Author Topic: 72 CB750 stumble off idle when hot  (Read 19220 times)
Offline KeithB
Re: 72 CB750 stumble off idle when hot
« Reply #25 on: March 10, 2017, 04:26:25 AM »
I'm pretty sure yours will be on the airbox side, meaning 3 turns out is leaning it out pretty much to (if not past) the the max adjustment range of the screw.
They are on the airbox side and I do understand that 3 turns out is drastic. However, the results were quite clear.
That is why I am considering the leaner pilot jets.
Hondaman...I will double check timing items you mentioned. It is my impression that the timing seems to advance rather quickly (watching with strobe) and I do remember reading of a "cut spring" mod to tighten the advancer springs. One thing at a time. I think I did that on my other '72 build.
Can't really do too much until I can get back out on the road.
-5C is a bit chilly  :o
Nanahan Man
Offline markreimer
« Reply #26 on: March 10, 2017, 05:16:48 AM »
Got up this morning and it was -19C. Last weekend I was out riding my 750. What's going on!?
« Reply #27 on: March 10, 2017, 10:37:06 PM »
Several things to look at:
Air screws: 7-8 to 1-1/8 turn out on the 657 series carbs.
At 1.5 turns out they are fully as rich as they will possibly go, at 3/4 turn out they are as lean as they will get and still run.
If you notice a further difference in performance beyond these ranges, something else (like jet size or float levels) is not right. Float levels should be 25-26mm for smoothest performance, 24mm with perfect float valves and hotter plugs will raise the low-end torque a little bit.
When the low-end is very rich, as yours now is, it will stumble at the point where the slide is open too far for the engine speed at that mixture. Another thing on the K0-K2 that makes this happen is: the spark advancer springs are too soft (or even loose) and/or the shim washers underneath the points cam are gone, letting the cam wobble at low speed and then straighten up at about 1800 RPM. This sudden timing shift (backward) as it straightens up causes the stumble.
Hondaman, I thought turning the screws out let more air in, leaning the mixture. You're saying it richens the mixture. I have the 657B carbs off a '74k and the screws are on the airbox side of the carb. Prettt sure opening them up leans the mixture?
I get this comment every Spring (and summer, winter, fall...)....no.
Here's how these carbs work, as outlined in my book (plus some of the stuff I left out at that time):
There are 3 pressure zones in these carbs. The highest pressure is outside air, pushing its way into the float bowls thru the little vent hoses. These hose must be routed to a quiet place, like up under the seat or behind the airbox, to work right above 40 MPH.
The second-highest pressure, which MUST be lower than the outside air pressure, is the air inside the emulsifier jets. This air comes into those jets on the idle side thru the air screw, and for the mainjet thru the little (brass) hole in the bell, running up to the main jet's emulsifer (some folks call this the "mainjet holder").
The lowest pressure is found under the slide of the carb, lowest at the front where it pinches off the throttle (this is called "throttling the air flow") air to the engine.
When these engines runs a single carb on a single cylinder like they do, there is a very short low-pressure "event" during the intake stroke, which is about 20% of the total time for a cylinder (I note this because it is NOT a steady vacuum, like in a car engine with one carb feeding many cylinders where the vacuum is constant, and where the metering system is VERY different for these). During the very short suction pulse at low engine speeds (below 1/4 throttle), the idle jet has to supply LOTS of gas for a short time to make up the 8:1 air-to-fuel mix needed to make these engine start, so the idle circuit has a large opening at the air screw and a separate emulsifier (right on the pilot jet), pointed directly under the highest suction point at the engine edge of the slide. When you then average out this 8:1 mixture for 20% of the run time of one engine cycle, you get close to 12:1 A:F mix ratio for the power cycle. So, they run very rich up to about 1/8 throttle, just so the engine can idle: it has to taper quickly from 8:1 at idle to about 12:1 by 1/4 throttle, so it has a natural tendency to feel slightly flatter as the throttle begins to open (i.e., without an accelerator pump, like the post-1975 engines have).
