Author Topic: Jet size for 4 into 1 exhaust and tuning  (Read 2322 times)
Offline Variantbuilder
« on: February 27, 2017, 09:26:55 PM »
Hey Everyone, this is my first build, I own a 75 Honda CB750, I have so many questions and some of them are hard to trace through all the threads out there. One question I have is what gauge wire is used for the positive terminal on the battery? And 2, I have four into 1 exhaust thinking of just straight piping and was wondering about the jets? need a different size? I do have pods as well, I know that has to be taken into consideration. How do I tune them up properly?
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
Re: Jet size for 4 into 1 exhaust and tuning
« Reply #1 on: February 27, 2017, 09:51:17 PM »
I think the search function is still buggered here on the forums. So, the best way for you to search for some answers is to go to your browser search engine and type in FORUMS.SOHC4.NET JET SIZING TIPS this will get you started. I'm so glad I got here first and you didn't ask about oil.  :)
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #2 on: February 27, 2017, 09:52:09 PM »
BTW, good luck! Rick.
1995 EG6
« Reply #3 on: February 27, 2017, 10:26:42 PM »
Hey thanks Rick! I appreciate it!
Offline FGKouki
« Reply #4 on: February 28, 2017, 08:21:53 AM »
Rebuild the carbs, put the jet needle clips at the factory spots, factory jets (cleaned) and go from there.  The parts wear differently and compression/age will affect fueling to a large degree.  With stock airbox and 4-1 open exhaust I've had good results going up 1 or 2 main jet sizes and leaving the idle jets alone. Mixture screws turned out maybe 1/2 or 3/4 turn but that takes some tinkering with.
Offline Jnel
« Reply #5 on: February 28, 2017, 12:31:03 PM »
Since this is kind of a carburetor question can anyone tell me on the low speed Jets after you turn them in and bottom of mouth what didn't normal amount of turns out is?
I was Dumb and didn't check it before I back them all the way out to clean
Offline Jnel
« Reply #6 on: February 28, 2017, 12:32:04 PM »
I swear I wasn't drinking when I typed that text.
Voice to text is not an exact
