Author Topic: How Do I Mount My Rear Signal Lights Now?  (Read 1238 times)
Offline Imago
  • 1978 CB750F
« on: February 28, 2017, 03:35:49 PM »
The PO basically snapped off the tabs on the grab bar where the rear signal lights attach. 1976 CB750K.
I ground down the mess left on both sides with my angle grinder, (see photo) but what/how should I mount rear signal lights?
Are there any after market LED's that don't need to be mounted in this location?
« Last Edit: February 28, 2017, 03:37:39 PM by Imago »
Offline chewbacca5000
  • I polish covers!
Re: How Do I Mount My Rear Signal Lights Now?
« Reply #1 on: February 28, 2017, 03:55:01 PM »
Make a bracket out of piece of flat steel and mount it to the license plate bracket the mount your turn signals to your new bracket.  15 minute job.
« Reply #2 on: February 28, 2017, 04:05:56 PM »
I dont run signal lights, my arm still works.
Offline Imago
  • 1978 CB750F
« Reply #3 on: February 28, 2017, 04:38:53 PM »
Ya, but you're not as old as me...  ::)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #4 on: February 28, 2017, 06:33:49 PM »
imago, what about something like this?  http://www.ebay.com/itm/Motorcycle-TURN-SIGNAL-Relocater-Holder-Fork-Clamps-Shock-Bracket-For-Cafe-Racer-/152192140652  obviously have to find ones that fit the diameter of the grab bar.  or you could always have new tabs welded on or better yet find that grab bar.  i think i know someone who has one for a 76.  let me look.
« Last Edit: February 28, 2017, 06:35:33 PM by evinrude7 »
cb750 k6 - ugly
Offline riverfever
« Reply #5 on: February 28, 2017, 06:40:45 PM »
I'm running the Motogadget Blaze turn signals and they are tiny so I made these tabs very small but you could do something similar. I cut off my grab bar tabs because I wanted the turn signals to be hidden.
Offline evinrude7
  • not a kung-fu
« Reply #6 on: February 28, 2017, 06:45:22 PM »
looks amazing riverfever.
imago, i don't think he has a grab bar.  here's all his 750 stuff http://stores.ebay.com/ridehard15/?_dmd=1&_nkw=CB+750
cb750 k6 - ugly
Offline Mr. Mike
« Reply #7 on: February 28, 2017, 08:04:48 PM »
Although not on my 750, but the idea posted above refers to brackets made to fasten to the license plate frame.  Originally I had two angle brackets on the license plate frame, but didn't really like the look, so I came up with this idea.
Easily fabbed from 1/8" flat aluminum stock available at Lowes.
Did the job for me.
I hope the attachement came through.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline Imago
  • 1978 CB750F
« Reply #8 on: February 28, 2017, 08:06:14 PM »
I like this idea... how do you keep the brackets you made from rotating and falling down from parallel? Want to make me some brackets? Hmmmm... I think I have some LED signal lights somewhere...
« Last Edit: February 28, 2017, 08:09:14 PM by Imago »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=be1p4nep34gl3jk5qjmlpg2l24&/topic,60973.0.html
« Reply #9 on: March 01, 2017, 05:46:41 AM »
i have put mine on the rear light holder..the idea vas to make the hard bags easyer to remove vitaut to take turnsignals off
« Last Edit: March 01, 2017, 05:48:46 AM by strynboen »
i hate all this v-w.... vords
Offline Mr. Mike
« Reply #10 on: March 01, 2017, 07:09:45 AM »
Imago,
I'm certain if you used aluminum as your bracketing material, the chrome sleeve on the seat rail would sort of crush into it and the frame and hold it in place.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline Imago
  • 1978 CB750F
« Reply #11 on: March 01, 2017, 08:18:23 AM »
Imago,
Yup, good thinkin'...
I'm off to my favourite store, Princess Auto, to see what they have for alumaniminum stock and/or something like "riverfever" made. "754" should make and sell these. Now, if I can just find those LED signal lights I know I have...
Offline Imago
  • 1978 CB750F
« Reply #12 on: March 01, 2017, 08:33:43 AM »
Will I need to change my flasher to run LED signal lights, either front and/or rear?
Offline strynboen
« Reply #13 on: March 01, 2017, 08:35:39 AM »
yes and a elektronic blink relæ..as the watt use is almost zero on diode light
Offline Imago
  • 1978 CB750F
« Reply #14 on: March 01, 2017, 09:36:14 AM »
OK, do you have a good source? (Read: cheap).
Offline strynboen
« Reply #15 on: March 01, 2017, 11:38:35 AM »
no..no good links..
 use a automobil type/or newer from bikes..they use to fit in the rubber hose..even they are sqvare..in form.
.have no idea if it vorks vith old type bulbs in the control lights...or they need to be thanget too/or revired vith diodes....so the common grounding not make problems..
Offline riverfever
« Reply #16 on: March 01, 2017, 03:31:54 PM »
The tabs I made are sandwiched between the grab bar and the frame and the fasteners are pretty dang....fastened. I have not ridden the bike with these tabs and LED's yet so I cannot speak to any issues with them slipping but I'd be real surprised if they did.
And I wish you had said something two weeks ago. This is the second set I made. I threw the first ones away because I wanted them a bit shorter in length.
Offline Chachi
« Reply #17 on: March 02, 2017, 01:20:20 PM »
I use these on the rear, but I removed my grab bar:
http://4into1.com/universal-turn-signal-mounting-bracket-set/
I mount them where my grab bar mounted. They have the perfect offset distance for most mini turn signal stems to fit between bracket and frame.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #18 on: March 02, 2017, 01:44:52 PM »
Imago,
I have one of these adjustable flash rate relays....and it works just as described.
http://www.ebay.com/itm/like/121740207541?lpid=82&chn=ps&ul_noapp=true