The "push" that puts the fuel up the throat is: the higher pressure inside the emulsifier tube, compared to the lower pressure in the throat above it. No, the engine isn't "sucking in the fuel" like a car engine (it's just sucking air): the carb is actually squirting fuel up into the throat AFTER the intake valve has closed, wetting the whole area. Then the NEXT intake stroke collects that wetness. I have seen hi-speed camera videos of this (in 1969-1970 in college), it really does happen this way...the "push" comes from having air pressure enough outside the emulsifier's holes to push the fuel up the center of the jet, which itself pushed up to the inside of that emulsifier from the bowl (thru the jet hole) when the previous intake stroke left a lower pressure (suction) momentarily inside the emulsifier's chamber. This "pumps" the gas from the bowl up into the center of the emulsifier, where the air pressure from the air screw then pushes a little more (and aerates it, too) up the tiny hole under the slide, just AFTER the last intake stroke happened. This makes a vapor-like blast appear above the tiny hole by the slide, which wets everything: if you take off the carbs and look, you can see this pattern where it makes a clean area in a vee shape toward the engine.
Now...about the air screw: if the air screw closes off all the air, the bowl has to try to push the fuel all the way up the jet to the throat: with the tiny hole involved, it doesn't get all the way up. The weight of the fuel makes it tend to simply block off the idle jets' metering hole, instead. As the air screw starts to open (about 1/2 turn) the fuel gets enough air to lighten (aerate) it in the emulsifier at each intake stroke to bubble up, but there is not yet enough air to help push it all up the throat. As the screw approaches 1 turn, it is close to optimized for the size of the aeration holes you see in the pilot jets, and the fuel erupts into a wet plume in a bloom of vapor as it exits the hole into the throat. Opening the screw a little more, until the most air possible is passing thru the emulsifier holes (about 1.5 turns) adds a little more lift and slightly more fuel, draining the tiny emulsifier in that one stroke: beyond that, the air becomes too much and it breaks up the vacuum in the tiny throat hole and the fuel stops moving any faster because it is limited by the size of the pilot jet's feed hole (#40). It thus reaches the rich-as-it-can-breathe point, and no further air will go thru the holes to the jets, even if the air screw is fully removed. After about 1.75 turns, this is the result. So, it gets a little richer by about 1.5 turn or so, but no richer beyond that - IF THE CARB IS WORKING CORRECTLY (i.e. it is CLEAN).
Now - IF your air screws ARE making a difference beyond 1.5 turns, then something else is wrong, which is usually blocked air passages. These can be in the carb's body between the air screw and the idle jet, or the throat's tiny hole, or the emulsifier holes in the pilot jet itself, or the pilot jet's tiny hole might be calcified, or the float bowl level might be too low. So, cleanliness in the idle circuit is VITAL to make these things behave as they are supposed to, and if not, all sorts of confusing symptoms arise. And, this circuit has more to do with the way these bikes operate than the mainjet circuit does, until 4000 RPM.
Moving onto the mainjet: I have actually seen the air passage from the bell area of these carbs to the main emulsifier COMPLETELY blocked before: even on my own bike after it sat 5 years while I beat cancer. It corroded itself closed from moisture and being "put away wet" once too often. When this happens, no amount of adjusting ANYTHING will make it run right. This passage has a small brass port in the bell area where the incoming air is the highest possible pressure available (the quiet "donut" area outside the venturi) so it can push a lot of air into the emulsifiers in the mainjet circuit. A lot more fuel must run up this circuit, so more heavy lifting is needed: this air is about 3% less than the bowl pressure, so the holes in this emulsifier are much, much bigger than in the pilot jet (where the pressure difference is closer to 6%) to help lift the fuel. Again, if these holes, especially the larger upper holes, are narrowed by calcification or just plain crud, then the fuel will not start lifting at about 2500 RPM (1/4 throttle) very well, and the bike stumbles as the idle circuit starts to fall lean and this circuit isn't doing its job yet. Aside from the afore-mentioned cleanliness "fix" for this, lighter fuels (e.g., ethanol) tend to wet the emulsifier too much, so adding slightly larger holes (or at least REALLY cleaning the existing ones) will help dry it out a little more so it will blend better with the waning idle circuit. This improves the flat spot often felt on these bikes after they have been sitting too long without some carb love.
