. And I mean snug. You'll also need a much smaller battery or to relocate the battery elsewhere.
Offline 540nova
« Reply #2 on: February 22, 2017, 03:20:30 PM »
I installed my Rick's R/R on the bottom of my tray, saves space inside, and better cooling there. Using a Li-Ion battery saves a ton of space. There are aftermarket fuse solutions that are more compact than factory.
Offline jcop550
« Reply #3 on: February 22, 2017, 03:31:17 PM »
If you guys could send some pictures that would be great. Thanks!
Offline 540nova
« Reply #4 on: February 23, 2017, 03:28:05 AM »
Offline calj737
  • I refuse...
« Reply #5 on: February 23, 2017, 04:20:08 AM »
He's cheating! He's running an M-Unit under there  :o ;D
Offline DaveBarbier
« Reply #6 on: February 23, 2017, 04:35:35 AM »
Here's a two shots of my electrics from couple years ago. This has all the stock wiring in there but with a Rick's reg/rec under the tray. I've got an m-unit now and that really cleans up the mess.
Offline jcop550
« Reply #7 on: February 23, 2017, 04:54:54 AM »
Looks good guys thanks!
Offline 540nova
« Reply #8 on: February 23, 2017, 04:58:54 AM »
Jcop550, looking at Dave's pix, you can see some of the fuse holders I was referring to. If you choose soft pvc wire sheaths, it'll save a lot of space over the rigid tubular sheathing Dave used.
Offline jcop550
« Reply #9 on: February 23, 2017, 05:01:16 AM »
Thanks i will do that to free up some space. I was messing with it last night and i think ill be able to fit it all with the reg/rec under the box. Just waiting on my battery to come in so i can see if it works or not.
Offline Jnel
« Reply #10 on: February 23, 2017, 05:07:53 AM »
Dave... what did you do for the oil tank? I'm so up in the air about this.
Offline DaveBarbier
« Reply #11 on: February 23, 2017, 05:13:52 AM »
550 has no oil tank :))
Offline DaveBarbier
« Reply #12 on: February 23, 2017, 05:20:51 AM »
This may be what Nova is talking about. That split corrugated loom is awful stuff. I ordered a sh*t load of the expandable polyester sleeving from McMaster Carr.
You can see the stuff in my new wiring.
Offline jcop550
« Reply #13 on: February 23, 2017, 05:26:31 AM »
I have to fit all of that and a battery in a small box. I dont have any extra space unfortunately.
Offline 540nova
« Reply #14 on: February 23, 2017, 05:27:06 AM »
Looks great, Dave!
Offline Jnel
« Reply #15 on: February 23, 2017, 05:50:09 AM »
550 no tank.... i see.  Didn't know this.  I wish i could say the same for the 750.  Life would be easier with out it.
Offline Jnel
« Reply #16 on: February 23, 2017, 05:52:09 AM »
This is a great post and is just what im looking for.   Thank you Dave.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline 540nova
« Reply #17 on: February 23, 2017, 05:53:02 AM »
That CM box is so short, I'd make your own, even if it entails removing the horizontal bracing. If you remove the bracing, and weld in a full length box, it would provide more bracing than factory, anyway. That's what I did.
Offline jcop550
« Reply #18 on: February 23, 2017, 06:02:40 AM »
Didnt think about removing the brace. Maybe ill try that and rig something new up. Thanks
Offline 540nova
« Reply #19 on: February 23, 2017, 06:13:27 AM »
Tie a full length, shallow box into both seat rails, and yo'll increase rigidity in the frame. Win/win.
