Author Topic: Question about spokes  (Read 833 times)
Offline Xavier823
« on: January 10, 2017, 07:41:30 PM »
I am restoring a CB500K and want to replace the spokes, would CB750K spokes fit on my CB500K?
-Thank you
Offline chewbacca5000
  • I polish covers!
Re: Question about spokes
« Reply #1 on: January 18, 2017, 10:02:52 AM »
The 500/550 is 36 hole the 750 is 40 hole so I would have to say no.
Offline hondaron
« Reply #2 on: January 18, 2017, 10:11:31 AM »
The front is exactly the same as a 750, the rear hub on a 500/550 requires different spokes than the 750, but is 40 hole.
I used 750 rim on my CB500, as it is 2.15 compared to the 1.85 that is stock on the CB500/550
« Reply #3 on: January 18, 2017, 11:14:44 AM »
450,500, 550, 750, 1000 wire wheels all. Use same hub..   But 77/78......looks diffferent.. But still interchanges..
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: January 18, 2017, 02:36:40 PM »
I just laced up a set of wheels for a buddy of mine.  He has a 500.   We used a set of spokes from one of my 750s
« Reply #5 on: January 18, 2017, 03:39:09 PM »
Hey Frank...I've noticed that too. Any idea why they made that change?
Offline jonda500
« Reply #6 on: January 18, 2017, 04:23:53 PM »
-Thank you
The front are the same, the rear may have different length elbows?
John
A starter clutch thread:
« Reply #7 on: January 18, 2017, 05:02:44 PM »
Isn't the backing plate on the later rear hub also different?
 What struck me as odd is the ribs on the hub circumference are un-needed on a disc brake setup and yet the front hub has them.  A drum brake needs the cooling area/ benefits from it...disc brakes do not.  I wonder if it is merely to give them symmetry?
Offline Xavier823
« Reply #8 on: March 01, 2017, 01:01:18 PM »
Sorry, I haven't posted a response. Thank you all for replying. I finally got a break from school/work and was able to order spokes for a CB750 and they worked perfectly on my CB500 hubs and rims.  :D :D