Sometimes riders try to change the jetting to "fix" a problem that was never there. All of the 750 bikes before the ill-fated K8-F3 series were too rich, resulting in fouled plugs as a constant problem: when the carbs get a little dirty in these passages, this gets worse, quickly. In fact: when the 750 first came out, it had 120 mainjets with .033" (large size) holes in the emulsifiers: you could not ride more than 1000 miles before changing the fouled black plugs. The first "fix" for this was: Honda switched to 115 mainjets and lowered the floats from 24mm (as measured in the 'modern' manuals) to 25mm, then by the diecast 750 the floats were always staggered with one set at 24 and one at 25mm, every set. In the mid-year K1 they again lowered the mainjet to 110 size and simultaneously opened up the emulsifier holes to .035" in all 8 larger holes. This allowed the fuel to be blown out of the engine with a shot up the freeway ramps, and Honda issued a Service Bulletin suggesting the "...ride the bike more spiritedly..." technique be told to the owners. Bankers and lawyers didn't appreciate it, but we did... :)   At this time, the airbox became a little bit more restrictive (still had the HM300 pipes) so as to increase the operating range of the idle air screw more toward 4000 RPM, causing it to run slightly leaner in the upper range of the idle circuit, before the mainjet started its thing.
The K2 started out like the K1 with #110 mainjets and staggered-height brass floats (like mine), but the last of the K2 had #105 mainjets and plastic floats all set to 26mm height for a leaner burn with the new HM341 pipes.
When the K3 midyear changes came out (around 1/73) there was a big change in the carbs. The idle air screws lost their little air hole in their tips, which effectively pinched back the airflow for any given setting and also stretched out their effective RPM range. At this time the mainjets also dropped to 105 size, and the floats were adjusted leaner to 26mm, with both (usually plastic) floats at the same setting. This effectively stretched the idle air screw's adjustment authority to about 3500 RPM, and a flat spot developed in the performance between 3500 and 4500. BUT...the sparkplugs were finally staying a lot cleaner, especially at the 55 MPH freeway speeds we were all stuck with in those days. Some riders rode more than a whole season on one set of plugs, which up until then was unheard of in this bike! In the K4 the spark advancer was changed to enhance this effect (slower advance curve), the rest being history and legend.
These are all just notes from my old shop notebook that didn't quite make it into my book, as I thought at the time that no one would be interested. Sometimes I wish I DID put it in, to help quell this confusion that the Internet still keeps alive.
So, it boils down to this: on all of Honda's carb'd bikes before 1988 (at which time I quit keeping track), the idle air screw makes it go LEANER when turned inward, RICHER when turned outward, and they have a very limited range because the air passages they control are very small. AND...these passages get "re-tuned" by dirt, very little of it, so use a good air filter! ;)
Offline KeithB
« Reply #28 on: March 11, 2017, 03:51:38 AM »
Much to consider. Thanks for taking the time to post. I have to re-think my trouble shooting method.
So, as I gather, turning the air screws out allows for more air which actually improves (richens) the fueling of the idle cct .
Also, 120 mains are not stock and I should probably step back down to 110s.
