Author Topic: throttle sleeve and grip advice  (Read 1198 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: February 24, 2017, 08:50:38 PM »
took grip off old broken throttle sleeve with wd40.  it was on tight.  got the new throttle sleeve on bike and working.  when trying to reinstall grip to new throttle sleeve the grip seems too big.  spins on the throttle sleeve.  any advice?  throttle sleeve fits bars perfectly and i've been riding without a grip on that side.
cb750 k6 - ugly
Re: throttle sleeve and grip advice
« Reply #1 on: February 24, 2017, 09:03:35 PM »
Offline firebane
« Reply #2 on: February 24, 2017, 09:05:29 PM »
Sounds like a grip for a larger tube. Most grips for 7/8 bars has a smaller and larger as per the proper side.
Offline evinrude7
  • not a kung-fu
« Reply #3 on: February 24, 2017, 10:19:41 PM »
so i should measure the diameter of the throttle tube before selecting a set of grips?
cb750 k6 - ugly
« Reply #4 on: February 25, 2017, 04:51:16 AM »
Buy new grips. I love Pro Grips....
https://www.amazon.com/Progrip-714BK-Black-125mm-Sport/dp/B000WO8MKY
+1 on those grips !  A friend of mine gave me a new pair of those as a gift once with a sly smile and a laugh after we went for a ride together  and I showed him the 'waffle' marks in my hands from some old half worn out stockers. Pair came on my mighty Kaw Z1 also and they are comfy.
« Reply #5 on: February 25, 2017, 05:08:23 AM »
Throttle tube is 1", handle bars are 7/8".    Grips are not made to be reusable, the WD may have caused a reaction.
I installed em on my mighty Z1 too, Eric.
Offline evinrude7
  • not a kung-fu
« Reply #6 on: February 25, 2017, 06:17:37 AM »
thanks for the advice.  bought a pair of oury's last night.
cb750 k6 - ugly
« Reply #7 on: February 25, 2017, 06:37:43 AM »
Those get good reviews here too.  I plan to try a set.
BTW - use aerosol hair spray when installing them. And check throttle tube length BEFORE install, you may need to trim it.
Offline evinrude7
  • not a kung-fu
« Reply #8 on: February 25, 2017, 11:28:30 AM »
thanks stev-o.  i kinda sorta figured i might need to trim the sleeve a hair.
cb750 k6 - ugly
