just went thru the carbs pretty well. they're clean. still having issue with idle and cutting out. unless i have the idle screw set at or above 1200 rpm it seems to want to die. also, after riding for a bit the bike idles up around 2000 rpm and i have to back the screw out to get the rpms down. any ideas? throttle play never seems to change and i believe it's within spec.
waiting on stock air box from ebay. currently crappy pods.
