If I can add more variety to this thread, and maybe help someone else, I've been wrestling with my K2, it has 657A carbs, needle in the mid position, 110 mains, 40 slows, stock air box and paper filter, floats at 26mm and pretty open 4/2 exhaust. I've been trying to stop the decel popping, I was having the stumble off idle from the lights etc but it's not a real problem compared to the popping.
After Mark saying that turning out the screw richens the mix because it adds more air thereby adding more fuel, I've been trying to figure out whether I need bigger or smaller pilot jets, turning the screws out does nothing to remedy the popping, right now I have them 1/4 turn out and the popping has improved unless I down shift at higher revs, then I get a bit of burbling but it's much improved. So just to help me and maybe someone else, before I shell out for new pilot jets, do I need a 42 pilot jet now or 35/38, If I listen to every body else I'm figuring 42? but according to Mark's theory, I have leaned the mix by turning in and would now want smaller pilots, it does my head in I tell ya.
Cheers.