« Last Edit: March 11, 2017, 03:55:43 AM by KeithB »
Nanahan Man
Offline markreimer
« Reply #29 on: March 16, 2017, 04:32:50 PM »
Ahhh, so while it's true turning the screw OUT lets more air through, the end effect is richening the mixture because of the resulting increased lift? I believe I understand it now. And makes a lot of sense why so many people are confused about that screw. Thanks Hondaman!  8)
« Reply #30 on: March 16, 2017, 06:59:23 PM »
I think this whole misunderstanding got started from the Jinglish found in the old Shop Manuals (mainly for the Singles, like CB100, etc.), where it states "...to adjust richness, turn screw inward...". But, I was learning some Japanese in those days for my future work with SONY, and I understood from their grammar that this meant, in our expanded English, "...in CASE of over-richness, turn screw inward...". These comments were usually added because the bikes had a tendency to vibrate the air screws outward over time (my SuperHawk did this weekly), so we were all constantly resetting them in those days.
« Reply #31 on: March 16, 2017, 07:43:07 PM »
John Robinson's "Fuel Systems Techbook" states turning the air screw ( located upstream of the throttle valve) in richens the mixture.....turning out weakens the pilot mixture.
 That is the way I have done it for about 45 years and that is the way it works on my modern FCR carbs (which has idle fuel screws and idle air mixture screws). Fuel mixture screws turned out richen and air screws turned in richen unless every tuning book I have ever read and all the carbs I have tuned are wrong.
Offline markreimer
« Reply #32 on: March 16, 2017, 08:17:39 PM »
Oh great. If you two can't agree on it, there is no hope for the rest of us!!
Offline kmb69
« Reply #33 on: March 16, 2017, 08:40:28 PM »
+1. That's how they have worked for me for the last 50+ years.
« Reply #34 on: March 17, 2017, 07:27:08 AM »
THIS^^^
+100...but  you gotta have a basic understanding of a fuel screw vs an air screw  ;)
« Reply #35 on: March 17, 2017, 11:36:55 AM »
THIS^^^
No argument here either.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #36 on: March 19, 2017, 06:09:37 AM »
Wow, I wonder why my 18 to 1 at idle with Georges bored out carbs went much better A/F on the DYNO when I turned the screws almost shut.....the carbs musta been in the " Beam me up Scotty zone"! ;D Next time I have a stock carb bike on a dyno or Wego we shall document such .....As the World/Screw turns! Very interesting read on the carbs though, stay tuned rich or lean , y'all ride on! Bill
BentON Racing Website
BentON Racing Facebook
Offline KeithB
« Reply #37 on: April 02, 2017, 03:54:15 AM »
Well, what ever they do, turning mine out eliminated the stumble off idle. (40 idle jet)
Had the bike out yesterday and it runs great. No stumble, no flat spots.
Need to get out on the highway and do a plug chop to see how the mixture is on the main jet.
Nanahan Man
« Reply #38 on: April 04, 2017, 07:12:22 PM »
Like I said, every time I post this truth, I get arguments...but I know 100% dead-sure that the ones on the SOHC4 bikes and all the earlier Hondas with the Keihin carbs work as I described above. And, it works this way on every SOHC4 that I have ever built. ;)
Offline KeithB
« Reply #39 on: April 06, 2017, 03:38:00 AM »
The truth will set you free.....of stumble off idle! ;D ;D
So if I am to understand this correctly, by turning out the screws and eliminating the stumble, I should be going to a larger pilot jet.
Any thoughts on what jet might be suitable considering I had to go 3 turns out?
Nanahan Man
« Reply #40 on: April 06, 2017, 06:46:53 AM »
I still dont think you have a grasp of IMS adjustment.
If you turn them OUT...you lean out the mixture.  If three turns out wont get you lean enough, you have to go SMALLER in pilot jet size.  Not larger.
If you have 40's in there now, and the stumble is gone....move right to 1/4 throttle position plug chop to verify your pilot jets are adequate.
Post a plug tip picture of your 1/4 chop.
Offline KeithB
« Reply #41 on: April 06, 2017, 10:56:18 AM »
See, here is the problem.
There are 2 differing explanations of the air screw adjustment results.
One offers more fuel with screws out and the other is the opposite.
