Author Topic: Front Fork "piston rings"  (Read 884 times)
Offline Ericcb750
« on: February 23, 2017, 11:47:14 AM »
Hey Guys,  Have a quick question to see if anyone replaces these when re-building their front forks..... I am putting together a set of 78K forks and I have a New Progressive Spring kit, new Fork oil, new OEM Honda fork seals installed, new rubber boots/caps.....
The last thing i was wondering about is the little Fiber type rings (slant groove/cut in them) that are at the top of the damper/piston.....Do you guys normally change those out? Mine are not damaged in any way but i wasn't sure if they "wear out" and cause oil to leak past or anything like that.... Couldn't seem to find too much info on these little buggers.
Thanks for the help guys, I appreciate it.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline emlupi
Re: Front Fork "piston rings"
« Reply #1 on: February 23, 2017, 12:13:15 PM »
When I refurbished my forks I replaced the piston rings. They are inexpensive and very easy to install. My thought was, if I'm going to take it all apart and then refresh the seals, etc., why not these rings as well?
Offline jamesw
« Reply #2 on: February 23, 2017, 01:07:03 PM »
Can't really be of any help, because I'm curious as well.
I opted to replace mine when I refurbished my K5 750 forks just to be safe.
Debatable if I'd do it again for the next forks.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline drumstyx
« Reply #3 on: February 23, 2017, 01:15:31 PM »
I didn't, because I'm not really expecting much from these forks, not to mention that I'll probably be replacing the tubes in a year or two anyway, due to minor pitting.
« Reply #4 on: February 23, 2017, 02:28:40 PM »
The last damper seals I bought were slightly undersize, obviously Honda combining model parts. Ideally the damper rod won't slide through the fork tube under it's own weight.
Offline Ericcb750
« Reply #5 on: February 24, 2017, 12:52:09 AM »
Thanks fellas, I wasn't really sure if they had any "sealing" effect on the forks in any way. I'll just snag a pair and call it a day. May as well considering i just spent so much time sanding down the legs and polishing them, new seals, springs, etc.
I always appreciate the help guys, Thank you.
1978 CB750K
2005 Sportster 1208
