Author Topic: Bore Size Master Cylinder ?  (Read 2166 times)
Offline rddcw
« on: March 03, 2017, 12:02:02 AM »
Trying to find out what the STOCK bore size of the Master Cylinder on my 74' CB 750 K4 ?  I'm going to add a 2nd disc up front ( dual disc brake set-up ) and should I use a bigger bore M/C for Better braking performance ? I'm only guessing that the stock M/C is 14mm and need to use a 16mm ?  Can't seem to find an answer to this question anywhere ?
Offline robvangulik
  • Honda Fourever
Re: Bore Size Master Cylinder ?
« Reply #1 on: March 03, 2017, 03:04:25 AM »
Stock size is 14mm, and it will work fine with dual disks, in fact a single disc works better with
 ½inch (12.7mm).
Offline rddcw
« Reply #2 on: March 03, 2017, 03:52:18 AM »
Interesting, do they even make a 1/2" M/C ?
Offline robvangulik
  • Honda Fourever
« Reply #3 on: March 03, 2017, 03:55:18 AM »
And 11mm , 5/8 inch(15.8mm) 17 and 19mm. Don't expect to buy all those from Honda, but even they use different sizes on different bikes. ;D
Offline rddcw
« Reply #4 on: March 03, 2017, 03:58:49 AM »
Where are you sourcing these M/C's ?  I'm sure there are motorcycle applications that used them ?
« Reply #5 on: March 03, 2017, 07:14:15 AM »
https://www.davidsilverspares.com/CB750K4-FOUR-1974-USA/part_123914/
Offline robvangulik
  • Honda Fourever
« Reply #6 on: March 04, 2017, 04:05:01 AM »
Google is your friend, type 'master brakecylinder XXmm'. and make your choice from the list...