On a side note, the pilot jets, I have found available, for this carb do not go below 38 but there are options up to 55.
Makes one wonder what is called for more often.
So yes, I don't understand and am now stepping away to work it out on my own.
Thanks to all for your replies.
Nanahan Man
« Reply #42 on: April 06, 2017, 11:21:01 AM »
One offers more fuel with screws out and the other is the opposite.  Correct, because there are two different types of carbs.  One group  where OUT means leaner(yours), and the other group where OUT means richer(like my K8's PD carbs).  I'd still like to see a picture of a set of plugs after an idle plug chop as you have it set up now ...please post one.
Makes one wonder what is called for more often.  no one 'decreases' performance of an engine...so there really is no need for smaller jets  ;D
Offline KeithB
« Reply #43 on: April 06, 2017, 12:00:19 PM »
from your posts...
Just adds to confusion.
Nanahan Man
Offline markreimer
« Reply #44 on: April 06, 2017, 12:05:33 PM »
You're right that there are two different style of carbs, but what he's saying is in this thread, there are two different claims for the SAME carb. Hondaman is saying turns out = richer. Others say turns out = leaner. Both have put forward compelling arguments.
Someone just needs to do a few plug chops or better yet measure with an a/f sensor and put the debate to rest!!
« Reply #45 on: April 06, 2017, 01:15:47 PM »
Honda is saying to 'tune out' any rich condition, turn the IMS out..
...and thats how it works if the IMS is on the AIRBOX side of the carb slide....it controls an AIR passageway.
A fully seated IMS closes this passageway.  You are getting the richest A/F mixture allowed.
Slowly turning the IMS out, adds air to the mixture....making it leaner.   Once the IMS is out about 2.5 turns, it cannot open the air passage any more.
If you are starting with an overly rich condition, or a pilot jet letting in too much fuel, and 2+ turns out cannot lean out this A/F mixture to appropriate levels, you have to decrease the amount of fuel allowed in, so we reduce the the size of the pilot jet.
If the IMS is on the engine side of the carb slide it controls fuel allowed into the carb throat at idle...IN is less fuel (leaner), It closes the passageway.  Out allows more fuel into the circuit.
KeithB....do an idle plug chop and post pictures please.
Offline markreimer
« Reply #46 on: April 06, 2017, 01:38:09 PM »
That is also how I had understood it to work.
Photos of results please!
Offline Nic
« Reply #47 on: April 06, 2017, 03:01:46 PM »
Who dares to disbelieve the master :o
« Reply #48 on: April 06, 2017, 04:03:54 PM »
There should be NO MORE than 0.008" worst case clearance between the face of the advancer cam and the back of the big nut.
A third thing: if the timing of the spark (especially on the 2-3 points) jitters back-and-forth under a timing light, the long bolt under the spark advancer is bent. This can be straightened, but it got that way from pulling the big nut CCW with the sparkplugs installed. This should be no more than 0.002" out-of-round, or the spark advancer tilts, causing the cam to bind at low speeds, then unbind above about 2k RPM, causing a stumble, too.
This always seems to turn into an argument....turning the screws inward leans it out. Trust it. ;)
Offline KeithB
« Reply #49 on: April 28, 2017, 06:46:19 AM »
Further testing....40 pilot 120 mains
Keeping the "what does the air screw do " argument aside, here is what I found out.
Screws out 2.5 to 3 turns clears the stumble off idle but starting is a #$%*.
Screws 1.5 turns out starts easy but stumble off idle returns.
With the stumble, if I gently add throttle the RPM comes up nicely but if I try to come off the line in a reasonably normal way, the engine bogs.
Checked the plugs with an idle test and it doesn't show an overly rich or lean condition but I don't have a stock of new plugs to keep testing.
Could this be a needle position issue?
Looking for a course of action.
BTW...did the advance spring cut mod and now the engine comes back to idle much better. They were very loose and timing was advancing too soon.
Nanahan Man
